Question about Hotpoint Aquarius WF000 Front Load Washer
My door handle has broken heelp!
Can somebody tell me how to open my washer/dryer with out the handle??
I need to get something out really quickly (ie uniform! lol)
I cant figure out how the mechanism works and am unable to see clearly with the door frame being in the way?
Its actually a WD440 but is not recognised on here!
  • 868 Answers
Call a service tech to get help.
Posted on May 24, 2008
Handle broke off
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
1 The washing machine door handle may have broken. ... 3 The electronic door lock called an interlock ...
Opening a locked washing machine door - YouTube
? 1:30
https://www.youtube.com/watch?v=gSF4JS2B_U0
Feb 25, 2012 - Uploaded by ScottStorm1
How to open a locked washing machine door when the handle / catch is ... How to fix a washing machine door ...
How to open a broken washing machine door. - YouTube
? 0:25
https://www.youtube.com/watch?v=UCJPkc_dTCE
Feb 26, 2013 - Uploaded by Kim Degerth
How to open a broken washing machine door. .... How awashing machine door lock works, how to test ...
How to Fix Washer With A Lid Or Door That Won't Op
Oct 07, 2015 | Splendide 2100 Vented Washer-Dryer
What parts do i need to repair the front door handle on my 2005 ford focus zx4. handle still there but doesnt open
there is a skinny rod that hooks up to the handle the little washer looking piece holds it in place it might have fallen off
Feb 28, 2013 | 2006 Ford Focus
Have something stuck between tumbler and the drum its a toploader wirlpool cabrio
Bite the bullet and tell him, its a lot better to get him or somebody who knows how to do the work than to make it worse or destroy it all together figuring it out. The drum comes out pretty easily, but definitely not a process I would feel comfortable walking someone through
Oct 01, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
WD640 how much will a new door cost me as my handle is broken
if its just the door catch they are around £11, if its the door opening handle they are around £12, you will not need to replace door, prob just one of the above. hope this helps regs eggytheman.
Sep 17, 2011 | Hotpoint Aquarius WD640 Front Load...
Malber washer dryer 800 handle broke. cant open door
As the handle will have to be replaced I would suggest calling for a service engineer is the only option ;-0(
You will either have to search in telephone directories OR stay on line and search for '(make) washer service' for instance or '(make) washer spares' and hope that you can find someone reasonably local.
Sorry and good luck.
John C
Mar 25, 2011 | Malber Washing Machines
My equator EZ 2512 CEE washer/dryer suddenly wont finish washing a load of laundry. I think some sort of drain pump may be broken. The door will not unlock. I took the drain hose out and put it on the...
If you are still looking for a solution to this here it is:
In these machines if you try to change the setting of the washer knob without letting a cycle finish which is already set it may happen that the unit won't function properly and hence the unit needs to be reseted. There is a reset procedure for the same and let me know if you would like have the same.
If the door is not opening it is advisable to reset the unit first and then try opening the door which should work and also the door handle won't break then.
If you have already replaced the door handle on your machine it is fine or else you may want to order the same from appliancedesk.com
Nov 22, 2009 | Equator EZ 2512 CEE Front Load Washer /...
Door wont open
Managed to pull back casing on door to reveal the handle and pin holding it together. Once i had pulled pin up slightly the door opened to reveal the door handle catch had broken. Engineer has fitted a new handle and everything is fine.
Jul 22, 2009 | Whirlpool LHW0050PQ Front Load Washer
Suspect door handle is broken on Indesit Washer Dryer WD12x
yes u can open door from the inside,take the top off (take plug out first)put your arm down to near the door latch and you will feel the mechinism there just gently push down or up until the door opens,if water is still in the washer then take drain pipe out of the waste pipe and place a bucket on the floor then put the pipe in that to manualy drain it,hope this helps you,ps you can buy a new door handle from any washing repair shop and they are easy to replace just see how the old one comes off,rgrds,paul
Jul 07, 2009 | Indesit W 123 Front Load Washer
DI 'My self' Washing Machine Door Rubber
This video will show you how to change the door seal gasket on your neff washing machine Neff W5340X0
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Neff W5340X0 Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
358 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
