Question about Watches
When i excellerate, there is a pinging sound. I tried adding fuel injector cleaner and using higher octane, but still does it. Am I in immediate danger?
    Genius:
  • 1,970 Answers
Mcdevito75 here, The pinging sound you hear is the air and fuel mixture being burned to fast in your engine, the spark at the spark plugs is happening to soon, depending on the year of your Ford, the spark timing is controlled by computer. I would recommend you have your local auto shop run a scan on your cars computer and adjust the ignition timing if possible. No real danger but could cause extra wear in the engine., (cylinder walls and Valves)
Posted on Aug 20, 2010
Flashing stop
Those "pop ups" telling you your computer is about to crash is a form of virus. You need to do a scan on your system to locate and remove the problem. Once you do this it should stop the pop up ... Do not ever click on the pop up and let it scan for you ... that's part of the virus. Just close it out right away. Try one of the reputable free cleaners like CCleaner or the trial version of Malwarebytes. If you do not feel you have the capability to install and run these programs you may try someone like Geek Squad to come help you out. It will be a fee but I would think that is better that seizures! You may also get more responces if you post your question in the computer section rather than the watch section.
Nov 30, 2013 | Watches
What causes smooking exhust
mcdevito75 here, The exhaust smoke you see is the burned air and fuel mixtue your engine makes to power the engine and thus your car, depending on the color and amount of smoke from the exhaust, some engine problems can be recognized.
Jun 20, 2010 | Caterpillar Diesel Power PD14135222 Watch...
Carbuetor promlems
Before removing carb a suggestion to check first,make sure distributor is supplying power to spark plugs and do inspect inside cap for moisture if there is no "fire"then that needs to be repared,"several things can cause this or if moisture is found clean distributor interior thouroghly and replace cap or it will happen again.if this is not answer try removing air filter for as long as possible along with plugs and let excess fuel evaporate before cranking anymore and add good fuel cleaner to fresh fuel and try again,old fuel can have condensation and not ignite.If you still find no change the problem may very well be carb and depending on how hard finding gaskets or replacement parts for it someone with experience may be needed for repair because carbs are difficult to do right without some knowledge.
Apr 20, 2009 | Watches
Citizen BL717459L - Alarm sound is too low
No, there is nothing wrong with the alarm in your watch.
The sound in all watches are generated by passing vibrations to the metal tweeter which is connected to the watch caseback inside the watch. As the surface of the watch is quite small, there is not efficient power to spred the vibrations over the caseback surface, hence low volume of the alarm. No wristwatch in the world is capable of loud alarm sound yet. This is something the scientists have to work with.
The plastic protector is definetly affecting the volume. Take it off and you will notice slightly better sound. This protector actually is ment to protect watch caseback from scratches prior to selling it to the customer and have no use after that. In fact it only collects the dirt and bacteria and can affect your skin as the caseback as well.
Another sound improvement can be the new battery if the original is underpowered. Alarm feature uses the most of the energy stored in battery and the power consumption is higher than all watch movement parts put together.
Rate me, please.
Mar 12, 2009 | Citizen BL717459L Watch
Peugeot406hdi
It sounds like the pump may be faulty. These are not cheap ! Could be a faulty pressure sensor, loose pipe connection or blocked fuel filter. Check the fuel filter is clear of water and dirt. Check there are no visible leaks between the pump and the injectors.
Have you run it low on fuel ? It is possible to get air in the system, and as air is more compressible than diesel, the pump pressure sensor may be showing a low pressure.
Oct 28, 2007 | Watches
Triax CV10
Nike Triax CV10 - Successful HRM reset 7 November 2008
I had real problems too. Even after repeatedly following the known reset steps everyone else is posting up. Here’s how I got mine going, please forgive the mind bogglingly tedious detail…
First make sure you’re using new good quality batteries. I used Maxell’s, bought in 10’s from Hong Kong on ebay – no problem.
Second, and this is the ESSENTIAL bit…move right away from the computer and any other electromagnetic sources before carrying out the known reset…
Third, follow the known reset steps below, adjusted to what worked for me…
If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit.
Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button.
The re-initialisation steps for the Nike C10 and CV10 digital HRM's is:
(1) reset the watch
(2) open the battery door on the chest strap
(3) move the watch to RUN mode
(4) press the reset button in the chest strap battery area without removing the battery
Tip - I agree with the suggestion to use a pin or needle and definitely do it with the battery in the hrm.
Tip – Thumb holds battery to stop it from pinging out, other hand performs jiggle with pin until the link is made (it links straightaway if you jiggle it just right!)
(5) replace chest strap battery cover…and smile!
Nov 30, 2006 | Nike Triax CV10 Wrist Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
