How to change ring tone? Model #RC8233R Carlton wireless door chime
Mary, there is a small button on the face of the face of the pusher. With the unit plugged in, push that little button and it will play the next available ring tone. When you find one that you want to use, simply stop and that one will be what you hear when someone comes to the door.
Posted on Sep 04, 2010
  • vickie briggs Dec 11, 2011
    Thank God! We had forgotten you just save our gandsons Christmas!!!
Http://www.carlonchimes.us/ccus-wireless-plugin-chimes.htm
for the RC8233R change tone ...push on small button just above the long push button on outside unit....see manual above for PDF Install Guide Available for other units to see drawings... hit once to change tone...
Posted on Nov 14, 2010
I have a Carlon RC8233R plug in chime with multiple door bells and different chimes. The doorbells have started intermittently ringing without being pressed. Would you know the cause of this? Thanks
Hello Laurie DeLisi,
If you live in the NORTHERN Hemisphere...
my best guess would be RAIN-WATER...
Dismount the unit and bring it inside... Open it and look
for moisture...
Then look at the instructions and see if the BUTTONS
ARE SUITABLE FOR wet locations...
ELSE
You have a NEAR Neighbor... with conflicting radio signals
(just guessing here)
Carnac the Magnificent
Nov 28, 2017 | Carlon Home Security
What is the replacement model number for Carlon RC8233R door chime?
You could look here
Cheers
Sir John Dana Hamilton Taylor
IQ 397
Apr 24, 2017 | Cars & Trucks
Setting the codes for the door chime
Presuming that you are asking how to set codes for the Desa International door chime, here's a solution:
There are two components of the Desa door chime --- the ringer assembly and the door button. Inside each component is a set of eight pairs of pins and several square-ish plastic jumpers. To set a code, you must push jumpers onto the pair of pins for each of three different numbers. (You may find that you have more than three jumpers. If so, the others are spares which you can tell because they will only be covering one of the two pins in a pair.) Whatever three numbers you choose, the ringer and button must match exactly. 5-6-7 seems to be the default set-up as delivered from the factory. This is only a problem if anyone else in the neighborhood also has a Desa chime with this setting. If you use pin 8, the ring changes from a two-tone chime to a 16-note sequence.
Aug 26, 2014 | Desa International White Wireless Plug In...
How do i add a second switch to my rc8233r?
I would try Ebay first (or search the net for availability and prices). I bought CR2032 3V Button Cell (that are used in my Carlon door chime buttons) batteries. I got 10 for under $5. Carlon (Thomas & Betts) still makes a variety of door chimes and accessories. However, on their site, the prices are atrocious. But, I think that Thomas & Betts deals in bulk (as in dealing with retailers). Because they list their items in bulk price form. I personally have 5 T&B wireless door chimes. Hence, 4 of the buttons are in storage. Out of curiosity, I tried all of them. All 4 extra buttons rang all the door chimes. Caution, on the packages of the door "chimes" I purchased. There's a blurb on there that states the wireless buttons for the "door chimes" will not work with the "doorbells". If you have the packaging for the one you have. It will explain. I'm not positive, but it seems the variance is due to whether you use battery or electric powered models. Hope I was of assistance...Greg
Jul 20, 2014 | Carlon Wireless Doorbell system with...
How do I change a ring tone on a Carlton Model RC3253
What is a Carlton? we are in USA
ABS Axle Tone Rings?
The only ones I have seen or worked on
are pressed on the axle or are part of a wheel
hub,rotor or whatever.
I have heard of them cracking & coming loose,etc.
That is a near impossible fix without taking things apart
Dec 01, 2012 | Cars & Trucks
Change ring tones on wireless ringer SL-6166-RX-A Door Chime
The chimes have jumper plugs to select the preset songs.
You CANNOT load your own like cell phones allow.
Jul 22, 2010 | Music
JUMPER SETTINGS FOR SL-6151-RX-A
I just solved a similar problem with mine. I found a PDF of the instructions for changing the frequency and the tone: http://heath-zenith.hcents.com/data/manuals/598-1034-02.pdf
May 14, 2010 | Desa International White Wireless Plug In...
My doorbell also ring neighbor's bell
Change pin configuration on plugin bell and the remote.
The pin configuration should match
Dec 29, 2008 | Desa International White Wireless Plug In...
8,878 people viewed this question
 Grubhead
Grubhead
