Question about Poulan 25CC Gas BlowerVac
Wont run up to speed without choke partially on. Where are the carb. adjustments? Does it requir a special tool/
    President:
  • Poulan Master
  • 1,545 Answers
Probably uses a Zama Or Walbo carb. The mixture screws are factory preset and may or may not have plastic limiters on them. There are tools for adjusting these type carbs or you can fashion one yourself. Most of the screws are of the "splined" variety.Running partially choked is a result of the carb needing adjustment and/or repair (rebuild kit). Like anything else, they require maintenace and installing diaghram or rebuild kit accomplishes this...you can remove and clean the carb and its internals with non-flammable brake cleaner aerosol spray. Don't use high PSI compressed air on it and never soak the carb.
Posted on Aug 20, 2010
Engine runs on choke but dies without?Special tool to adjust hi /lo carb settings?
Your main jet in carburetor is fouled and needs to be cleaned out. The choke circuit bypasses it but when you remove the choke the gas is supposed to go into engine via the main. If clogged, the engine will quit for lack of fuel.
Either clean the carb and jet or replace carb. And yes, newer carbs have basically non a adjustable jets which is ridiculous since each engine is unique and has to be properly matched to new carb. Way around this is by either buying the special tool (he-- with them) or using a dremel tool to cut into head of adjuster a slot so that you can use a regular flat blade screw driver to adjust.
Oct 27, 2015 | Ryobi Garden
I have a 450 farm boss 50.2 cc huskavrna chain saw wont run out to high speed cant fin a adjustment on the carb
There is an adjustment. But need special tool. That may not be the problem though. If you are running ethanol fuel in it it nay have gummed up the inside of carb so it wont adjust. If you try adjusting you may lean it out and burn it up.
Oct 19, 2014 | Husqvarna Garden
How do you adjust the carburetor?
Most of the newer equipment have EPA carbs that wont allow serious carb adjustment without special tools. The tools are only supposed to be sold to service shops who will make adjustments and then put limiting caps on the adjustment screws. Anyone found defeating these systems can be fined by the EPA. If you think your carb is running a bit lean just use a little bit of choke and see if the engine picks up a bit. Then you can try mixing in some fuel system cleaner into your next tank of fuel and see if that gets you back on track. It is the cheapest way to go before spending any money on shop service or new equipment.
Be safe and good luck!
Oct 03, 2014 | Homelite Garden
Starts good won't run without choke
Possibilities include:
Carburetor has internal air leakage (requiring choke to create more venturi air velocity and hence vacuum to suck fuel through jets)....if older...gaskets dry out...short of "kitting" carburetor can try tightening all carb assembly fasteners....likewise insure carb mount to cylinder is tight. (more daring diagnosticians have lightly sprayed fuel source to external surfaces to detect air leak...engine speeds up when fuel is sucked through air leak)
Another possibility is that the fuel jet is dirty, making fuel restriction..
For that matter, other air/fuel channels can be partially/completely occluded by particulates of corrosion/dirt/etc that can accumulate in the fuel system...let alone plasticizers leached from fuel tubing by alcohol and/or other solvents in the fuel....not to mention other petroleum distillates the can build up with evaporation of fuel during storage....or even as simple as water condensing..
If has conventional adjustable fuel float in float bowel, can be adjusted so that level is a little higher, allowing easier "suck" of fuel through jet and into venturi air stream..
And of course a partially clogged air filter (or even one that looks clean, but the fibers have been swollen by water or inappropriate cleaning solvents).
Aug 30, 2014 | Motorcycles
My 2007 honda shadow starts with choke on but when push choke in dies out
Your fuel mixture may just need adjusting or your carbs may need some cleaning the adjustment is a bit painful as it requires a special tool for the carbs if you take it in for a oil change ask em about adjusting the carbs for you - a good shop will have it done in a jiffy
Jun 14, 2014 | 2005 Honda VT 750 Shadow Aero
I have a Briggs & Stratton 2 cylinder motor Model # 42A707-125201. Runs fine at high speed with the choke off, but it will not idle smoothly unless the choke is partially on (about 2/3). I rebuilt...
The fact the choke must be 2/3 applied to obtain a smooth idle indicates not enough fuel is being supplied by the carb at idle speed. Applying the choke richens the air/fuel ratio.
I suggest you revisit the carb idle air/fuel jets, air passages and any adjustments as well as checking for intake air leaks.
Sep 15, 2017 | Yard Machines MTD Gold 185 HP Lawn Tractor...
Trimmer will start but as soon as i depress the trigger it dies. I have had to replace the primer bubble and in doing so made sure the gasket was put back on properly IT JUST WONT STAY RUNNING can you...
Your trimmer is starving for fuel. If it is less than 18 months old, my guess is that it just needs a carburetor adjustment. If it is older than 18 months, it should have the carb cleaned and rebuilt, or replaced. Check with homelite.com for the cost of a replacement carb, sometimes they are less expensive than having the old one repaired. If it just needs an adjustment, find a local repair shop to do it for you. Homelite requires a special tool to adjust the carb, and won't sell the tool directly to consumers. Some shops will sell the adjustment tool. No special tools are required to replace the carb, just basic tools.
Sep 11, 2010 | Homelite Mighty Lite Lawn Trimmer
My home lite start when on half choke but shuts off in a few seconds to a min. or if i put it on run it immediately stalls
Your trimmer is starving for fuel. If it is less than 18 months old, my guess is that it just needs a carburetor adjustment. If it is older than 18 months, it should have the carb cleaned and rebuilt, or replaced. Check with homelite.com for the cost of a replacement carb, sometimes they are less expensive than having the old one repaired. If it just needs an adjustment, find a local repair to do it for you. Homelite requires a special tool to adjust the carb, and won't sell the tool directly to consumers. Some shops will sell the adjustment tool. No special tools are required to replace the carb, just basic tools.
Sep 09, 2010 | Homelite Mighty Lite Lawn Trimmer
Craftsman blower stalls when choke is disengaged
You need to play with the timing adjustment, either on the spark plug, or the gap between the contact and the magneto.
That'll do it ;)
Don't forget to rate, thanks
Jul 31, 2009 | Craftsman 4 Cycle Blower/Vac
Poulan 25CC Gas BlowerVac Logo
807 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
