Question about ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard
Can't start from stat switch
I change with new casing. after that i can't start my pc.
i can see LED light at mother board. jumpper connection correct.
if u know more possible, pls help me
Thanks,
ACC
  • acc1980 May 05, 2008
    sir,
    i have check my MB. i put MB to the paper card board.
    Still can't start.don't hear any beep beep song also.
    but LED light is light up at MB. I remove battery and fixed back.
    Now mother board graphic card, processor, keyboard power box and monitor only installed.
    Pls try to help me.
    thanks
    Genius:
  • 2,785 Answers
Just check your motherboard is touching any metal part below
Posted on May 03, 2008
  • Rajkumar Bordoloi
    Rajkumar Bordoloi May 05, 2008
    plz try with new power supply unit
I have a new pc case on the front panel connectors their is one hdd led +- and one hdd led plug were do they go my case is a EVO LABS E-6690 BLACK/RED, 12CM LED FAN, INC DOOR AND SIDE WINDOW my mother...
You need to look in the handbook that cam with your motherboard for a section labeled 'Connectors' or possibly 'Connections'. There will be one USB 2.0 type prong on the motherboard that is designated for case connections [Power LED, mini-speaker, etc.]. The manual for the motherboard will indicate what order and where on the motherboard your connectors should go.
Good luck with your build. :]
Aug 26, 2011 | Computers & Internet
I have an old PC with VIA VT82C693A motherboard,256MB SDRAM and Pentium 3 CPU. I connected all the peripherals correctly and started the system. The CPU and the fans are working.The CD-ROM is...
Hi,Thanks for using fixya,
Switch off the computer and open the pc cover.
First check the ram,and clean by eraser or with solvent and install again.If the problem is same, install the ram to another computer to ensure either it damage or not .If the problem is same change ram.
http://en.wikipedia.org/wiki/DIMM
http://www.pcbuyerbeware.co.uk/RAM.htm
If same as before, remove the cmos battery or clear the cmos jumper and hold" on off "switch for 40 seconds. Install battery again and start pc.
Now please check the "smps" by another new or by your"smps" to another pc to confirm either it damage or not.clip_image003.jpgclip_image004.jpgclip_image005.gif
http://www.playtool.com/pages/psuconnectors/connectors.html
If same as before now please take a risk and ready to chip label repair,
1.Change all the bad capacitors, beside the processor, with the help by nearest technician. http://cquirke.mvps.org/badcaps.htmclip_image007.jpghttp://en.wikipedia.org/wiki/File:Acer_E360_Socket_939_motherboard_by_Foxconn.svgclip_image009.jpghttp://en.wikipedia.org/wiki/Motherboard
2. Set an identification Mark, on the bios chip, by the permanent marker because you need to remove and install it. It could not be possible for all mother board.clip_image011.gifclip_image012.gifclip_image002.gifclip_image013.gif
3. Remove bios chip from base, clean with solvent and install it proper again.It could not be apply for all mother board.ONLY FOR INTEL PLATFORM
4.For Intel mother board ,install a floppy drive and switch on the power and, watch the "led light",( floppy drives )either Blink with a long times or not.
If the floppy drives led light on, download updated bios your Intel mother board,and use a floppy disk for restore the bios , Download link.http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22865%22.
5. Don't switch off your motherboard at the time of updating the bios, so please use ups and insert the floppy, along with bios file. Set the cmos jumper in recovery mode (just change the normal position). http://www.intel.com/support/motherboards/desktop/sb/cs-023360.htmhttp://www.intel.com/support/motherboards/server/s5520ur/sb/CS-030161.htmNow switch on motherboard, hope, through these processes,should recover the mother board.
If the problem is same, try to install a graphics card. For same problem I will recommend you for new motherboard.
Feb 19, 2011 | Computers & Internet
Bought new power supply, no difference power button will not even go on or light up ; however small green light on mother board lights up. als accidentaly disconnected the switches wiring to the mother...
