Question about Garden
MTD- riding mower, 1999. Lawnflite How to remove and replace the throttle control box assembly?
  • 3 more comments
  • pdurksen Aug 20, 2010
    Re throttle control box assembly- this assembly is not a part of the engine, it is mounted under the panel by the steering wheel.
    How do I disassemble the control box?
    Peter D
  • pdurksen Aug 21, 2010
    Hi-
    model -136H455 F511
    Hi
    As mentioned , the model # is 136H 455 F 511
    Peter
    Thanks for your efforts.
    Pete
    How do you remove the throttle control box assembly on a MTD riding mower, 1999 Lawnflite.
    Model 136 H 455 F 511
    Pete
  • 2,926 Answers
Your best option is clicking here and finding the correct linkage assembly. MTD makes there mowers from so many different sources, it is almost impossible to isolate an exact model number and match a component.
http://www.mtdparts.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10101&catalogId=19502&langId=-1&arimn=136H+455+F+511
Posted on Aug 21, 2010
  • 857 Answers
Tools you'll need include a box wrench set; hammer; pipe wrench; nut driver; screwdriver; flywheel puller; match book; the replacement parts.
1. Remove the engine cover and flywheel.
2. Remove the screen that covers the flywheel.
3. Remove the clutch assembly and the flywheel.
4. With the clutch off (if unit has one) you will see the flywheel key in the crankshaft. If the key is bent, you can just replace the key; the points/ condenser may be okay. It not, continue on:
5. Remove the flywheel. You can buy a "puller" for this. It is a block of metal that is inserted over the top of the crankshaft. You tap the "puller" with a hammer, which pops the flywheel off the crankshaft. Do not pry up on the flywheel; it is pot metal and will break.
6. Lift off the flywheel. Under it you will see a small metal covering. Unscrew the covering to expose the points and the condenser.
7. Remove the condenser clamp and condenser. Install the new condenser and lightly clamp it in place. Two tiny wires are slipped into a hole in the condenser; a spring holds the wires under tension. There is a plastic tool in the kit to hold back the spring tension while the wires are threaded into the hole.
8. Remove the moving point. As the slotless screw is removed the spring and point will lift off.
9. Install the new moving point. Fasten the spring to the arm of the point and the spring post. Then move the condenser forward so it touches the tip of the moving point. Turn the crankshaft via the blade until the moving point opens to its widest gap.
Posted on Aug 20, 2010
Lawnflite 630 ride on mower. Key to turn how do we start the engine?
hi,
did you lose your key? here is a link to buy one, they are generic so you might be able to go to a local lawnmower shop for that. if it wont start with the key check your safety switches at the blade control lever under the panel and under the seat. riding lawnmowers that sit out get rusted all over, look for rust and bad connections under the service panel and battery compartment, sand connections with sandpaper..
https://www.partstree.com/parts/mtd/mowers-lawn-garden-tractor/136-630-331-lawnflite-lawn-tractor-1986-forest-city/electrical-without-headlights
Jul 31, 2017 | Garden
Can anyone help me and tell me the part number for a blade for a dx70 Mtd yardman 8.5cc
Duncan, Blade #, MTD Part No 742-0578, 27.5" should be replacement bade for Yardman DX70. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GENUINE 27 5 Blade for Yardman DX70 MTD Beatle Lawnflite 503G Ride on Mower
YARDMAN DX70 MODEL 310 SINGLE BLADE MOWING DECK FG424 5900
Yard Man 13A 325 402 Operator Manual
May 21, 2016 | Mtd Garden
How to remove the rear wheels from a mtd lawnflite ride on mower
they just need bumped off after the bolt is removed .they will be rusty so some penetrating oil will help a lot
Feb 17, 2015 | Mtd Garden
I have an mtd. Lawnflite model 135-668-352 and need a belt, but can't seem to find one. Can u help?
There are two belts in this parts list (and 6 other parts lists for your model) on this site:
Parts and Diagrams for MTD Lawnflite Mdl 668 352
May 20, 2014 | Garden
I need a throttle cable assembly diagram for mtd yard machine riding mower
any lawn mower shop or homedepot/lower and most hardware stores use a new cable on your control handle
May 13, 2012 | Mtd Garden
Where can I find the diagram for the cutting deck belt routing for an MTD Lawnflite tractor mower 13AA478E678
Hi go onto the powerhouse site below, put in your mower details and you will see the plans for the deck.
Geoff
www.powertoolspares.com/...lawnflite.../906-13af765n611-1998-576/
Oct 19, 2010 | Garden
What size drive belt for a mtd lawnflite 11 hp
(1991) 131-531C611/505
(1990) 130-531C611/505
(1992) 132-531C611/505
(1993) 13-505 / 133C561C611
Jul 20, 2009 | Garden
Garden Logo
358 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
