Question about Kirby G6 Bagged Upright Vacuum
My kirby sentra won't **** up anything. I've changed heads and bags to see if something was stuck inside but couldn't find anything.
  • Kirby Master
  • 17,129 Answers
Your inferance proves that the fault could be with the vacuum pump. Since the rest has been checked and there is a drastic reduction of the suction rate of the pump, I think the motor must be checked. Please remove to see if there is accumulation of dirt in the motor or the rotary vanes. If there is a shift in the position or wearing then the suction can reduce. Make sure that the vanes sweep very closely and there is no gap with the sweep. If the motor bush/bearings are faulty, the suction can be reduced as there will be loss in vacuum produce.
So check this out to confirm the fault.
Posted on Aug 20, 2010
Kirby G2000 how do you get the head off to check for clogs
HI Linda,
The G2000 kirby is the same procedure as the G5 Kirby. As it happens I put a solution up on YouTube showing how to change the belt and to do this you need to take the head off. Long story short if you watch my video you will see how to take the head off. If you need anything for your Kirby like kirby bags or kirby Belts just visit VacuumSpot
Dec 03, 2012 | Vacuums
Kirby G4 plugged in won't come on? Is there a reset button and where is it?
There is no reset on a Kirby. Remember that the motor will not run unless the bag assembly and vacuum head (or hose) are fully in place. If this is not the problem, the most likely causes are either a bad cord, a bad switch, or a worn or stuck carbon brush in the motor.
Apr 16, 2011 | Kirby G4 Bagged Upright Vacuum
Kirby g2000 not picking up dirt
It is most likely the belt. You cannot reverse the suction. First check to see if the bag is expanding when running. If the bag is blowing up then it is the belt if not it is clogged just take the bag off from the vacuum and remove the head you will see the obstruction.
Dec 16, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby generation 3 won't vacuum. It runs and
You may have suction but if the belt is worn the roller brush won't spin and therefore won't pick up anything. You can get a replacement belt here:
http://vacbelts.xps.convina.com/kirby-301291-belt.htm
Oct 10, 2009 | Kirby Generation 3 Bagged Upright Vacuum
My Kirby G3 makes a loud, high pitch whistle with the hose
I would say you either have something stuck on the impeller or there is a piece of paper or something stuck inside the hose. its not clogging the hose but when the air passes by it. It is making that noise. If you find nothing you may need a repair. May have a bad bearing in the motor. Actually you can also try inspecting the brush on the head. It removes easily from vacuum and should spin freely and quietly.
May 04, 2009 | Kirby G5 Bagged Upright Vacuum
How to use my kirby carpet cleaner
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=541258
Generic problem for all Vacuums
How to use my Kirby
Posted by rnelson510 on Apr 24, 2008
How to use my Kirby carpet cleaner?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This is kind of a general question and I will try to explain the best I can. Most Kirby’s have a vacuum head and sometimes a shampoo head, the vacuum head is removable on most Kirby’s and the vac head comes off the front for a brushroll and belt change. When you vacuum and you go to adjust the vacuum head, raise the height adjustment all the way u to the top with your foot, then listen to the tone change, @ first you will hear air pulling thru and the brush has not hit the carpet as of yet, that is the sound the you are listening for, once the brushroll hits the carpet – there is a definite tone change and that is when you have it adjusted correctly, try to vacuum with it set that way, if it is picking up well – you’re OK, if not adjust if down one more click. Also remember to do a belt change every 4 to 6 months for good cleaning, change the bag more often because it will pup better with a new belt and bag, or if you don’t have a paper bag, take and scrape the inside of the cloth bag with the scraper provided in the small zipper section. Please refer to the owner’s manual or trouble shooting guide or to your local vacuum cleaner dealer or in the yellow pages, also you can use the Kirby factory or website listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Vacuums
Kirby G6 Bagged Upright Vacuum Logo
101 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
