Question about Cub Cadet Garden
Cub Cadet Riding Lawn Mover with Kohler Engine - oil light stays on.
    President:
  • 986 Answers
You need to change your ,and if you already have,the light come on evevy 50 hours to let you know to change your oil, the light will go out after about 2 hours,there is a way to reset it in your owner manual, I just unhooked my battery and it reset
Posted on Aug 20, 2010
Testimonial: "Thanks much for very fast response. Don't remember seeing this in manual. Expect this to work. Was puzzling.,"
  • Donnie Wilson
    Donnie Wilson Aug 23, 2010
    did it work for you??
Oil change
Take the old one out and get the numbers off of it or take it with you for reference. The amount of oil is probably 3 quarts but that can be looked up on cub cadet site.
Jul 26, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Oil warning light comes on &off on riding lawn moorer
If your oil is at the correct level, replace sending unit.
Jan 11, 2014 | Garden
How to check the charging system of cub cadet 1515
start engine put volt meter across batt terminals should min 12v max 13.8v
Aug 28, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
I have a cub cadet with a kohler command series 16 engine..It runs rough,oil gets on the spark plug and smokes a little what is wrong with it?
This usually means that is's been overfilled with oil, or the engine has been tipped enough for oil to run into the cylinder. Drain oil if it's above the line at all, and the problem will go away once the oil's burned out of the cylinder.
Mar 23, 2010 | Cub Cadet Street Sign- tractor lawn riding...
How do i change oil on a cub cadet riding lawnmower
is yours the newer cub with a kohler command engine? if so pop open the cap on the drain to expose the port.
remove the oil fill cap/ dipstick.
put the rubber hose on the end of drain spout and route it to a safe container.
push in on the spout and rotate counter clockwise and pull outward on it to begin draining the oil.
Jul 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
1,103 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
