Touchpad off - Computers & Internet
    Sergeant:
    Champion:
  • 233 Answers
You can find a small button on the touchpad, make sure that it is turned on. If it is turned on and still the touchpad is off, then the issue might be with the corrupted touchpad drivers. We can try by reinstalling the touchpad drivers
Visit the below link for more information
http://notebook-solutions.blogspot.com/2009/07/how-to-uninstall-and-reinstall-touchpad.html
Posted on Aug 20, 2010
Charger causing cursor jump
AnswerMake sure you're not touching the touchpad
Because the touchpad often is close to where the palms of your hands and thumbs lay, it's possible that you may be touching the touchpad without realizing it. An easy way of determining this is to see if the cursor moves without touching anything on the keyboard.
Dirty touchpad
Oils, lotion, and other substances from your fingers can cause the touchpad to not work properly. Make sure the touchpad is clean by dampening a cotton cloth with water and rubbing the touchpad surface.
Disconnect other external input devices
It may not be touchpad that's causing your issue. If you have other input devices such as an externalmouse, graphics tablet, keypad, etc., try disconnecting these devices to make sure they're not the cause of your issue.
Disconnect from docking station
If your laptop is only encountering this issue while connected to a docking station, it could be the cause of your issues. For this issue we suggest the below solutions.
Update drivers
Because the drivers control how the touchpad interfaces with the operating system, if the drivers contain issues, any number of problems can occur. Including the cursor moving improperly. Make sure you have the latest drivers from your laptop manufacturer for your touchpad either by visiting their website or contacting their support.
Try a third-party utility
Download and install Touchpad Blocker, a fantastic free program that can be used to help prevent any mistaken touchpad movements.
Bad hardware
If you've completed all the above steps and continue to have issues with your touchpad, it's possible you may have a physical hardware issue either with the touchpad or interface connected to the touchpad.
If your laptop is out of warranty and you do not wish to spend the money it takes to repair the laptop, we suggest disabling the touchpad and using an external USB mouse. Many touchpads can be disabled by pressing a button above or around the touchpad.
Additional information
Sep 10, 2013 | Computers & Internet
Cursor problem
Disabling the touchpad on a Dell Inspiron can be useful when typing for long periods of time, or using an external mouse. Bumping or tapping the touchpad while typing can cause cursor jumping and unwanted results. Use the touchpad software to enable or disable touchpad controls. Download the driver for your touchpad at the Dell Support website.
Click on the "Touchpad" icon in the task bar. If the icon doesn't appear, you can download and install the driver for the touchpad from the Dell website, or choose "Start" and "Control Panel." Choose "Device Select" on the touchpad menu, or choose "Mouse" in the "Control Panel" menu and "Device Select." Click "Disable" under "Touchpad" to turn off the touchpad, or click "Disable Touchpad/Pointing Stick When a USB Mouse is Connected."
h
Feb 28, 2013 | Computers & Internet
Laptop touchpad not working
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 09, 2012 | Toshiba Computers & Internet
Touchpad not active
hope this helps
Sep 05, 2012 | Computers & Internet
Where is the touchpad lock on the Hp probook laptop.
Hi.
Turn off the touchpad Most HP notebooks come with an on/off button near the touchpad. If you do not wish to use the touchpad at this time, press this button. Press it again when you wish to use this accessory again. If the notebook does not have an on/off button for the touchpad, touch and hold the top-left corner of the touchpad for approximately 5 seconds to disable it and do this again to activate it. When the touchpad is disabled, a small light will illuminate on the touchpad and an icon will appear briefly of the touchpad with a line through it. When the touchpad is activated, a small light will turn off on the touchpad and an icon will appear briefly of the touchpad. Alternatively, if the notebook does not have an on/off button for the touchpad, and you wish to turn the touchpad off, open the Mouse Properties window, select the Device Settings tab, and click the Disable button. You may re-enable the touchpad from here at any point.
Regards.
Sep 05, 2011 | HEWLETT-PACKARD ProBook 4520s Notebook
I can not unlock my TouchPad.
You might have disabled the touchpad accidentally. If the touchpad is disabled it is indicated by a yellow LED on upper left corner of the touchpad and when the TouchPad is active, the light is off.
To turn the TouchPad on, quickly double-tap the TouchPad off indicator (the yellow LED).
Hope it helps!
CreativeTECH
Jun 27, 2011 | HEWLETT-PACKARD ProBook 4520s
How to enable touch pad operation in ubuntu 10.04
Ubuntu provides configuration of the most common touchpad options in System > Preferences > Mouse, under the Touchpad tab.
Try the touchpad after unchecking the Enable mouse clicks with touchpad check box.
Check operation after Enable horizontal scrolling is checked. This may not have been the default setting.
Disabling Touchpad while Typing
  • Go to System > Preferences > Mouse > Touchpad and uncheck 'Disable touchpad while typing' and 'Enable mouse clicks with touchpad'
Feb 15, 2011 | Dell F3534 Touchpad
My touchpad buttons do not work
hi locate the FN key on lower left side of keyboard next locate the touchpad key usually one of the F1-F12 keys,press and hold the FN + the touchpad key together and release, now check the touchpad.
good luck,
let me know how it turns out.
ken
Apr 04, 2010 | Dell F3534 Touchpad
Quickplay touchpad above keyboard
The following illustration and table describe the computer TouchPad.
(6)
TouchPad on/off button Enables/disables the TouchPad.
Component Description
(1)
TouchPad light Blue: TouchPad is enabled.
Amber: TouchPad is disabled.
(2) TouchPad* Moves the pointer and selects or activates items on the screen.
(3) Left TouchPad button* Functions like the left button on an external mouse.
(4) Right TouchPad button* Functions like the right button on an external mouse.
(5) TouchPad scroll zone* Allows you to scroll up or down.
(6) TouchPad on/off button Enables/disables the TouchPad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 08, 2009 | HP Pavilion dv9000z Notebook
HP NC6400 touchpad
Hi i am an ex HP employee
here are the steps
Remove the TouchPad Assembly
  1. Remove the T8-9 mm screw that secures the TouchPad assembly to the base enclosure.
  2. Turn the notebook right side up and open the display panel fully.
  3. Lift the rear edge of the TouchPad assembly and remove it from the top cover.
  4. Disconnect the TouchPad cable from the system board.
  5. Remove the TouchPad assembly from the notebook.
Replace the the TouchPad Assembly
  1. Place the TouchPad assembly over the palm rest.
  2. Reconnect the TouchPad cable to the system board.
  3. Toe the front edge of the TouchPad assembly into the top cover and lower the rear edge into position until it snaps into place.
  4. Close the display panel and turn the notebook upside down.
  5. Replace the T8-9 mm screw that secures the TouchPad assembly to the base enclosure.
I hope it works out
Jun 04, 2008 | HP Compaq NC6400 Business Notebook
Computers & Internet Logo
782 people viewed this question
David Payne
David Payne
