I recently purchased and fitted an ATC Mini 10 over sink water heater. There's a light to say it's heating but the water is not heating up. Can you help? Thanks Paul
5 Suggested Answers
tborn6
  • 700 Answers
SOURCE: running water in 2 sinks just to get hot water from a bosch
you can put in a circulatating pump that is controller with a timer and a thermostat so the when yo need heat water the most its readilly available and when you don't it's off, the only thinsg thing that you would have to do it tye in the supply and the return and then insulate the pipes.
Posted on Dec 26, 2008
  • 139 Answers
SOURCE: I have a Mini Max 100 pool heater. The pilot
check pressure switch for proper adjustment and make sure filter is clean so system pressure is normal
Posted on Jun 21, 2009
pipesster
  • 20 Answers
SOURCE: size and installation for instant water heater
Ariston gl4.0 should be fine if used inline with your hot water heater. Used alone it will likely run out when dishwasher is filling and you are using sink.To use your existing hot water for backup: 1 connect existing HOT water line to cold (inlet) on ariston, 2 Then HOT (outlet) from ariston to sink and dw. If you want instant hot water at a sink 10 feet away: use 3/8 pex pipe from ariston to sink, so you only have to run off a cupful or 2 before hot water arrives at sink.
Posted on Jan 24, 2010
SOURCE: in our 1995 Chrysler Concorde,
Factory wiring diagrams or manuals --order from -- Helm.Com
Another source -- would be to go to a local shop that has ALLDATA
System & have them print what you need
I personally never buy any Haynes,Chilton etc for the reason
you have found out
Spend the big bucks,if your going to work on your own vehicles
Posted on Jul 30, 2011
2006 mini cooper heater is not working
mini cooper s heat not working - North American Motoring
www.northamericanmotoring.com/...2006/243158-mini-cooper-s-heat-n...
Jan 2, 2013 - mini cooper s heat not working R50/R53 :: Hatch Talk (2002-2006) ...Any way to determine if the heater core is clogged? And could it be ... Overheating issue / heater not working
Jan 18, 2012
No Heat!!!
Nov 5, 2011
2008 MC Heater Problem
Nov 2, 2008
Heater stops working at idle, Engine overheating light comes on at ...
Apr 10, 2008
More results from www.northamericanmotoring.com
MINI COOPER 07 heater blowing cold air-HELP - MINI Cooper Forum
www.mini2.com > ... > Second Generation Faults & Fixes
Mar 6, 2010 - I too have a 2007 Mini Cooper with heater problems. It now has 96,000 miles and I have just started having this problem. Heater will not blow out hot air bottom or top vents when ideling or low speeds .... Join Date: Nov 2006. Heating not working - mini one 02plate - MINI Cooper Forum
May 15, 2012
2002 Cooper S lukewarm heater - MINI Cooper Forum - Mini2.com
Oct 25, 2011
Problem with heater blower - and no resistor pack to be found ...
Mar 21, 2011
mini cooper 02 HEATER NOT WORKING? - MINI Cooper Forum
Jan 19, 2010
More results from www.mini2.com
Heat not working, MINI overheating! - Motoring Alliance :: MINI ...
www.motoringalliance.com > ... > 1st Generation MINI > Cooper S
Jan 12, 2016 | Mini Cars & Trucks
Hot water tank wont heat water, how do you relight or resat, its a reliance self cleaning 808
Reliance Water Heater Literature ' Owner's Manuals ...
www.reliancewaterheaters.com/resources/instruction-manuals
Welcome to the Reliance Water Heaters Owner's Manual and Installation ... 9 40 EKRT - 40 Gallon Tall Self-Cleaning Electric Water Heater - 9 Year Warranty . ..... 10 50 DHPST - 50 Gallon Electric Heat Pump Water Heater - 10 Year Warranty .
How to light the pilot on a Reliance 606 water heater ...
? 3:27
https://www.youtube.com/watch?v=VU2PsFVd2ug
Jul 12, 2011 - Uploaded by kilroywashere123
How to light the pilot on a Reliance 606 water heater ... How to fixwater heater, will not stay lit - sealed combustion no hot water - Duration: ...
Reliance Water Heaters - Consumer Affairs
www.consumeraffairs.com > Homeowners > Bath & Plumbing
Rating: 1.6 - ‎84 votes
I purchased a Reliance 606 water heater in 2010. ... That they don't TELL you there's areset button or that I'm having conspiracy thoughts ... After several attempts, I was able to relight it. ... It's heading to the junk pile and I will purchase a new reliable (NotReliance) ... Checked breaker and changed breaker still no hot water!
Dec 28, 2015 | Reliance Water Heaters
What is the difference between a ATC fuse and a ATM fuse ?
ATC Fuse
  • ATC fuses were created before ATM fuses. An ATC fuse will be larger than an ATM fuse in physical size. This is considered to be the regular size. An ATC fuse will be found in late-model electronic devices.
ATM Fuse
  • An ATM fuse is considered to be a mini fuse and it came out in the early 1990s. The only difference is it is smaller than an ATC fuse in actual size. It generally cannot be used in a fuse block that is made for an ATC fuse, as it will not fit in properly.
