Question about GE WSXH208A Front Load Washer
Washer would not drian nor spin - GE WSXH208A Front Load Washer
No the solution is that the drain pump is dead and needs to be replaced open the front panel of the front loader and locate the filter and clean and also remove!!
Posted on Sep 30, 2012
  • GE Master
  • 17,129 Answers
Possible fault is the failure of the controller as the wash cycle and rinsing is OK. Hence the program is not advancing further due to error in the controller.
Suggest replacement.
Posted on Aug 20, 2010
What do i do when the washer starts to fill up and shuts off on me completely?
Drian water out place blocks under all four corners laying down w/flash lite inspect belts under washer.with it off try to spin tub. Trun nob to spin and c if tub turns
Jun 17, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer WTW5510VQO will fill, spin and drian but won't agitate, just makes a clicking noise.
If this is just clicking then the agitator bearings stuck or something is jamming it.
Jun 05, 2012 | Whirlpool Washing Machines
Will not spin or drian
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 17, 2011 | GE WBSR3140DW Top Load Washer
Washer won't drian
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Oct 04, 2010 | Kitchen Ranges
This washer wont spin but it dose drian
Most likely your motor coupling is busted.
part number is 285753A
May 17, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Zanussi washer washers,drians but will not spin
The transmission is belt driven so carbon brushes cannot be the issue. most likely it is a slipping or loose belt remove lower rear panel and check belt tension also check condition of the belt. In order to shift into spin there is a solonoid that activates the transmission you should be able to hear it click. if it just hums it may need replacment.
May 15, 2009 | Zanussi Washing Machines
Will not spin
It's the coupling between the motor and transmission.
This is a common problem and not an expensive part to replace. I can give you all the details if this is a DIY.
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Ge washer not draining or spinning
HI yes you can remove the pump and clean. the pump is the problem
Oct 12, 2008 | GE WBSR3140DW Top Load Washer
GE WSXH208A Front Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
