Question about Toshiba Satellite A15-S129 Notebook
I have a Toshiba Satellite A15-s219 that someone gave me,and it does lite up. I think it might be the adapter,because it does warm up when plugged in to a wall outlet. Should I be looking for something else besides the adapter.?
    Sergeant:
  • 238 Answers
  1. Check your power cord & adapter.
  2. If its working then check the battery, reseat the battery & check.
  3. If available then check with another battery
  4. If no, then remove the battery & switch on the PC in AC mode.
  5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
  7. If still no display, connect an external monitor, check if display is comming.
  8. If Display is coming then your LCD need to replace.
Posted on Aug 20, 2010
  • coachjp1 Aug 21, 2010
    Thanks for the advice on my Toshiba,I have checked the adapter,and it seems to be alittle warm after awhile trying to boot up. But it does not lite up like it would on a normal startup with my other laptop. I will do what you have mentioned and keep you updated with my problem...thanks alot
    coachjp1
My Toshiba Satellite A15-S127 Will not stay on for more than 15 minutes. It then shuts it's self down?
There are three possible reasons for that.
1. it's overheating. Feel to see if there is air moving out of it (when it's running) and if that air is hot. Also see if the bottom feels hot (it always is warm but shouldn't be hot hot), or if it feels hot around the touch pad then it is definitely overheating. Lint, dust, pet hair etc gathers inside and blocks the fan. The CPU has to have air movement in order not to over heat. If it's hot it needs to be cleaned out which is something that has to be done very carefully so as not to burn out the bearings of the fan nor push the dust in further.
2. The power adapter could be bad. They do go out. To replace one make sure it is matched to the one you have, for that model. Not all adapters are the same.
3. It could be the battery, tho with a toshiba is will run plugged in on a low battery.
Toshiba "A" series were notorious for overheating due to the way they were made though the A-15 is not one of those with the problems that way. (There was a class action suit over the earlier "A's" because of it. But the most likely reason for shutting down like that is over heating...
Apr 09, 2011 | Toshiba Satellite A15-S127 Notebook
I have toshiba satellite a15-s1292 laptop.does this model have wifi in it?
there is no wifi card built in to the laptop as standard but it is easy to use a usb wifi adapter to allow a wifi connection
Feb 16, 2011 | Toshiba A15-S1292 Notebook
Need to find wireless card for Toshiba Satellite A15-S127 laptop
Just get a wireless network adapter and plug it into your USB port...any newer makes will do:)..D-link...so on
Apr 13, 2010 | Toshiba Satellite A15-S127 Notebook
I have a Toshiba Satellite A15-S127
Support site for that LAptopp is here http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=411405&rpn=PSA10U&modelFilter=A15-S127&selCategory=3&selFamily=1073768663
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | Toshiba Satellite A15-S127 Notebook
Toshiba a15-129 laptop--Will not turn on. Yellow
Your laptop is having a power problem. There was one Toshiba satellite pro that my friend had, it gave exactly the system fault as yours. And by the time we checked, it was a power problem.
The laptop had one IC that controls both the power and the entire board. If anything happens to that IC, it will affect the whole board.
I hope yours is different, because if it is the same, it will result you replacing the whole laptop mother board.
I would advice that you take your laptop your a qualified specialist, so that the fault will be made know and solution will follow.
I wish you the best.
Dec 18, 2009 | Toshiba Satellite A15-S129 Notebook
S-video tv out for TOSHIBA A15-S127
Hello Earl,
The device you need is called a scan converter, they are available from www.newegg.com search for avermedia. Please keep in mind, these adapters will convert from pc to tv but the picture in now where near as clean and crisp, especially for text. I think your best be would be to spend just a little more and get a 19-22" LCD monitor.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 18, 2009 | Toshiba Satellite A15-S127 Notebook
Hard drive crashed
Nope, it's just a matter of pulling the old hard drive and putting in the new one. Sometimes there will be an adapter attached to your old drive that you'll have to transfer over to the new one. What you need is a 2.5" mobile PATA (IDE) drive.
May 28, 2009 | Toshiba Satellite A15-S129 Notebook
Toshiba Satellite A15-S129 PC Notebook
Have you turn the wireless antenna switch on?
Mar 31, 2009 | Toshiba Satellite A15-S129 Notebook
I'm need to replace the hard drive without having a system disk.
Google "TOSHIBA RECOVERY AND APPLICATIONS/DRIVERS SATELLITE A100/A105 SERIES" to find the cd delivered with a TOSHIBA. the fourth entry shows what appears to be the real thing. On their webpage EDIT>FIND "A15" to locate the CD.
There may be others in the 355 Google pages listed.
On the original factory disk gives a TOSHIBA Phone number, 1-800-457-7777, for support. I think they sell the disk for @$40.
good luck.
Dec 18, 2008 | Toshiba Satellite A15-S129 Notebook
Toshiba Satellite A15-S129 Notebook Logo
136 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
