Sound like a spaceship taking off on spin cycle. Very loud. Something is going to give. Can I fix it before it gives? Probably bearings but can I repair them myself?
    Top Expert:
  • Washing Mach... Master
  • 75,197 Answers
Need the make and the model number of washer, this number is located on a tag on the back of washer or in the owners guide. And yes this is a bearing problem most likely, a very involved and very expensive repair.i
Posted on Aug 20, 2010
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
Whirlpool washer WTW6400SW very loud spin cycle, sounds like airplane taking off
Most likely it is the spin tube bearing worn. Reguires some know how and special tools. Requires a major dismantle of the machine and usally I did these repairs in the shop. Bearing will eventually sieze over use and time. Labor will probably exceed the value of the machine.
Jul 06, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAV 7000 stopped in rinse cycle with water in tub. When turned on, there is a low buz sound. Was making a louder noise prior to stopping.
RepairClinic.com
The top of the washer lifts up like a car hood after two clips between the top and the front panel are pushed with a putty knife. Once the top is flipped open, the screws that hold the front panel in place at the top can be removed and the panel lifted off. The belt may be bad or something may be stopping the belt like a bad pump. Or the transmission drive pulley and bearing may be going bad. If the bearings above the transmission drive pulley fail the brake will not release correctly in the spin cycle causing weak, slow or no spin. The belt & pulley system can be accessed by tipping the washer back. The belt is routed around all three pulleys under the washer and is fairly loose until the motor starts. It is the torque of the motor that gives the belt tension. Leaking or loud "jet engine" sound in spin indicates a bad main tub seal at the outer tub which has caused the spin bearing to fail. This is a complicated repair as the inner and outer tubs need to be removed from the washer to access and replace the seal and bearing components.
Go here for: Maytag-Washing-Machine-Parts
May 05, 2009 | Maytag Atlantis MAV7000
High pitched noise when spinning or slowing down(cat screaming)
Sounds like you have bad bearings. I suggest you get it fixed before it creates further issues.
Feb 26, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Front loader making loud noise with spin cycle
It may be something that was in the wash and fell thru the holes in the inner drum. Check all the plastic agitators and make sure they are all secure and an attach bolt has not backed out of one and rubbing the outer tub. It will wear a hole in it fast if it is.
Usually when the bearings go bad, it gets very loud on the spin cycle, like a loud roar and sometimes clothes will have rust or grease stains on them.
I just replaced my tub bearings on my Frigidare and spent about $60. They are all pretty much the same. On mine they only list the complete rear outer tub assembly with bearings, but you can knock the old bearings and seal out and match them up at a bearing supply house or you can buy online. Online seems much cheaper. If you buy bearings, make sure you get ones with a -2rs on the end of the part number. ex. 6308-2rs. They are sealed and hold up much better in water environment.
I would give it a try, the junk man doesn't care if it comes in pieces or one big piece.
There are a couple online articles that can probably help you. Do a google search for 'washer rear tub bearings"
Jan 29, 2009 | GE WPXH214A Front Load Washer
Loud noise in spin cycle
it is your bearings and your transmission the noise is coming from your bearings but because you have to push the basket to get it started your transmission is bad also
Dec 30, 2008 | Maytag Performa PAV2200
Loud spin cycle
OTHER THEN CHECKING THE WATER PUMP I THINK YOUR RIGHT THE BEARING ARE GOING,IT WILL WORK FINE TILL THEY LOCKUP THEN THE BELT WILL BURN OFF,BUT I WOULD CHECK THE WATER PUMP ALOT OF TIMES IT JUST THAT,LET ME KNOW -MIKE
Nov 03, 2008 | Frigidaire FTF530ES
Maytag washing machine repair
The water pump may be going bad...Yes it probably is a bearing. Take the belt loose and try turning each pully until you find one that makes noise or is hard to turn. Pump and motor should both spin very easily with out noise.
Nov 27, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Spin cycle
  Did it make this noise just when it stopped spinning.  Just for a couple seconds?  If so,  it's only brake noise and not a concern.  If it does this all during spin you probably have a bad tub bearing.  Is it a roaring noise?  This is what the bearing will sound like.
Oct 28, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
