Question about iRobot 4150 Roomba Vacuum
The main brushes do not seem to be working very good anymore it clrans but doesn't do a good job
    Problem Solver:
  • 28 Answers
You will need to remove the gears cover from the cleaning head module and remove all debris found inside.
Posted on Sep 26, 2010
Brush inside main head doesn't spin, and stops spinning immediately after prompting it to spin. seems like the motor stop turning brush, however when i open main head and cover suction hole for a...
Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 13, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
My vacuum isn't cleaning/suctioning very well. The hose attachment will work and pick up debris but the main part of the vacuum (where the brush is) doesn't pick up. The brush only spins but there...
Check to see if the brush is turning when you have the vac on and the handel down 'of course keep your hands from that area when doing this ,you might have to lean the vac ,to see the resaults.
Jul 09, 2011 | Panasonic MC-V7582 Bagless Upright Vacuum
We are trying to replace the belt on the bissell 89q9 model. We purchased belt 8 and got in onto the brush however the brush doesn't spin anymore. Even trying to turn it by hand doesn't work. One...
Remove the beater brush assy & remove the
shaft & brgs that go through it 7 clean out the
hair,fuss ect,so it will turn
You need to take your vacuum apart once a year or more
to clean things so they continue to work
May 22, 2011 | Vacuums
My model F5906-900 --- problem is the brushes have stoped working... I pulled the brush assembly out by holding the two tabs, and all seems clean and the brush assembly rotates easly... onced the brush...
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
Mar 10, 2010 | Hoover F5906-900 Upright Steam Vacuum
Sebo Automatic X1 vacuum 'check brush' light on
I work in a Sebo agency, where we sell and repair Sebos - although they're so reliable we don't get that many to repair.  What's "automatic" about this machine is that it automatically adjusts the brush height so that it's ideal for whatever floor it's on.  It does that by sensing the amount of drag on the brush.  On a wood floor, there's much less drag than on a carpet, so the machine lowers the brush as far as possible to get the optimum drag.  After a while (4 1/2 years in your case) the brush has worn so far that the machine can no longer get it down low enough to brush the floor effectively. That's why the light comes on.  There's still plenty of bristle to do a good job on carpet but, if you want to do the best job on your wood floors too, you need a new brush roller.  Change the brush roller, and you'll probably feel the suction's improved too!
Any questions, just post a comment and I'll help if I can.  I value your feedback so please remember to rate this response.
May 04, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Spin brush not working anymore.
Is the shaft still on the brush block, if it broke off, then replace the block. if it is ok, then the turbine(#13) is most likely the problem. It is what drives the brushs. You may be able to take the turbine apart and clean it, if that doesn't work the replace it.
Mar 15, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Kirby Ultimate G will not suck with main brush head attachment
You may need a new belt, it may have stretched enough so it isn't turning the brush roll anymore.
Mar 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Doesn't seem to pick up little articles anymore
You have to turn the filter, there is a knob on the tank lid that you turn to help clean the filter. If the filter looks pretty clogged, then it needs to be replaced, or cleaned if it is one of the washable ones. You could have a clog in the hose, or down below where the brush roll is the inlet where the dirt first comes in. Is the brush turning? You may need to replace the belt and/or brushroll. Down in the noozle asm, there also is a vale that will open and close depending on the handle position, it may not be working so it seems like no suction when you do the floor.
Feb 16, 2008 | Hoover U5753-900 WindTunnel Bagless...
The brushes have stopped moving, what can I do? The machine still works, sucks etc. Just doesn's scrub anymore.
You should check the intake screen on the turbine. On some models it is located behind the glass window just above the circular indicator that spins with the brushes. On other models, it is located on the underside of the machine just behind the brush block assy. It is housed in a bright orange/red cassette that is only partially visible until you pull it out. This screen is responsible for keeping debris out of the trubine but will restrict airflow when clogged and the brushes will stop.
Otherwise, the bearings in the trubine may be rusted and siezed from water entering the turbine in which case, the turbine would have to be removed, dissmantled and repaired or in extreme cases, replaced. I have repaired many in my shop but some have to be replaced.
Nov 26, 2007 | Hoover F7222-900 SteamVac Upright Vacuum
iRobot 4150 Roomba Vacuum Logo
167 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
