Question about Stanley Air Tools & Compressors
Have a n80sb. not hearing any air leaking. sometimes will shoot a nail and sometimes nothing happens when trigger is pulled.
  • 4,234 Answers
If the plunger has not fully retracted after the nail has been fired, this can happen. Try lubricating the unit. It is possible that there is a leak in one of the Orings as well. Check the site below for a complete parts breakdown diagram that should be helpful.
Dan
Link: http://www.ereplacementparts.com/bostitch-parts-c-29443.html?gclid=CMzYk82-z6MCFUmA5QodV1g7vQ
Posted on Aug 23, 2010
Freeman PFN1564 shoots air when you disengage safety and pull trigger
if you mean it only shoots air when you pull trigger and not a nail , disconect from air supply and open side of nail mag. (two screws on side) look for forign object in front towards head end , sometimes the paper that nails are wrapped in gets stuck in there , also there is a small spring metal clip at front of mag is this broken off and is unusually short ?
Sep 22, 2014 | Freeman 15 Gauge 34 Degree Angle Finish...
I think it is leakin air thru the trigger what would cause that
If air is leaking from the trigger, check vinyl ball and oring on the white plastic firing pin. If air seems to leak from the plunger just in front of the trigger (with air connected and nails removed move plunger with finger and listen for change in sound), remove the head and pull out the cylinder. The outer oring to the plate around the cylinder is bad, however, clean the cylinder and lube with white grease. Good luck
Feb 03, 2013 | Hitachi NV45AB2 Roofing Coil Nailer
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
Bostitch N80SB won't reset after firing
Most likely just needs piston oring. Remove nails from the gun and point nose of gun up then down again. If the piston travels up and down in the cylinder, replace the oring. The piston returns to top with air pressure and needs good snug piston oring and good lower bumper (if bumper is cracked or missing pieces ~ replace ). Be sure to lube the orings in the headvalve with silicone paste or white grease. Part # ORK11 oring kit will reseal the gun. Good luck with your repair.
Jun 02, 2012 | Stanley Air Tools & Compressors
I have a N80SB stick nail gun that have been leaking air from the trigger valve but was still able to shoot nails. After 3 months of discontinued use, I plugged in the air hose and fire the first nail
A new trigger valve and o-ring kit will give you a like new gun. Just remember to replace all available o-rings in the kit, lightly grease all of them as you reassemble the gun and use pneumatic oil at the beginning of the day so you won't be doing it again in a couple months.
Feb 23, 2012 | Stanley Bostitch Stick Framing Nailer...
Porter Cable FN250c wont shoot with every trigger pull. sometimes it shoots correctly (10% of the time), other times it just pops (no nail) and other times it shoots two nails at once. Also when it...
Worn trigger and or worn firing valve. Remove the trigger and look for wear on contact surfaces (worn pin that holds trigger, worn inner lever inside trigger, worn or loose firing pin in valve ). Easy test for worn trigger. Remove the nails, remove trigger, fire the gun against wood with finger to test for proper action. If it works better without trigger, consider replacing trigger with new (I would also order the oring repair kit that includes the firing valve )
Jul 26, 2011 | Porter Cable-Cable FN250C 1-inch...
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
I have a hitachi nv 65 ah that will shoot two nails at time
I hope this doesn't offend you. What I'm suggesting is that you may not be using your nail gun correctly. Some people keep the trigger pulled and bounce the gun onto the wood. This technique works okay, but placement accuracy of the nail suffers. The other technique is to place the gun on the wood and pull the trigger USING TWO HANDS! This is the technique suggested by the manufacturer. The problem with this technique is that if you apply insufficient pressure to the gun (USING ONE HAND) the safety is not engage so you don't shoot a nail. What usually happens - I just witnessed this a couple of weeks ago - is that not enough pressure is applied while pulling the trigger so you push harder and end up bumping the gun which shoots a nail - because you have the trigger pulled, but the nail shot was a surprise so it causes another bump (and is more apt to bounce because you're using just one hand). Because it is a machine and can operate faster than your reflexes - it shoots another nail. This happens before you can lift it off of the wood, or remove your finger from the trigger. That's the reason I keep the trigger pulled and bounce it. I know that after the bounce I've set a nail, and can remove my finger from the trigger. When I need to accurately set a nail I always use two hands, press hard and pull the trigger, and release quickly. Only pull the trigger when you know you're about to set a nail, and are poised above the workpiece.
Dec 09, 2009 | Air Tools & Compressors
N80sb-1 stanley bostitch framing gun.
Yes your nailer will drive other sizes of nails. For info and parts go to www.bostitch.com and look for the support tab then select service parts. Here you will find parts list and manual. To remove the tva11 trigger valve remove the retainer pin (the pin is 3mm) for the trigger and remove trigger. Next remove roll pin/pins that retain trigger valve. Use heavy glove to catch trigger valve as you apply air pressure to gun. The valve could pop out with great force so try lowering the pressure to gun. Before installing the new valve, check the opening for sharp edges which will cut orings. Good Luck and email if you have more questions.
Mar 14, 2009 | Stanley Air Tools & Compressors
Air Tools & Compressors Logo
393 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
