Question about Dell 926 All-In-One InkJet Printer
No problem. I just don't know how to open it to change the cartridges.
  • 369 Answers
How do i change the cartridge ?
901 is the cartridge what is the printer model?
Jan 31, 2015 | HP Two 901 Black ink cartridges
I changed a toner cartridge and now it is not alligned and I don't know how to allign it. I have an HP CP2025 and I have tried doing the cleaning and printing the test pages. I don't know what to...
Calibrate the product
Calibration is a product function that optimizes print quality. If you experience any print-quality problems, calibrate the product.
1. Open HP ToolboxFX.(in your PC)
2. Click the Device Settings folder, and then click the Print Quality page.
3. In the area for Color Calibration, select the Calibrate Now check box.
4. Click Apply to calibrate the product immediately.
Jul 10, 2011 | Office Equipment & Supplies
I have to get a letter typed and don't know how to open the machine to change the ink????
  1. Open the cartridge access door. Figure 4: Open the cartridge access doorc00127636.gif
  2. Raise the cartridge latches for both cartridges. Figure 5: Raise cartridge latchesc00127637.gif
  3. Remove the protective tape from the end of the cartridges. Figure 6: Remove tapec00127639.gif
  4. Insert the cartridges into the carriage. Figure 7: Insert cartridgec00127642.gif
  5. Close the latches, and then close the cartridge access door. Figure 8: Close latchc00127644.gif The control panel displays a message prompting you to align the cartridges.
  6. Press the Enter button to start the cartridge alignment. Wait until the alignment completes before continuing.
Jun 24, 2011 | HP PSC 750 All-In-One InkJet Printer
Don"t know to change the toner it was donated and
There are usually picture instructions on the Canon toner box. But here it goes - Gently shake the toner cartridge to break up the fine toner powder. Then open up the front door, the you should see a blue handle on the right side, rotate this in the counter clockwise direction. The Developer should move to the right and gently pull this out as far as it will go. Put the toner cartridge on top of the developer assembly and gently push down until it locks in. You will have to angle the rear facing end of the cartridge so that it slips into a slot. When the cartridge is lock the tab should break away. Before pulling this tab away from the copier lift up on the cartridge to guarantee that the cartridge is locked into place. You don't want to pull the tab until locked because you will have abig mess to clean up. The tab will open up the developer unit and the toner will drop inside. The you close up the slide and at the end of this procedure you may have to place a thumb on each side of the slide and fingers on the blue finger catches to fully close the developer unit. The cartridge should release and then remove the empty toner cartridge. Throw it away, return the developer to its normal position, close the front cover.
Jun 20, 2011 | Canon imageRUNNER 2200
Changed toner---back side now prints dirty with band on the top. Did the cleaning procedure - no luck
If you changed toner because old was empty and now you have this defect with the new cartrige, it is most likley a defective cartridge. Try the old cartridge again, if it prints clean, then you know for sure it is the cartridge. If you purchased a new HP cartridge, get it replaced by HP, they warranty their toners against defects. If you bought a 3rd party toner, return it to where you bought it and get them to replace it. If you had your old toner refilled by someone, get your money back, they don't know what they are doing. This type of defect is often caused by a filled waste toner bin then then runs back out when you print. Some refillers just throw toner in and don't empty the waste toner bin.
Jun 07, 2011 | Office Equipment & Supplies
Hi, i cant find where to change my ink cartidge for my canon pixma MP480 printer
just open the cover on top catridge will come to center and remove it.
just open the cover .when you open the cover cartridge will come to center just pull all the cartridges one by one don’t make pressure too hard it will come easily if you put more pressure and try to removing it and it is not come out then don’t do it may be you doing wrong . let it be and take help from some one who using printer and know how to fix the cartridges.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | Canon Pixma MP480 All-In-One InkJet...
Replace ink cartridge
Have a nice day and do not forget to rate please...!
Feb 16, 2010 | Epson Stylus DX4450 All-In-One InkJet...
I need help removing an empty ink cartridge from canon mp480 printer
Feb 15, 2010 | Canon Pixma MP480 All-In-One InkJet...
Wrong Colour Cartridge Available
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Nov 05, 2009 | Epson Aculaser C1100 Printer
Black will not print
Hi springfield, From what you describe I don?t think it has anything to do with your printer drivers. I would try the following: -Run a couple of nozzle cleaning jobs. -If no change I would suspect a defective cartridge and would try a brand new HP cartridge. If these don?t work I?ll need some more details such as do you refill cartridges, buy remanufactured cartridges or use new HP. Also is this still under manufacturer?s warranty? I don?t want to suggest anything that would void it. Let us know what happens and please don?t forget to rate the posting.
Jan 23, 2007 | HP LaserJet 3300mfp All-In-One Printer
Dell 926 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
