Question about Kenmore 24 in. 17032 Built-in Dishwasher
KENMORE DISHWASHER STUCK IN WASH CYCLE it will not move off of this postion water heats up it cleans but does not move off this cycle.
  • 2 more comments
  • Anonymous May 03, 2008
    Same exact conditions - washer gets stuck in wash cycle (after 25 minutes, I aborted the cycle and sent it through a rinse cycle. Water appears to heat, cut "heat" indicator remains lighted indicating "heating". TUBE MANIFOLD part # 3379644 for model # 665.15835790 has deteriorated with holes in bottom of manifold causing supply water leakage to lower rack area. Dishwasher is 10 years old.
  • Carl P May 19, 2008
    Kenmore dishwasher stuck in wash cycle. Won't move on to next cycles.
  • Anonymous Jul 28, 2008
    I just had my kitchen remodeled and never had a problem with the D/W until they put it back and reconnected it. First, the clean light was flashing and I did the sequencal thing that everybody posted and it seemed to work. So, I tried running the dishwasher today and it seemed to be stuck in the wash cycle. I too after a long time, aborted the cycle and drained it. It's only about 3 yrs old so I'm wondering if moving it and reconnecting it has something to do with the malfunction of it? I hate to waste money on a service call if it is something simple.
  • ogulin123 Dec 13, 2008
    I have the same problem. as described before get stuck in wash cycle and doesnt move to nextone.
    Thank you in advance for any help.
SOURCE: Stays in wash cycle Whirlpool Dishwasher Du1050SS
my repairman contacted whirlpool about my washing machine staying on
wash.. to his surprise.. and mine.. and his co=workers.. this is the answer,
it worked.. and we have never heard this before.
In your original istallation booklet it tells you to let the dishwasher run til its complete
the first time you use it as it may rinse twice... my original installation man told me this also.
however.. if you suffer a "blip" in your electricity.. it could put the little dishwasher "brain"
out of whack.. it can run as long as 3 to 4 hours on wash to reset itself.. if you stop it
(like others have mentioned.. and which I did also).. it doesn't complete the reset and it
will attempt to do it the next time..
answer?.. just let it go once as unnerving as this is.. it works.. They did mention that
if it went to 5 hours.. call your repairman because you need a new mechanism.
karen in Dothan
Posted on Apr 03, 2009
SOURCE: Dishwasher Kenmore Ultrawash
One possibility is that the screen/filter to the wash units have become totally clogged. (I had this problem because of some particularly dirty water in the dishwasher.) To access the screen requires taking out the cover at the base of the dishwasher arm assemble which can be done without removing the machine, although you'll need a special screw spline screw driver. Given this the repair takes jsut five or ten minutes. Remove the screen clean it out in the sink and replace.
Posted on Feb 10, 2008
SOURCE: K-more elite dishwasher stuck in sensing mode; won't move to wash
Where did you find the sequence to clear the flashing clean light?
Posted on Apr 14, 2009
SOURCE: Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
Posted on Apr 21, 2009
SOURCE: Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Posted on Sep 04, 2009
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Kenmore ultra wash dishwasher gets stuck at 42 on the control panel
Be aware that all (well, almost all) dishwashers have a "thermal hold" period in their cycles. This is the point in the main wash cycle where the heater is turned on to heat the water to the optimum wash temperature (about 150 to 160 deg F), and during this time, the timer will stop advancing. Once the water has reached the desired temperature, the cycle will continue. IF it does not, then you have a water heating problem. This could be caused by a bad heating element, a bad controller, a bad thermostat or temperature sensor.
Mar 20, 2015 | Kenmore Dishwashers
Dishwasher will operate only 10 min before stopping cycle
Check for places food could get stuck and clog the workings, including the drain hose.
Nov 24, 2013 | Kenmore 24 in. 16302 Built-in Dishwasher
Water does not enter dishwasher during wash cycle
Make sure the under-sink valve is turned on. Then suspect the water solenoid valve under the front may have an open coil or stuck shut valve.
Dec 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Dishwasher 587.15163401 knob stuck mid-cycle
See if it is stuck on a water heat cycle. if the heater circuit or the thermostat is not working properly it will continue to run looking for a rise in temperature. If these are in working order the timer it self could be sticking and not advancing.
Oct 23, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
The dishwasher is not cleaning the dishes at all, so far I have done the following: Checked both sprayer arms and they move freely and do not appear to be clogged (I ran stiff wire thru holes in each The...
Heating element may have burned out. Check water temp during wash--should read between 130 to 140 F.
If not the heating element,you may have to replace pump-motor assembly or wash impeller.
Hope this helps.
Aug 12, 2009 | Kenmore Dishwashers
Kenmore dishwasher stops midway through
Here is a good page that can help you resolve this issue and buy the parts needed
Feb 14, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Cycle stops, won't drain
This is either a bad timer or a bad heat sensor. On most cycles that call for the water to be heated it will pause the timer and continue washing/heating until the sensor is satisfied the water is hot enough. Try selecting a quick, delicate, or china cycle without heated rinse or dry. If it works this way the timer is fine but the sensor is bad. Sometimes cold water to the machine will cause this problem because the machine is not capable of totallly heating cold water. It is only designed to boost the temp. Make sure you run hot water at the sink before you start the machine.
Jul 03, 2008 | GE Nautilus 24" Built-in Dishwasher
Kenmore 24 in. 17032 Built-in Dishwasher Logo
964 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
