Question about Homelite Factory Reconditioned 26cc Gas-Powered MightyLite Hedge Trimmer
I have a gas powered trimmer .Model ut21566/serial no. atki713420. Dated 6-20-07. 26cc. 7hcps0264aj.Used brand new 6 times. Will not stay running . I checked fuel mix ok. I purchased at home depot.If you cannot help me get this running will you send me a letter so i can return to home depot for exchange or buy a new trimmer.Also I work at home depot in west berlin new jersey store 0940 phone no.of store 856-719-0335.My name is john h kosak 706 harrison ave magnolia nj 08049 pn 856-784-2445
  • 718 Answers
Clean your carb and give it fresh fuel. Thats if you are getting spark. Can you give me a note so I can give it to my teacher so I can get back into school.
Posted on Aug 21, 2010
Sears & Craftsman 25cc Weedeater brand new starts but will not stay running?
Try leaving the chokey partially engaged. Operate it this way for a few minutes until the engine is thoroughly heated then move to the run position. If this does not work return it.
Aug 13, 2014 | Sears Craftsman Convertible 25cc 2 Cycle...
Why will My weed eater only run with the choke fully on and cant give throttle?
It sounds like the carb needs adjusted. Things can even happen to new weed eaters.
May 31, 2014 | Poulan P4500F 16-Inch Straight Shaft 25cc...
Keeps stalling out and wont stay running
The fuel system is probably gummed up from the gas sitting in the unit. Change the gas and use a fuel additive such as Star Tron in the new gas to help clean it out. If that doesn't get it, you may end up needing to replace the fuel filter and/or rebuild the carburetor. You can get the model # from your carburetor (usually stamped into the housing of the carburetor, itself) and enter it at PartsBuggy's website here to get a list of the available repair kits.
Ethanol in fuel shortens the shelf life of fuel dramatically and using Star Tron can all but eliminate the problems of ethanol in today's fuel.
Oct 24, 2011 | Homelite Consumer Products 4.0 Amp, 13 In....
What size line for a Homelite Ut21566 Trimmer?
It would be .08 inch.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 13, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite model UT21566 string trimmer runs only on full choke and at lower RPM. I have disassembled and cleaned carburetor but that did not fix problem. Steve
Your carb high and low settings may need tweaking if it's not a fuel or muffler issue. I believe needles are made only to be adjusted by a technician. If you want to try adjusting it yourself, google and you tube your to see how.
May 03, 2010 | Homelite Carburetor Trimmer Blower...
Polan pro pp133
Are you saying that this is a brand new trimmer or is it new to you, used trimmer? You are describing a problem that is typical of a used trimmer.
This is a sign of a clogged gas cap. When the gas cap can't breathe, it chokes out the carburetor.
Try this: The next time you run the trimmer, and it starts to die, loosen the gas cap, it should start running again.
Jim
Jun 22, 2009 | Poulan Garden
Remington Axcess hedge trimmer wont run at all.
Check your fuel lines. It is probably getting air into the system. Also check inside the gas tank to make sure the fuel pick up line is still attached.
If you need more assistance please provide an exact model number and I can better help you.
Kelly
May 10, 2009 | Remington Factory Reconditioned 17-Inch...
Homelite Factory Reconditioned  26cc Gas-Powered MightyLite Hedge Trimmer  Logo
211 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
