Question about HP Pavilion N3410 Notebook
I Have an old HP pavillion model N3410. I am trying to access BIOS or change boot order but it won't let me. I've tried pressing f2 during reboot but it goes straight to normal windows me startup.Also tried pressing escape during boot but get the same results. This is an old machine but still works fine, I want to get into BIOS or at least change boot order so that I can install a Linux OS and get rid of the windows ME OS. Any suggestions on what to do? Will the default boot order read the cd-rom first or will I have to change it. How can I access setup?
    Brigadier General:
  • 10,406 Answers
Turn the computer off.
Hold down any key on the keyboard, and turn the computer on.
You might get a "keyboard error, press <something> to enter BIOS SETUP".
Also, instead of F2, try F1 or F10 or F11 or F12 or DEL.
Posted on Aug 20, 2010
Cd start server primergy b210 fujitsu siemens
In order to change the boot drive you have to change the boot settings in BIOS, or sometimes you can get a separate boot menu which allows you to change this setting on a one-off basis. During the boot sequence you need to press the "F12" button during the POST testing to bring up the boot menu if one is available, otherwise you need to press the "Del" or "F2" button during the POST process to bring up the Bios screens. Navigate to the BOOT option and alter the boot sequence, save the settings, exit BIOS and reboot.
Feb 18, 2014 | HP Compaq ProLiant ML110 G4 Server
D800 cannot change boot order
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart This will set the boot order If this fails you might try some of these Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Feb 05, 2013 | Dell Latitude D800 Notebook
How to change disk controller in bios on Toshiba Satellite A135-s2276?
Hello here is the homepage:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1596141&
You need this for the drivers.
And you can downlaod a manual
Press the "F2" key to access the Toshiba Satellite's BIOS menu. Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Read more: How to Change the Boot Order for a Toshiba Satellite ' eHow.com http://www.ehow.com/how_6383103_change-boot-order-toshiba-satellite.html#ixzz2Cn6HdU2k
Turn on or restart your computer and watch for a message during the post about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
Go to boot and select the boot order.Use F4 or F5 to change.
First boot device: Cd/dvd drive
Second: the harddrive.
Leave the bios and save the settings.
Place your windows cd in the drive and reboot.
Now you can install windows again.
Good luck
Nov 20, 2012 | Toshiba Satellite A135-S2276 Notebook
I tried to install windows 7 on my HP Pavillion DV9, but it's not booting from CD-ROM, i tried using a USB CD-ROM, but it's still not booting. pls I need assistance.
Try to check if the windows 7 disc that you are using is not just an upgrade disc. Make sure that it is a bootable disc. Try to use other bootable disc to test. Also make sure that the boot device priority is set CD/DVD drive.
Hope this helps.
Jun 06, 2011 | Computers & Internet
How can I change boot sequence in Compaq Evo N410c?
You need to access your BIOS configuration. 1. To do this, shutdown your computer and boot it by pressing the power button. 2. You need to hit F10 when the computer first powers up in order to get into BIOS (Note that the key is usually different for different computers. If F10 doesnt work, try F2, F12, Delete or F9. 3. Once in the BIOS, you should find the boot sequence option.
Hope this helps!
Apr 11, 2011 | Compaq Evo N410C Notebook
Compaq 6310US: Can't get into BIOS
you can try removing and replacing the battery on the motherboard. If that does not work, you will have to look for the reset jumper on the board.
May 02, 2010 | HP Compaq Presario 6310US (DA201A#ABA) PC...
Pc keeps rebooting and wont even go to safe mode
the os on the harddrive is not recognising the hardware and could be caused by change in bios settings or bad os.
Jan 24, 2010 | Dell Dimension 8200 PC Desktop
Entering bios setup
Occasionally, most computer owners will need to access BIOS on their computers in order to change or update the computer's most basic operations; such as memory and boot order.
Different computer manufacturers will have you press different buttons to access BIOS depending on the model you have. For example, on my laptop, I press F12 to enter the BIOS setup utility.
Here's how to figure out how to enter your computers BIOS setup utility. 1
Turn your computer on or shut it down and restart it if it is already on.
  • Step 2 As soon as the computer starts up, watch for a message that informs you about which button you will need to push in order to enter setup, aka BIOS.
  • Step 3 The opportunity to press the correct key to enter BIOS passes by quickly, so you need to find that key and press it before the computer moves on to the next stage of booting. If you miss your chance, just restart the computer and try again.
    You can always access BIOS, even on computers that dont have an operating system installed. This is because BIOS is part of your computer's motherboard hardware and has nothing to do with Windows, Linux or whatever operating system you may be using.
  • Dec 02, 2009 | Alienware PC Systems M7700 Notebook
    How do I Access BIOS screen in a IBM PII-6862-84U?
    As the computer boots press the DEL key to access BIOS
    note: some systems you must press F2 or Esc
    In BIOS under the BOOT tab options change the Boot order so that the CD drive is First
    Select EXIT and Save Changes to reboot
    note: make sure the CD is in the drive BEFORE you reboot!
    (it sounds obvious but a lot of people forget)
    If the CD is bootable it will start its own boot sequence.
    Feb 21, 2009 | IBM I System Board (61H2600) Motherboard
    Bios Access
    just press delete button to access bios settings not F2 and escape button.
    Jan 27, 2008 | HP Pavilion ze1115 Notebook
    HP Pavilion N3410 Notebook Logo
    139 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
