Question about Microsoft Comfort Curve 2000 Keyboard
W key not working
Hello! I have quite a problem with my Microsoft keyboard: my "w" key is not working anymore (I am writing this after having copy/pasted a w letter from an e-mail...). I kinda need that key and I wouldn't want to buy a new keyboard only because of this. It's a really good keyboard.
I haven't spilled any drinks on it. I tried to clean it a couple of days ago but I don't know if it has something to do with it. A friend told me to open the keyboard and clean it inside but I don't want to damage it even more.
Can you help me please?
Thank you!
Apparently whatever the manufacturer is using for a conductive material reacts with the air to form an oxide or film that interferes with conductivity. This is not a permanent solution to an engineering problem. I have several times taken the keyboard apart (little screws on the back), removed the bubble plastic layer, pealed back the layers and then wiped the "electrical key contacts" with a cotton cloth dampened with isopropyl alcohol. Put it back together and problem fixed-- for a while.
I think i've worn enough of the very thin material off that I can't do that anymore. Which is why I ended up here. Good luck.
Posted on Jan 20, 2009
F12 function key doesn t work
Function keys are special keys used for assigning program shortcuts and specialty tasks to the keyboard.
They are located at the top of most keyboards and labeled "F1" through "F12."
Some keyboards may only feature 10 function keys, while others may have as many as 18. These keys often go unutilized by the average computer user, but they may have very important tasks for some users, which can lead to problems when the keys do not respond.
Fixing nonresponsive or malfunctioning function keys is quite simple, and should only take a few minutes.
Connect your keyboard to your computer, and power it up.
Open a program that uses the function keys such as Microsoft Word or Microsoft Excel. Check your keyboard for an "F-Lock" or "Function Lock" key.
This key is used to toggle function-key support; when it is toggled on, the function keys will not work.
Press the "F-Lock" key and then try using a function key in the selected program. "F1" is a good key to test, because it is set to open a "Help" document in all Microsoft software.
If the key does not work, press the "F-Lock" key a second time, and test the keys again.
If the keys still do not work and you are running the Windows 7 operating system, you may need to install a "hotfix" from Microsoft to fix the key functionality.
Navigate to the link entitled "Microsoft Support: Some Function Keys do not Work Correctly." (See Below.)
Some function keys or keyboard shortcuts do not work correctly on a computer that is running Windows 7
http://support.microsoft.com/kb/975741
Resolve unexpected Function (F1 - F12) or other special key behavior on a Microsoft keyboard
http://support.microsoft.com/kb/894513
Click on "View and request hotfix downloads" located beneath the title of the article to access the Microsoft Hotfix database.
Agree to the terms and conditions, then download the hotfix.
When the download is finished, run the downloaded file and follow the on-screen instructions.
You may need to restart your computer after the installation is complete.
Your function keys should now work properly.
Jul 14, 2013 | Dell Computers & Internet
My fn button wont work
Jun 27, 2013 | Packard Bell Computers & Internet
Why wont my fn button
My Samsung laptop's (np-r430-jb01ae) function keys are not working. how could i solve it?
Step 1:
Function keys are special keys used for assigning program shortcuts and specialty tasks to the keyboard. They are located at the top of most keyboards and labeled "F1" through "F12." Some keyboards may only feature 10 function keys, while others may have as many as 18. These keys often go unutilized by the average computer user, but they may have very important tasks for some users, which can lead to problems when the keys do not respond. Fixing nonresponsive or malfunctioning function keys is quite simple, and should only take a few minutes.
Connect your keyboard to your computer, and power it up. Open a program that uses the function keys such as Microsoft Word or Microsoft Excel. Check your keyboard for an "F-Lock" or "Function Lock" key. This key is used to toggle function-key support; when it is toggled on, the function keys will not work. Press the "F-Lock" key and then try using a function key in the selected program. "F1" is a good key to test, because it is set to open a "Help" document in all Microsoft software. If the key does not work, press the "F-Lock" key a second time, and test the keys again. If the keys still do not work and you are running the Windows 7 operating system, you may need to install a "hotfix" from Microsoft to fix the key functionality. Navigate to the link entitled "Microsoft Support: Some Function Keys do not Work Correctly." (See Below.) Some function keys or keyboard shortcuts do not work correctly on a computer that is running Windows 7 http://support.microsoft.com/kb/975741 Resolve unexpected Function (F1 - F12) or other special key behavior on a Microsoft keyboard http://support.microsoft.com/kb/894513 Click on "View and request hotfix downloads" located beneath the title of the article to access the Microsoft Hotfix database. Agree to the terms and conditions, then download the hotfix. When the download is finished, run the downloaded file and follow the on-screen instructions. You may need to restart your computer after the installation is complete. Your function keys should now work properly.
Feb 25, 2013 | Computers & Internet
Hello I can't write some letters with my keyboard.for example "f" "r" and others.I press this buttons but nothing is not writing on wall(or Word) I use keyboard 2years.
Hello Aqhala,
If the Genius SlimStar C100 Keyboard Keys is not working then you can use the On Screen KeyBoard from the Accessibility in Windows Vista or Ease of Access in Windows7. You have to replace it with new keyboard.
Also visit the link provided below :
http://www.microsoft.com/enable/products/windowsvista/
http://www.microsoft.com/enable/products/windows7/
Jun 15, 2011 | Genius SlimStar C100 Keyboard Mouse...
I have problem with my keyboard, all the simbols can not appear in its respectivly key. I mean that if I write a symbol the lap writes another one
Hello.
Give this a try (from Microsoft Support):
  1. Click Start, point to Settings, and then click Control Panel.
  2. Double-click Regional and Language Options.
  3. Click the Languages tab.
  4. In the Text Services and Input languages pane, click Details.
  5. In the Installed Services pane, click any keyboard listed other than US, and then click Remove.
  6. When the confirmation message appears, click Yes.
  7. Repeat step 5 until all listed keyboards except US are removed.
Hope this helps.
Jun 25, 2010 | Computers & Internet
The volume control buttons on the left side of my keyboard don't seem to be working. Any ideas about how to fix that problem?
Article ID: 932875 - Last Review: December 30, 2009 - Revision: 6.0 Resolve Hotkeys or Volume control keys not working on Microsoft keyboardshttp://support.microsoft.com/kb/932875
Worked for me Model 1031 Microsoft Digital Media Pro Keyboard
1-11-10
Dec 20, 2009 | Microsoft Digital Media Pro Keyboard
On my apple keyboard the caplock and shift key won't work anymore
Hello, you will have to change the keyboard then... It costs 49$ on the applestore and is delivered within 48h
Mar 31, 2009 | Apple iMac G5 Desktop
Key tronic wireless mouse quit working
Sounds simply broken to me. Time for a new mouse.
May 23, 2008 | Key Tronic UNPLUGGED PS2SB01...
Enabling my Emachine keyboard functions
Sounds the The F lock is on when your computers starts up, You should see a number or F lock on top or your key board just press that button to disable and let you f keys work again, It must be on in your bios if some one there is computer savoy enough to go into your bios and change the setting so when you boot up next time that won't happen anymore, Ok if thats don't work just write back here and we will try another easy task, Let me Know. We try to keep it a simple as possible, Ok Thanks so much and Happy New Year
Dec 25, 2007 | E-Machines eMachines Desktop PC
Microsoft Comfort Curve 2000 Keyboard Logo
350 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
