Question about Kenmore 24032\24036 Top Load Washer
My washer just stop spinning and the water will not go out It willwash and rinse but not spin and will not empty
  • Kenmore Master
  • 17,129 Answers
For sure it is the fault with the program controller. You will need to replace the unit as the programme is not advancing.
So check this out.
Posted on Aug 20, 2010
Rinse and spin cycle keeps repeating at 11 minute time to 17 minute time and won't stop
Sounds like your washer does not empty enough water for the spinning to stop. Have you check that the filter(s) are not clogged?
Jan 23, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Will not drain the water
The most common cause is a foreign object caught in the pump keeping the little impeller from spinning. Take off the pump hose and make sure it is not plugged.
Mar 14, 2012 | Hotpoint Aquarius WF000 Front Load Washer
Washer stop
My first thought Lid switch gone bad. This washer has a motor which reverses. The motor is a double shaft design. 1 end of that motor drives the transmission and the other end drives the pump. When moving in one direction the tranny agitates them clothes and the water cannot be repelled out of the washer. On spin cycle the motor goes opposite directione and tosses out that water while spinning the drum. Later models have a fancy spin pawl which allows them pump to empty that water and lessen the strain on the motor. If that safety lid switch don't act right then them washer will be dead in da water during dat rinsing cycle. Now here is a wondermous vido i found on dat new fangled world wide web from repair clinic the most wondermous site to buy them parts for this washer.
More good stuff HERE
Visit my forum and I might told you a story: Here
Jun 19, 2010 | Whirlpool Inglis IP4400 Washer
Washer is getting stuck at rinse cycle-
sorry to keep asking questions but i just need to know a little more information. are you using auto fill? have you tried manual water level settings? is your machine the one with the LCD DISPLAY?when it stops at rinse, is it agitating? if you have the LCD display have you tried the- traditional wash mode? please reply 4 further help.
May 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
My washer will not empty rinse water to begin spin cycle
i believe you have a lid switch issue..if you unplug machine and find the wires to the lid switch. you can connect the wire together..this will make it continue if its the proble. if it is make sure you secure them real good...
May 20, 2010 | GE WWSE5240D Top Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Fisher paykel will not complete rinse spin cycle
will sence it will spin once the water is out .that must mean your pump is restricted.unplug go to buttom of washer find pump and clean out
Dec 31, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washer will not spin
normally i would suggest changing motor carbons for hotpoint washers, but my experience is that the WMA motor armature is weaker than the carbons, normally if there is no connection fault a replacement motor is the answer 9 times out of 10, not a job for the amature
Aug 28, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
49 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
