Question about Haier HTF27R11 27" TV
Hi i was just wondering how to get the picture settings back to default on my haier tv.
  • 734 Answers
Goto setup and return to factory settings.
Posted on Aug 20, 2010
How to do a factory reset
Excerpt: SETUP MENU The third item of the MENU is the SETUP MENU. You can set system settings here. The last item on the menu is Restore Default: Reset all settings to the factory default value: "reset to default"
Source: http://www.manualowl.com/m/Haier/L32B1120/Manual/208789 (page 12)
May 21, 2014 | Haier L32B1120 32 LCD TV
Haier LCD picture goes dark, sound only
hi, since your TV is under warranty,It is better to ask for a replacement a new one ..the problem is factory defect.
Apr 02, 2012 | Haier HL15R LCD TV
I have a Haier Tv model number P42LV6-HD and for some reason the sound isnt working, the picture is still there, but no sound. I think its the audio board and I was wondering if you could send me the...
There is no dedicated audio board in the TV, the audio processing is one of the functions of the main board, also known as the AV board or motherboard.
I'm not sure whether your comment means you have a cable box or a direct cable feed and this is not the most technical answer, but I see this problem regularly with cable boxes and it's rarely a fault with the TV. Often the firmware/software in the cable box "crashes" and needs to be "re-booted". This is similar to what happens with a PC from time to time which is unsurprising as, essentially, these devices are computers.
I'd like to suggest that you reset your cable box before looking for replacement parts / numbers. Some cable boxes have a reset button on the front. Others simply need to be switched off and unplugged from the electrical outlet for a couple of minutes. If you're doing this, you may as well unplug the TV as well and "re-boot" it.
If this doesn't work, you should also try restoring the factory default settings on your TV:
1. Switch the TV on
2. Press the "MENU" button on the Haier remote to open the on-screen menu
3. Use the CH+/- buttons to highlight "FUNCTION"
4. Press the VOL+ button to open the FUNCTION MENU
5. Use the CH+/- buttons to highlight "Restore Default Value"
6. Press the VOL+ button to activate the restore feature
Please note: After restoring the TV to factory defaults, you will need to complete the initial setup again the same as you did when the TV was new.
If you have done all of the above and there is still no audio from the TV speakers, then there is a fault with the TV and you should post back to discuss options for repair.
Before posting back, please also try plugging headphones into the headphone socket on the back of the TV and check whether you have audio in the headphones. The headphone socket is next to the antenna connection socket.
Hope this helps.
Regards,
BElectric
Feb 09, 2011 | Haier Televison & Video
Sound is operating correctly ..However, there isn't any video , screen has an extremely faint picture
Sounds like a broken backlight. That's a write-off for an old set, or a factory warranty repair (90 days labor, 1 year parts). First make sure the TV is in TV mode (press mode on the set, or TV/AV on the remote).
Once in TV mode, press MENU and use the navigation buttons (arrows and ENTER) to choose the set to factory default mode.
Also make sure you have a working signal by trying another TV on the antenna or cable coaxial wire.
You can also try adjusting the brightness from the MENU.
If these steps do not work, call the Haier hotline listed in the manual: 1-877-337-3639
Oct 14, 2010 | Haier HLT71 7 in. Portable TV
Haier HL26R-B LCD-TV no power up
there is a repair kit for these haier sets part# TV-3910-01
you can try encompassparts.com and make sure this kit fits your model. The kit includes a few boards that need to be installed together.
Thks
Roety
Jul 14, 2010 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
Feb 25, 2009 | LG 32LG30 32 in. LCD HDTV
Haier 26; TV Tuner
contact the Haier Service center in NY. www.asnyonline.com
May 25, 2008 | Haier HL32BG 32 in. LCD Television
Haier P42LV6-T1 picture
when TV overheats white lines come across the screen
May 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Picture settings
Go to the menu and select "preset" It should default the contrast, bright, tint and color to factory.
Dec 13, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Haier HTF27R11 27" TV Logo
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
