Question about Kodak EasyShare DX7630 Digital Camera
Menu wheel and joystick
I have been having difficulty with the wheel being hard to rotate and also noticed the "joystick" does not respond sometimes, wondering if there is a warranty covering these items? Thanks
  • 1 more comment
  •  Susie Q
    Susie Q May 12, 2008
    Yes my joystick will only work up/down/left....it will not go right or "in" to select an option....So Now I can't change any settings ....like turning the date on and off.
    So if anyone has any ideas Please let me know via email!
    Thanks
    Susie
  • Anonymous Jul 14, 2008
    Joystick up-down; side-side; and ok features do not work consistently.
  • Ctfun4u Aug 20, 2008
    joystick works in left, up down positions but not right or in out for video play etc.
Took back of camera off 6 screws, and found wheel had skipped ofer plastic range limeters. took small screwdriver and popped them over limeters wile twisting. wheel works now but joystick does not work. also wheel spins but functions do not work.
Posted on May 06, 2008
My Dad's 2012 Pride Jazzy Select 6 wheelchair is difficult to maneuver. Since all 4 wheels rotate, backing up straight is impossible. What is my problem?
A light touch on the joystick is first. If it remains difficult then have the joystick reprogrammed. Only a dealer is set up to reprogram a joy stick.
Jan 11, 2014 | Pride Jazzy Select 6 Indoor Power...
My Magellin eXplorist 100 will not respond when the 'start' utton is pressed. Is there a 'hard reset' option somewhere on this thing?
  • To perform a hard reset follow these steps
  1. Press "MENU."
  2. Use the arrow stick to highlight "Preferences."
  3. Press "Enter."
  4. Use the arrow joystick to highlight "Restart GPS.'
  5. Press "Enter."
Regards, Tony
Apr 28, 2011 | Magellan eXplorist 100 GPS Receiver
My eXplorist 100 will not respond when the 'start' utton is pressed. Is there a 'hard reset' option somewhere on tjhis thing?
  1. Press "MENU."
  3. Press "Enter."
  5. Press "Enter."
Regards, Tony
How to change setting picture just opposite
If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
Press MENU button to display the menu screen.
then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
1. FRONT DESK
2.FRONT CEILING
3.REAR DESK (A translucent screen is required for rear projection)
4.REAR CEILING (A translucent screen is required for rear projection)
If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
Jan 21, 2011 | Panasonic PT-LB60NTE LCD Projector
Left joystick sticks
Sounds like the joystick is sticking, the only thing you can do would be to take apart the joystick and with a slightly damp washcloth, and clean off the joystick. Then after you clean all the stickiness off, put the joystick back together and the screws back on and it should react like normal.
Courtesy of Ehow here is the link that gives instructions on how to take apart the controller:
http://www.ehow.com/how_4865722_apart-xbox-controller.html
Aug 07, 2009 | Microsoft Xbox 360 Controller
80gb ipod video broken clickwheel buttons
Its possible your click wheel has gone bad, what you should try before freaking out is to do a hard reset. To do so hold down the center and menu buttons for 10 seconds. if there is still no response at all, then your clickwheel is fried and you should look online for a new front cover with a new click wheel.
Jan 05, 2009 | Apple iPod MA446LL/A MP3 Player
Finalize
to finalize the disk for enabling discs to be  played on other devices. Connect this unit to the AC adaptor. Finalization cannot be executed using a battery. Rotate the mode dial to select the arrow. Press the MENU button, then select SETUP, FINALIZE, YES and press the joystick. Select whether or not to create a top menu, then press the joystick. When the confirmation message appears, select YES then press the joystick. hope this helps you. julie
May 19, 2008 | Panasonic VDR-D100 DVD Camcorder
Microsoft sidewinder force feedback 2 joystick
Well, I just noticed this exactly same problem with my new PC, so i try it with my older PC and it works fine, I´m not sure if this has something to do with the USB 2.0 or the driver, but i was not able to find the version 5.X for it, microsoft page only has the version 3.2.
the extrage part is that both PCs are using the same version of WXP.
Feb 22, 2008 | Microsoft SideWinder Force Feedback Pro...
Nokia 6600 joystick (to the left) not working
I HAD THE SAME PROBLEM WITH MY NOKIA 6620 FOR 3 DAYS. AND I OPEN THE PHONE AND PLAY WITH THE JOYSTICK AND IT STARTED WORKING. TRY THAT...
Sep 10, 2007 | Nokia 6600
Kodak EasyShare DX7630 Digital Camera Logo
231 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
