Windowspdate 000006B2 " WindowsUpdate dt000 '
How do I fix WindowsUpdate_8024A000 error in Vista 64 Toshiba Satellite M305-S4848?
Are you on 1TB SSD? Wow! And still on Vista? Have you tried to Google with your update error?
Apr 14, 2015 | Toshiba Computers & Internet
Error code 80080005
Is your windows updates disabled? Is your anti virus up to date? Do you have a Malware program, updated? If you do not have MALWAREBYTES download and install :http://www.filehippo.com/download_malwarebytes_anti_malware/ Run a FULL SCAN, may take hours, depends on HDD size. Delete ALL RESULTS. I don't know your OS? Vista? win7? 32? 64? Her is a standalone windows update for both 32/64:
http://download.windowsupdate.com/v7/windowsupdate/redist/standalone/WindowsUpdateAgent30-x86.exe or
http://download.windowsupdate.com/v7/windowsupdate/redist/standalone/WindowsUpdateAgent30-x64.exe
Nov 19, 2012 | HP TouchSmart Computers & Internet
Can't update using windowsupdate
Hi Good day!!! Turn on your Auto update in your control panel. Click this link it shows you what are the steps in updating windows. http://www.microsoft.com/windows/downloads/windowsupdate/learn/windowsxp.mspx
Don't forget to vote thanks!!!
Leave comments thanks!!
Oct 29, 2010 | Computers & Internet
80070246 error when trying to update windows how to fix problem
Clear the contents of the WindowsUpdate folder
  1. Click Start, click Programs, and then click Windows Explorer.
  2. In the left pane, double-click the Program Files folder.
  3. In the left pane, double-click the WindowsUpdate folder.
  4. In the right pane, click the V4 folder, click Edit, and then click Invert Selection.
  5. Press DELETE, and then click Yes to confirm.
  6. Open the V4 folder, then in the right pane, click to select the IUHIST.XML file, click Edit, and then click Invert Selection.
  7. Press DELETE, and then click Yes to confirm.
Note When you delete the IUHIST.XML file from the WindowsUpdate folder, you clear the whole Windows Update installation history. Microsoft does not recommend that you do this because you lose your record of previous downloads. The steps in this section delete all your files except the IUHIST.XML file.
Apr 04, 2010 | HP Pavillion ZV6000 Notebook
I am not about to open system restore and it has caused some of my other programs not to open or run.
If System Restore does not start, follow these steps:
  1. Run Windows Update to check for and to install any system updates. Visit the following Microsoft Web site to check for updates: http://windowsupdate.microsoft.com (http://windowsupdate.microsoft.com)
  2. If you are prompted, restart the computer.
  3. After the computer restarts, click Start, click All Programs, click Accessories, click System Tools, and then click System Restore.
If System Restore did not start, you can use the "Advanced troubleshooting" section to try to resolve your issue. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact support. For information about how to do this, visit the following Microsoft Web site: http://support.microsoft.com/contactus/
Oct 07, 2009 | Microsoft Computers & Internet
I keep getting error code 0x80080005 when trying to download service pack pack 2 on vista and error code 80080005 when trying to run windows update. can you help?
you can download it from softpedia or dozens of places if you google it download it els where and install it that way i see alot of users have this issue i would also make sure your time date and time zone are correct if you still cant install it from the end user installer . *****http://www.softpedia.com/progDownload/Windows-Vista-Service-Pack-2-Download-112640.html here is the link i would try *****right click your my computer go to properties and find out if you have 64bit windows if so you need to download the x64 version if not x86 is for you food luck
Sep 20, 2009 | Computers & Internet
Can't recognize new nvida video card and ram automatic updates dont work error message 0x8DDD0007
Found this solution, may apply to you:
Thanks to a gentleman by the name of Igor Franchuk, he has found the
fix to this problem, and it so easy, it makes me mad.
Here is what we sent to me:
" I've encountered the same problem as you did today. When searching
the
Internet for the same error in hope for a ready solution in
some discussion forum I surfed over quite a few responses and none
of them were solutions.
After giving up I came up with a solution of our problem. It seems
like there was actually a mistake in the previous versions of
windows update.
After disassembling wuweb.dll that is responsible for webControl
update ActiveX object that is actually handling web based updates
I discovered the place where reboot required message is generated.
After looking in around the code I found that the condition
the message is generated is the presence or absence of
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto
Update\RebootRequired
key.
If the key exists - the message is generated by that brand new v5
update and it fails to work further causing [Error number:
0x8DDD0007].
I assume this key was set up in my registry long ago by the when the
old automatic
update (taskbar version) was uploading a new software and failing to
install it.
The solution then is simple remove the key
so there would be only
Update
key without RebootRequired entry.
REGEDIT4
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto
Update\RebootRequired]
After I removed the key RebootRequired v5 update started to work
happily, and installed a new version of wuauclt.exe
It worked for me wonderfully, and I feel a lot better about sp2. Hope
this helps those in need!
