Question about Iomega Micro Mini 4GB 4200rpm 480Mbps USB 2.0 USB 2.0 External (33361FT) Hard Drive
My 4GB GIGABANK can not access the data on the drive! At one point I could see the data, but I did not try to go further for fear it would corrupt my drive. Is there anything I can do, or a place to send it to recover my files?
  • Michael Siller Aug 20, 2010
    I'm not able to even access the drive now; the light comes on, but does not recognize the drive!
  • 1,606 Answers
Usually what happens on these usb drives is the usb part of the drive fails. The hard drive inside which is a standard drive will be just fine and so will your data.Unless you have a extremely rare situation the drive is fine.
You can send this to a data recovery place and spend about $500 to get your data back.
Or you can buy a new external usb drive enclosure for anywhere from $15 and up and take the drive out of the enclosure and put in in the new one. This is something you can do yourself or just take it to a computer shop and they should do it for say an hours labour charge or less. It only takes about 10 minutes to do but the charge will depend on how busy and greedy the shop is ;-] It's worth calling around and tell them that you want to know how much to take the drive our and put in a new enclosure. If you buy the enclosure from them they may be a bit better on the labour. If your tempted or want to consider doing this yourself just search for usb enclosure instruction on youtube or google and you will find several videos. The hard part will be getting the original enclosure apart as the screws may be hidden or it will use tabs. Putting it in the new one is quite straight forward.
Anyway don;t panic, your data should be just fine unless you are very unlucky. I've fixed a lot of these drives this way and have yet to see a dead drive. I'm sure it happens but not that I've run across.
Posted on Aug 21, 2010
  • 712 Answers
Try to access the device using "RUN". If that doesn't work, try "SAFE MODE".
Posted on Aug 20, 2010
  • Sebin Punnacheril
    Sebin Punnacheril Aug 21, 2010
    Try re-installing the USB port.
A partition of my hard drive is not accessible and when I format the drive it says format can not be completed drive is corrupted what should I do.... please help!!!
You can try with this corrupted partition recovery software. I have utilized it, it works well. It has recovered my lost partition containing important data. You can check with the link for further details- http://www.macpartitionrecovery.com/corrupted.html
Jan 22, 2013 | Computers & Internet
My memory card shows me the folders as .exe files,also i cant access to them, how can i solve this problem?
The file system has become corrupt and unreadable, or at least a section of it. If you can't reformat it then it's likely dying or dead. At least you should be able to recover some of your data however...
Go here and get a FREE copy of USB Flash Drive Data Recovery Software:
http://www.easeus.com/resource/drive/usb-flash-drive.htm
May 17, 2012 | Sony 4GB Memory Stick PRO Duo Memory Card
Gigabank powers on.....doesnt read onto my laptop.......Dell Inspiron 1525, that of which used to work fine at one time......cant retrieve any of my files....
From your description it sounds like your GigaBank is damaged. You can check if there are problems with the drive using the free trial version of http://www.hdtune.com/
If it checks out ok then you can try to recover your data with Recuva it's free http://www.piriform.com/recuva
Or if you need data recovery help this a good choice for low cost and fast data recovery. All data recovery work is performed by an experienced tech remotely over the Internet from a boot cd that you download and the best part is they just ask for donations: http://FreeDataRecovery.us
Jul 29, 2011 | IO Magic Corporation GigaBank (I250HD35)...
I HAVE MY PNY 4GB MICRO PEN DRIVE.....AS NOW IT GOT CORRUPTED.... IT CAN'T GET DETECTED BY ANY OF COMPUTER AND LAPTOPS ......SO PLEASE GUIDE ME THROUGH THIS PROBLEM..IS THERE ANY SERVICE CENTER IN...
SaveMyUsb.com can recover data from most damaged faulty and corrupt flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 28, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
My SanDisk Cruzer Gator 4GB is not working. When
The filesystem appears to be corrupted. Try right-clicking the drive's icon, going to Properties, Tools and Check Disk. If that doesn't help the partition that holds the data may be unreadable, and if that happens try asking a data recovery service if the data is important.
Jul 12, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Computer does not read my gigabank 8.0; no access to data
hi,
These drives are pretty sturdy but it sounds like the USB control circuit may be dead.
If this is the case what to do next comes down to what's on the drive. If there is nothing important on the drive which isn't backed up somewhere else. Buy a new one for $30 and recopy the file on the new one. If you need the files on it you can send it out for data recovery, anywhere from $100-$1500 depending on which part failed. I know a few places able to help you if you need this option. If you need the pros reply back with your Country, State and City and I will refer you to an appropriate pro for the job.
Hope this helps FixYa,
Chris
Sep 02, 2009 | IO Magic Corporation GigaBank 8.0...
How do I open the case to replace the hard drive of the Toshiba 160GB external hard drive? It is a model # HDDR160E03X.
Just leave it in the case. Unplug it to prevent further damage. Don't worry in many cases you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Jul 08, 2009 | IO Magic Corporation GigaBank (I250HD35)...
Cruzer 4GB Zip will no longer read
If your drive does dhow up, but the data is not there there was somehow a short in the drive, like ultimitloozer said if you don't safely remove hardware that short can corrupt data, or delete it. You will need to get a software that searches your drive for corrupt data and see if you can restore it, but that is unlikely. Sorry. However you drive will still work, but you will just need to be careful
Ryan Frame
Creative Energy Associates Technical Center
Head Technician
Apr 06, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
IO Magic 250gig external hard drive
Unfortunately the hard drive within the external case has died. The clicking noise you can hear is the read / write heads trying to find anything on the platter and failing, this means that any files that were on the drive are lost. There are many tricks on the net that give hope of recovering data off a dead hard drive but most just corrupt the data completely. If you have files that you must have and can afford the extremely high price for data recovery there are services available through most hard drive manufactures, most notably through Seagate.
May 07, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Computers & Internet Logo
69 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
