Washer doesent spin. Was yesterday but it got real slow today and then stopped all together. Washer still works and switches cycles, just doesent spin. I figure its the belt. Would like some directions on how to change the belt unless you think its something else.
  • 92 Answers
It is the belt and i am sure because i am an engineer
Posted on Aug 20, 2010
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
I have a GE wcx1070 and it will not agitate or spin will fill the tub and drain but won't spin. I have checked for obstrutions in the tub and under the agitater. and the belt looks good if it does spin it...
I think it might be the lid switch. 8e3407e.jpgas you can see it can fail mechanically and electrically. To get to the lid switch you remove the front panel firstf373b4d.jpgthen you can remove the top and access the slid switch.
Use this training manual
Aug 06, 2010 | GE WVSR1060A Top Load Washer
My washer will not empty rinse water to begin spin cycle
i believe you have a lid switch issue..if you unplug machine and find the wires to the lid switch. you can connect the wire together..this will make it continue if its the proble. if it is make sure you secure them real good...
May 20, 2010 | GE WWSE5240D Top Load Washer
I have a maytag over capacity plus heavy duty 2 speed 10 cycle washer it fills with water fine you hear the motor kick in to girate but doesent spin or you put it on spin cycle it sounds like it is...
The motor is working, but the mechanism not engaged by the helix so the shaft can not move therefore no agitation or spinning. Motor is designed to turn 2 directions: clockwise and counterclockwise for agitation and spinning. Therefore there are 2 mechanisms to assist these tasks. The drain is control by a separate pump and it is still good also.
The tube has to be out to replace the helix for agitation and a part to engage with the spinning rotation to release the brake so the spinning function can work. These parts are cheap, but the the labor is not. Hope this can help
Jan 09, 2010 | Washing Machines
Frigidaire gallery front load won't spin
Does the washer spin after the wash cycle? It sounds like the door switch. This is a common problem with frigidaires. 90% of the time a door switch fixes it.
Jul 01, 2009 | Frigidaire Washing Machines
Type 111 filled with water and stopped
with the machine off, turn the cycle dial around 3x very harshly, then try it again. If it works normally now, you'll need a new cycle switch soon!
Mar 27, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
