I can not open my usb flash drive. computer unable to detect flash drive. what do I do?
    Sergeant:
    Champion:
  • 389 Answers
Try another usb port 1st,preferably on the back side of the pc.If it still doesnt work try it on another pc.if it doesnt work on aother pc its more than likely bad.
Posted on Sep 03, 2010
My pen drive unable to show my data on it & aiso not detect in any pc or laptops.What can i do?
If the flash drive is not detected, it means there is damage to hardware.
Flassh drive hardware malfunction, there are two types
1. Cracked solder.
Solution: Open the flash drive casings, heat the tin solder.
2. Resistor (R) broken
Solution: Open the casing flash drive, flash drive instead of resistors.
Hopefully this information helps
Nov 09, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend jf v30/64gbmy pen drive is not detected in my computer
Flash drive not detected, it means there is damage to hardware.
Damage to hardware, there are two types
1. Cracked solder.
Solution: Open flash drive casings, heat the tin solder.
Solution: Open flash drive casings, replace the resistor.
Nov 04, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I do not know how to use a usb flash drive
Just plug in your usb flash drive to your computer's usb port. Once plugged in, your computer will detect it and should pop up a notification on the lower right corner of your screen saying that it has detected a new usb device. Now to view the files in your flash drive, RIGHT click your windows START button and choose Explore or open Windows Explorer. Then find under My Computer or Computer, then drive letter associated to your flash drive; click on it and it will show the contents on your right. To save files on your flash drive, just select for that drive location.
Hope this helps. Thank you for using FixYa.
Feb 26, 2011 | Computers & Internet
How to solve usb not reconized error in sony vgn-s36gp?
Hello
Disconnect the flash drive from your computer, then plug it into a different USB port. On occasion some USB ports do not detect inserted equipment (either because the port is damaged or because the flash drive is not supported by the particular connection).
Connect the flash drive after the computer has powered on. If you plug the drive into the computer before starting the system, the computer may not detect the USB device.
Open an Internet browser and navigate to the drive manufacturer's website. Although most USB flash drives are plug-n-play, the computer may not have the appropriate drivers installed, which means you must install the driver before the system can use the flash drive.
Select the "Support" option, then choose "Drivers and Downloads". Click on the model of flash drive you are using, then the operating system. Click on the driver download link and wait for the driver to download to the computer. Double-click the downloaded file to load the installation wizard. Accept the license agreement, then follow the prompts to install the driver. Restart the computer and the system is ready to use the USB flash drive.
Oct 12, 2010 | Sony VAIO VGN-CR220E/P Notebook
I got a Kingston 4GB Data traveller pen drive which when plugged into the usb slot gets detected and also opens fine but when i try to send in files to it it says : "Windows was unable to save all the data...
hi,
its not a issue , down load HP low device formatting freeware , then format your usb using that software , then reboot you computer inject the usb, again format your usb in windows , use FAT32, not ntfc to format, it will for mat then try to save it it will , its nothin your usb is affected by autoexe virus it will be find if you follow what i said,
thank you,
domnickr...
Sep 14, 2010 | Kingston 4GB Secure Digital High Capacity...
Kingston DTI/512
If you are unable to open it ,there might be a virus in you flash drive which is causing problem .
Solution:
Select the flash drive and right click .now select autoplay, a dialogue box will appear ,now select open to open it..
if you are unable to do this .
open my computer ,in the address bar ,click on the downn area button in address bar and select flash drive to open .if this also fails you have to format the flash drive ..
Try this in other pc if you are unable to do this on your computer ..now if you are getting same problem ,format it.
right click on it >select format >and format it to remove virus ...
If this answers your question please rate this as fixed.
THANKS.
May 08, 2008 | RCA (DVDCP33) Media
Sandisk flash drive
Strange... Vista does seem to have a problem with everything Sandisk...
Anyway, this should be all you need:
Launchpad Installer
Launchpad Uninstaller
Mar 19, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