Jul 04, 2009 | E-Machines T3065 PC Desktop
WindowsUpdate_80244019"
I think I have a solution for you.Try this one:-
1. Click Start - Run, type regedit and press enter.
2. Navigate to the following Registry key
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU]
HKEY_LOCAL_MACHINE
\SOFTWARE
\Policies
\Microsoft
\Windows
\WindowsUpdate
\AU
3. Once in, from the right-pane, change the value of the key
“UseWUServer”=dword:00000001
to
“UseWUServer”=dword:00000000
4. Reboot the Windows Vista PC and that should fix the problem.
May 02, 2009 | HP Compaq Presario F756NR Notebook PC
Enquire
Resolution Suggestion One:
# Test your Internet connection to Windows Update.
A simple solution but one that works in many circumstances!
Test to determine if your Internet connection is preventing you from reaching the Windows Update Web site. To do this, visit the following Microsoft Windows Update Web site to determine if you can download the Iuident.cab file:
http://windowsupdate.microsoft.com/v4/iuident.cab
If a file download dialog box appears, the problem is not with your Internet connection. Click Cancel. If you cannot connect to this link, and you receive a "Page Cannot Be Displayed" error message, your Internet connection is preventing you from reaching the Windows Update site.
I TRY THIS OPTION AND I HAVE NO PROBLEM
Resolution Suggestion Two:
# Reconfigure or update your firewall program.
Reconfigure or update your firewall program so that Windows Update is not blocked, and then try to update your computer again by using Windows Update. For information about how to reconfigure or update your firewall program, see the documentation that was included with the program, view the Help files for your program, or contact the manufacturer's technical support department.
e.g It my mean Opening TCP/IP 443 in both directions for this process: %windir%\system32\svchost.exe
I DONT HAVE A FIREWALL PROGRAM.
Resolution Suggestion Three:
# Remove Windows Update entries from the HOSTS file.
To remove Windows Update entries from the HOSTS file, follow these steps:
-Click Start, point to All Programs, point to Accessories, and then click Notepad
-On the File menu, click Open.
-In the Files of type box, click All Files.
-In the Look in box, locate the following folder:
C:\Winnt\system32\drivers\etc\
-Double-click to open the hosts file.
-Remove any lines that contain entries for Windows Update (http://v4.windowsupdate.microsoft.com).
-On the File menu, click Save.
-Close Notepad.
I have seen the 0x80072EFD error resolved by this tip many times...
HERE I AM... I DON'T HAVE A HOSTS FILE... I NEED TO STOP HERE
AND SOLVE SOMETHING?
WHAT HAPPEN WITH THE NEXT SUGGESTIONS?
I TRY THEM ALREADY BUT THE PROBLEM IS STILL THERE.
I DON'T HAVE SPYWARE... I ALLREADY SOLVE THAT PROBLEM.
Resolution Suggestion Four:
# Run the IPCONFIG /FLUSHDNS command.
To run the ipconfig /flushdns command, follow these steps:
-Click Start, and then click Run.
-In the Open box, type cmd, and the click OK.
-At the command prompt, type the following command, and then press ENTER:
ipconfig /flushdns
Close the command window.
Resolution Suggestion Five:
# Add Windows Update addresses to the trusted sites list.
To add Windows Update addresses to the trusted sites list, follow these steps:
-Open Microsoft Internet Explorer.
-Click Tools, and then click Internet Options.
-Click the Security tab, and then click Trusted Sites.
-Click Sites, and then click to clear the Require server verification (httpssmile.gif for all sites in this zone check box.
-In the Add this Web site to the zone box, type each of the following addresses, and click Add after each address:
http://Windowsupdate.microsoft.com
http://V4.Windowsupdate.microsoft.com
https://v4.Windowsupdate.microsoft.com
http://Download.Windowsupdate.com
http://V5.Windowsupdate.microsoft.com https://v5.Windowsupdate.microsoft.com
-Click OK to close all Internet Options windows.
Resolution Suggestion Six:
# Add Windows Update addresses to the proxy settings exceptions list.
If your Internet connection uses a proxy server, add the Windows Update sites to the proxy settings exceptions in Internet Settings. To do this, follow these steps:
-Open Internet Explorer.
-Click the Connections tab, and then click LAN Settings.
-Click Advanced, and then type the following text in the Exceptions text box (all in one line):
windowsupdate.microsoft.com;v4.windowsupdate.micro soft.com;
Note If you are running third-party proxy or firewall software, see your product documentation for information about how to add these sites to the exception list for those applications.
Resolution Suggestion Seven:
# Change the MTU setting on your router.
Yours ISP's MTU for their connection may not be correctly setup on your Broadband router and/or your computer.
Please contact your ISP's support for more assistance on this. However the following articles may be of help:
http://www.microsoft.com/windowsxp/using/networking/
learnmore/ppoe.mspx
http://support.microsoft.com/default...b;en-us;283165
Resolution Suggestion Eight:
# Configure Norton Internet Security 2003.
Norton Internet Security 2003 may be blocking Windows Update. try this:
-Open the Norton Internet Security 2003 Application
-Click on "Norton Internet Security" button located on the left side
-Click on "Personal Firewall" located on center
-Click on "Configure" button on bottom right side
-When dialog box appears, click on "Program Control" tab
-Scroll down and find and click on "Microsoft Generic Host Process for Win32 services"
-Then click on "Modify" bottom at button of scroll box.
-When dialog box appears, click and choose "Permit" button
-Close all boxes and close Norton.
-Reboot your computer.
Mar 06, 2008 | Danware NetOp School for Windows 3.0...
Computers & Internet Logo
312 people viewed this question
David Payne
David Payne
