Question about Philips 190B6CB/27 19" LCD
My backlights for my Philips 190G Monitor is very weak. The screen is black, but when I point a lamp against it, I can see a see some picture but its like the contrast is on the weakest point. Its a problem with the backlights I think, what should I do??
  • 11,361 Answers
Not likely to be the lamp (but not 100% sure), more likely to have bad DC caps problem.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
http://www.badcaps.net
Posted on Aug 23, 2010
Black screen (Philips 190G)
check the brightness / contrast control
do you see OSD (On Screen Display) Menu clearly?
Feb 08, 2010 | Philips 190B6CB/27 19" LCD
When I turn my Toshiba laptop on,it's black
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 26, 2009 | Toshiba Computers & Internet
Monitor blacks out
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 12, 2009 | E-Machines eMachines Monitor E15T4
Need help for my Dell Inspiron 9400 Laptop
Try and determine what is wrong with your LCD screen first and you can then decide the best course of action. Follow these instructions to determine the fault and then check out LCD Parts WEB site for parts, replacement LCDs, service and DIY info..
You may have a faulty inverter or loose power inverter connection. OR
Check out
www.lcdparts.net
Sep 03, 2009 | Computers & Internet
Elonex webbook displays anything black as red
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 08, 2009 | Computers & Internet
Computer is on, screen stays black
Check out
www.lcdparts.net
Jul 04, 2009 | Acer Aspire 3690-2196 Notebook
Display Problems
Check out
www.lcdparts.net
Jul 02, 2009 | Dell Latitude 100L Notebook
Lcd screen black on laptop. External monitor works.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 31, 2009 | Dell Precision M60 Notebook
Please help me:(((( 190g
Oh... poor 4cs,
Sorry to tell you, but you've got unlucky! Your Phillips 190g backlight inverter got fried due to over heating. Need to replaced a new inverter. Good lucks!
Oct 02, 2008 | Computers & Internet
Philips 190G -> http://www.cnet.com.au/i/r/2006/desktops/monitors/22139625/Philips_190G6FB-97_c.jpg
My solution:
Open the monitor. Take off the mainboard. There´s a supply board for the backlight under it.
Replace the two purple capacitors (150uF/25V). These are from a bad batch.
Also replace fuse F1 (lightbrown SMD-component) on the bottom of that board (near the long side).
It has blown as a result of the bad capacitors.
In my case the values were dropped to 25 uF. And the internal resistance (R) was more than 2 ohms.
That´s it. Hope it helped you.
Aug 18, 2008 | Philips 190B6CB/27 19" LCD
Philips 190B6CB/27 19" LCD Logo
476 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
