Cold water will not flow into the washer. I just replaced the valve assembly. Model number is FWTR425RG50
  • Washing Mach... Master
  • 17,130 Answers
Did you check if the inlet valve was receiving voltage to open when the program is put on for wash. If voltage comes in the valve must open and you must hear water filling. If not the valve is deffective. However if the voltage is absent when the wash cycle is started then the controller unit , main board , is not outputting the valve voltage from the driver/relay. As the boards are epoxy filled on to the tracks you can remove the components to change only by cutting into the board. the company expects a new board to be put in place.
Please check this out and credit me if helpful.
Posted on Aug 20, 2010
Kenmore eco cycle front load washer. error E70 displays and stops washer. What does E70 mean?
You should check the model number of the washer. If the model number starts 417, then the washer was made by Frigidaire. In that case, the E70 error indicates that cold water is not being detected at the washer inlet sensor.
In some cases, this could be due to connecting the hot water line to the cold water inlet (and the cold water to the hot water inlet). Make sure that the cold water shut-off valve is open. Try swapping the water hoses (close the shut-off valves first). Try new hoses; some anti-flood hoses will restrict the water flow if they detect damage. Thus you won't have sufficient water coming into the washer. (You can check this yourself. Turn off the shut-off valves. Disconnect the hoses from the washer and put the ends into a bucket. Then open the shut-off valves and check the water flow.) While you have the hoses off, check for debris in the inlet filters.
If the hoses are fine, you probably have a problem with the washer's inlet valve or the reed switch that measures incoming water. The inlet valve should be replaced if you find that only hot water enters the washer.
I hope this helps. Please add a comment with the model number of your washer for more information. It will be on the inside of the door opening (probably at the top).
Sep 30, 2013 | Maytag EPIC MFW9700S Front Load Washer
W6444
make this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 25, 2013 | Washing Machines
Washer stops between wash and rinse, and stays full of water. ld code
see this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 21, 2013 | Kenmore Washing Machines
The washer work but stop along the way,ie unable to complete the circle
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Washing Machines
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Maytag A282 Washer low water flow, both H&C
Your supply hoses have screens in the ends.....shut off the water supply valves, unhook the hoses and take a look at the screens....sounds like they are plugged.
Jun 01, 2013 | Plumbing
Affinity stops in the middle of a cycle a just shuts off no signal or anything?
use the following steps. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
May 23, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer heavy duty cycle issue
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
God bless youcb4af627-0171-42f5-ad0a-5f8e85e72ae0.gif6634bf88-8eca-4d0f-b59c-0e8829e5d59d.gif419f93c3-fea0-4d93-af85-2e59d98d88e0.gif
May 23, 2013 | Whirlpool AWG320 Front Load Washer / Dryer
Water does not shut off. Water flows constantly
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
©2006 Publications International, Ltd.
If an inlet valve is faulty, check the water connection and the
valve screens. Try gently tapping the solenoids;
if this doesn't work, replace the inlet valve assembly.
Step 1: Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
Step 2: Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
Step 3: Tap the solenoids with a screwdriver handle. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
Aug 29, 2009 | GE WBVH6240F Front Load Washer
Washing Machine is not getting cold water
The solenoid comes as part of the fill valve assembly. It's fairly simple to replace, but before you attempt replacing the valve try turning off the water supply and disconnecting the hoses from the back of the washer first. Inside the valve assembly on the back of the washer are water valve screens. These screens can get clogged with sediment which will restrict or stop water flow. If you've never checked them or cleaned them before this could save you a little bit of repair time. Simply use some distilled vinegar and a cotton swap and thoroughly clean each screen. If the valve still does not produce water flow, the part number is 878761 an runs about $25. Let me know if this helps you.
Sep 21, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