Apr 24, 2015 | 2002 Mazda Protege
How to unistall franke mythos mtx taps
Turn off the water supply from the heater and at the main water supply line outside. place a container under the sink where the flick mixer is mounted to catch the water that will come out of the lines when you undo the fittings.
there should be 2 flexible braided lines coming from the mixer to the water supply lines, undo both fittings from those lines, then undo the brass nut that fastens the mixer to the sink, you may need a 10 or 12mm socket with an extension bar to get up under the sink to be able to undo the nut.
there should be a metal horseshoe shaped retaining plate that holds the mixer to the sink which should come off when the nut is undone.
You may or may not have to remove the flexible lines from the mixer which you should be able to sort out when you get to that point.
I hope this info helps you with your problem, the info may not be exactly how I have explained but that is how most mixers are fitted or removed.
Jul 05, 2014 | Emerson InSinkErator HC-View-SS Satin...
Squeeling sound and lower pressure from gas water heater
Probably the factory-installed heat trap nipples are clogged.
Open following links.
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/Low-hot-water-pressure.html#trap
Noisy whistling and humming and low pressure are common problem with heat trap nipples and inserts from factory.
Replace heat-trap nipples with pex-lined nipples, or remove heat trap inserts with screwdriver or needle nose... careful not to break insert so it falls into tank ... which can then get lodged in hot water line elbow or under-sink shut off.
Factory-installed heat traps are part of overall strategy so manufactures can claim more efficient water heaters, without requiring customers to any thinking.
Other strategies include foam insulation instead of fiberglass (so that wires cannot be replaced on electric units), reducing factory-set temperature from previous 130-135 to 100-120, and re-estimating downward the hot water use for average family.
So some of the strategies are useful, while others problematic or imaginary.
Call manufacturer to pay-for or provide new pex-line nipples. Warranty for fist year covers Labor and parts, and after 1st year, warranty covers parts
http://waterheatertimer.org/Water-heater-manufacturers.html
Save $10 a month in future replacement costs: maintain water heater so it lasts longer:
http://waterheatertimer.org/How-to-maintain-water-heater.html
Apr 25, 2013 | Rheem Tankless water heater for 1-2...
Jag 2005 diesel 2.0 where is the fuse front right headlight
found this, hope it helps!
X-Type Fuse/Relay identificationpicture.php?albumid=77&pictureid=795
picture.php?albumid=77&pictureid=796
Engine compartment fuse box - fuses
Fuse Fuse Rating Colour Circuit
No. Type (amps)
F1 Cartridge 20 Blue Dip beam, High Intensity Discharge (HID) light relay.
F2 Cartridge 50 Red Ignition relay feed.
F3 Cartridge 60 Yellow ABS.
F4 Cartridge 30 Pink Rear window heater/heated mirrors relay.
F5 Cartridge 30 Pink Automatic transmission control module relay.
F6 Cartridge 30 Pink Heater blower relay.
F7 Cartridge 50 Red Power supply to passenger compartment fuse box.
F8 Cartridge 80 Black Blower module.
F9 Cartridge 50 Red Engine management system power relay.
F10 Cartridge 20 Blue Headlight power wash pump relay.
F11 Mini Not used.
F12 Mini Not used.
F13 Mini 30 Green Heated front screen right-hand side.
F14 Mini Not used.
F15 Mini 30 Green Heated front screen left-hand side.
F16 Mini 20 Yellow Left-hand dip beam, day time running lights, autolights.
F17 Mini 20 Yellow Right-hand dip beam, HID lights.
F18 Mini 20 Yellow Throttle motor supply.
F19 Mini 15 Blue Screenwash pump, rain sensing system.
F20 Mini 5 Tan Navigation display.
F21 Mini 15 Blue Side (Parking) lights.
F22 Mini 20 Yellow Accessories relay.
F23 Mini 10 Red Air conditioning compressor clutch.
F24 Mini 15 Blue Door lock power.
F25 Mini 15 Blue Direction indicators (GEM).
F26 Mini 15 Blue Horns.
F27 Mini 10 Red Automatic transmission control module, transit relay.
F28 Mini 15 Blue Ignition switch.
F29 Mini 30 Green Starter motor solenoid.
F30 Mini 30 Green Accessory sockets.
F31 Mini 10 Red Engine management relay coil.
F32 Mini 5 Tan Engine management control.
F33 Not used.
F34 Diode D3 Not used.
F35 Diode D2 Engine management control relay diode.
F36 Mini 10 Red Canister purge valve, airflow meter, throttle motor relay, power wash relay, air conditioning relay.
F37 Mini 15 Blue Engine management system, blower speed controller, road speed sensor (if fitted).
F38 Mini 30 Green Oxygen sensor heaters A.
F39 Mini 5 Tan Variable intake valves.
F40 Mini 15 Blue Automatic transmission control module.
F41 Mini 10 Red Injectors.
F42 Mini 30 Green Oxygen sensor heaters B.
Passenger compartment fuse box - fuses
No. Type (amps)
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear tail lights.
F64 Mini 7.5 Brown Left-hand - front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module, VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, Jaguar diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid, electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid, electrochromic mirror, instrument cluster.
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front fog lights, master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit.__________________
02 X-type 3.0l
04 S-type 3.0l
07 X-type 3.0l
Apr 05, 2012 | 2004 Jaguar X-Type
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Size and installation for instant water heater
Aug 30, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