The green light just show that the motherboard is getting power.
The power button of the front of the case is connected to the mother board, not to the power supply, usually in the extreme lower left corner along with the with the HDD and Reset Button cords; Power button wire are labeled and usually red/black.
If all wired correctly, possible bad or stuck power button or reset button.
Hope this helps.
Please rate this answer by check rating "Hands"
Feb 08, 2011 | E-Machines T3958 (827103050974) PC Desktop
Front panel motherboard samsung harappa-30 PBA:BA59-00905A
i wont to sound drivers for polaris motherbrod
Jun 12, 2009 | Computers & Internet
Swapped mother board
Hi Paul,
see page 8 number 15 for location. Than see page 19, System Panel Header in your manual.
The basic wire color's for positive are red, blue, green & can also be light blue, light green, light red.
Negative wires are usually white or black. Case wire colors do vary from case to case.
To see pin one shown on page 19, (positive + for hard drive led = HDLED+). Bottom row farthest pin to the left of set. Pin two is above pin one. Pin two is, PLED+ (known as power led). Pin 3 is to the right of pin one & is HDLED- (Hard drive led, negative). Pin 4 is above pin 3 & is also PLED-, (Negative for power led). ECT!
6781222.jpg If your new case has an internal speaker (Used for P.O.S.T, power on self test). This would connect to, Chassis Speaker Header located on page 8, number 16. Again, normally only two wires are used across the 4-pin connector. (One at each end of the connector).
To see ASRock's main site for the 775VM800 motherboard click this link:
http://www.asrock.com/mb/overview.asp?Model=775VM800&s=
Good luck Paul!
Run into a snag, just post the issue here.
Mike
Nov 02, 2008 | Asrock 775VM800 Motherboard
GA-M57SLI-S4 wont power up !!! what to do !
Hi check the cables from the case to the mother board. They should be marked and the manual that came with the board ,this show you where to connect them on board The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] in most cases check to see if this is correctly connected
To test if there is no fault in the board or power pack. first visualy check the board to see if it shows a red led light when the power is turned on, if not the problem is in the power pack or the wall outlet.
second if the light is on, bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, check the processor and ram if not you have a faulty board.
Sep 17, 2008 | Gigabyte GA-M57SLI-S4 (4719331821180)...
Dimension 8200 will not turn on
Try a new power button. Also does the machine power light turn on at the front of the machine? if so check that the CPU is seated correctly as if it has come out of position then the machine doesn't boot. I would like to think power switch though.
Thanks J
Jan 17, 2008 | Dell Dimension 8200 PC Desktop
New installation of mother board
Hi check the cables from the case to the mother board. They should be marked and the book that came with the board will tell you where to connect them. The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] To test if there is no fault in the board or power pack. first visualy check the board to see if you have a red led light on when the power is turned on, if not the problem is in the power pack or the wall outlet. second if the light is on, the bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, if not you have a faulty board. Regards mistyman
Oct 05, 2007 | Select Brands System on board CPU / VIDEO/...
New Problem
The manual you need will be on the board manufacturers web page, howevr I will bet you have the case power switch and perhaps the reset switch on the wrong pins on the mother board. To check this, remove the switch leads from the mother board, then use a small screw driver and bridge the pins on the mother board a pair at a time. All of these leads plug on to the board in a line and not across the two lines of pins. when you get the mother board to fire up by this method geet a torch and look closely alongside the pins you will see the letters PWR SW or RS SW. It does not matter what polarity these two sets of leads are plugged onto both will work. The LED lights on the case front will only work if the polarity is correct but it will not do any harm if they are backwords. On the board you should se two sets of pins marked HDD and PWR these are the led light pins you will know you have them right when the usual red and green lights are working at the front of your tower. Regards mistyman
Aug 15, 2007 | Balance CP4401 PC Desktop
ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
