Question about Moen Home
My Moen shower valves work so hard my wife can't pull them in and out
  • 85 Answers
I think the valves got rusted so it is hard to pull try to pore some oil to free it up if not solved plunber is needed
Posted on Aug 21, 2010
How to fix bathroom shower faucet
shut off water to shower, remove knob by popping cover off and removing screw, remove valve cover by just pulling straight out. there will be a retaining clip that holds cartridge in you will need to remove, Pull out old cartridge and replace with new.
Feb 21, 2014 | Moen 3175 Legend One Handle Shower Faucet...
Very difficult to pull faucet handle out to turn on in shower installation
the cartridge heeds to be replaced. It sounds like you have a moen shower valve. turning the stem on this cartridge will only reverse hot and cold. it will not fix your problem.
Sep 01, 2011 | Moen 3175 Legend One Handle Shower Faucet...
I have a single handle Moen shower faucet. Pull to turn on. Turn clockwise for cold. Turn counterclockwise for hot. It does not leak but it is hard as hell to pull out when I turn it on. The house was...
If it is hard to pull out or push in the valve then you will need to replace it. On moen valves you can not rebuild the cartridge you can only replace them. A new cartridge will cost you around 15 to 20 dollars.
Also I would tack the cartridge with you when you gao and buy it because they make 2 different ones.
Good Luck and please rate 4 thumbs up for the free answer
Sep 21, 2010 | Moen 3175 Legend One Handle Shower Faucet...
The moen shower pullout type hot/cold valve will not slide out of the main valve body even after the retainer clip has been removed. I found some corrosion on the retainer clip and I have sprayed the area...
Howdy, those can be like pulling teeth. The wd40 will not help that much as it is not a robust solvent. I suggest letting some liquid wrench sit overnight on it and then pulling real hard. Good luck:)
Regards,Farmerbear
Aug 31, 2010 | Moen Home
The shower control valve for my moen 2995 faucet is stuck in the shower position. how do i remove it?
Turn off water main. remove round cap on face of handle, remove screw and pull handle. After that everything else can be pulled off easily. When you get to the diverter you should be able to why its stuck.
Sep 27, 2009 | Moen 2995 Chateau Three Handle Tub and...
Moen one handle tub & shower is leaking from spigit
A stem is a cartridge in a real old valve. You have pulled retainer clip, you can try to pull it out with pliers, but you might need a moen cartrigde puller.
Sep 06, 2009 | Moen & One Handle Tub & Shower Faucet
Single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Feb 23, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Home Logo
62 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
