Question about Garden
Tecumseh model lev120 195 cc will start and run but has no power when under any load acts as if it runs out of gas put new carp parts no difference Thanks
  • 24 Answers
Sounds like your govenor is out of adjustment.
Posted on Aug 20, 2010
Act like it is flooding out at high rpm
try cleaning the air filter as it is probably blocked
Jul 13, 2014 | Briggs AND Stratton Intek Briggs &...
5 hp tecumseh no power
you need to remove carb for cleaning... if it has an adjustment on the bottom of carb try turning it SLOWLY in and out... also possibly a screw on the side under a black cap... might try it as well engine model number would help here
Dec 11, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
I need a free diagram of a tecumseh carburetor 5TPXS.3582AA Spec. 206915F
You can find a free diagram at www.sepw.com, use the part number of the carburetor as a model number under tecumseh brand lookup. Your carb part number is 640065a.
Jul 12, 2013 | Garden
Tecumseh back fires but does not run
Have you checked to make sure the flywheel key is not sheared? If sheared it throws off the timing and will backfire when you try and start it. Somewhat common on those engines. If you have the engine model number I could look up a parts diagram to better answer the carb question.
Aug 19, 2012 | Tecumseh Garden
Our HMSK 80-110 electric start snowblower starts up right away, but the idling is very rough. It runs very smoothly when it is engaged in snow throwing.
The Tecumseh snow motors are notorious for idling rough. Especially the last few years of production. Most service techs just say "live with it" But there are a couple of things you can do to help.
It is not a carb adjustment issue. It's usually a fuel, clean carb issue.
First, use a premium grade fuel without ethanol and a fuel stabilizer. This will give you the best fuel mix.
Second, Remove the carburetor shield and clean the inside and outside of the carb with carb cleaner. Even though you can't see the carb usually, they do get varnish build up and cleaning it will help some.
Third, Put the recommended amount of fuel system cleaner in the gas. I use Sea Foam brand. Over a tank full or two you will notice a difference in how the engine idles.
Fourth, Use a high quality spark plug and use a new one every year. Make sure the gap is correct.
Good Luck! Feel free to as any other questions you may have. Don't forget to rate this answer!
Jan 14, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Won't stay running
Check the gas cap vent. A partial vacuum in the tank will cause these symptoms.
Sep 06, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Generator hard to start and backfiring
Sound like you've done things in the correct order, tecumseh's are notorious for carb problems if you let as sit in them. Backfiring is timing related (flywheel key) or valve problems. I would take a closer look at the exhaust valve I don't believe it is closing all the way.
Mar 16, 2009 | Coleman Powermate Powermate 5000W...
Hard to start and backfires from muffler when running
Sounds like the timing may be off or maybethe exhaust valve maybe hanging open.
Mar 15, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh Snow King HS40 engine only runs on full choke, no power
i did and thanks - just picked up one that does the same thing and i plan to take your advise
Thank you Jerr
Jan 01, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
194 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
