Question about Xerox CopyCentre 133 Printer
XEROX display panel lights blinking and equipment wont work customer turns off and on then works for a page. then starts blinking/flashing again.
  • 229 Answers
<p>Problem</p> <br> Xerox CC 133, corrupted system. <br> <p>Solution</p> you have a bad <b>IIT unit</b>, contact Xerox in order to fix properly due theres nothing you can't do as user.
sorry
please rate my soution
Posted on Aug 20, 2010
Xerox color 550 has its control panel lights flashing, and printer wont start up
This http://forum.support.xerox.com/t5/Printing/7428-Shutdowns-All-Lights-Flashing/td-p/164967 says do this, carefully.... http://www.support.xerox.com/support/workcentre-7425-7428-7435/support/enus.html?objGUID=17471 good luck with that one. sounds a bit like the sort of issue an old hard drive might give you.
Oct 03, 2017 | Xerox Office Equipment & Supplies
Samsung DMT - 400 delicate light blinking
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Oct 02, 2012 | Dishwashers
I am on Dish Network...how do I set my Dish remote to turn on/off my Sharp Aquos 52E77UN televisiona
If you start this procedure and at any time do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again.
  • Press and hold the desired mode button (about three seconds) until all mode keys light up, then release.
  • Use the number pad buttons to enter the three-digit number corresponding to the equipment (026, 091, 105, 106, 107, 108, 128, 129). One of the three digit combinations will work. The light will blink off after each digit is entered and then return to a steady light.
  • Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
  • To verify the code works, try several functions for that equipment.
Jul 08, 2011 | Sharp Televison & Video
Outside temperature display on rear view mirror
Here are the instructions to reset flashing airbag light, the instructions are for an Armada but I believe it will work on all Nissan models of this period. It wont hurt to give it a try. If that doesn't work you may have a problem that should be looked at by your local Dealer.
1. Turn the key from off to on.
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
www.nissanhelpforums.com
Feb 28, 2009 | 2006 Nissan Altima
Xerox 3500 blank pages xerox 3450 display flashes
Clear all memory under maintenance will solve this
Feb 05, 2009 | Xerox Phaser 3450DN Laser Printer
Xerox Phaser 8560 display error
There is a known issue with that display. Call 1-800-835-6100 and tell Xerox you have a problem with the diaplay, They should replace it free.
Jan 26, 2009 | Xerox Phaser 8560MFP Laser Printer
Flashing green light
http://www.xerox-displays.com/drivers.html
This is the link to the xerox install info. This should fix the problem. If it does not please list the CPU OS and video card you have. Before connecting the LCD monitor make sure in your display properties are set to a refresh rate of 60 hertz. You can set refresh rate by going to the control panel in windows and display settings properties.
Jan 16, 2009 | Xerox XG-91D 19" LCD Monitor
Xerox Phaser 8550dt printer
That is a known problem with the 8500 phaser family.
Contact Xerox at 1-800-835-6100, They WILL replace it for free. It is a known problem.
I really believe that display is failing. very common problem.
Just tell them the display is blank when you call. But they are faulty. Very faulty.
Sep 21, 2008 | Xerox Phaser 8500/DN Printer
Xerox CopyCentre 133 Printer Logo
197 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
