Question about Kenmore 98702 Stacked Washer/Dryer
My dryer tumbles but does not heat. I've cleaned the lint vents still no heat.
  • Kenmore Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
Whirlpool dryer heats and tumbles but doesn't dry
Sounds like it is still clogged up. Is the blower running?
Feb 23, 2014 | Whirlpool Dryers
Tumble dryer overheating
Check and clean your lint filter. If problem persists, check the discharge of your dryer vent. A clogged dryer vents will cause abnormal heat build up in a dryer.
Feb 17, 2012 | Dryers
Dryer Model LER3624JQ0 tumbles clothes, has heat, but clothes are hot and damp. Cleaned lint filter & took of vent in back (thought maybe clogged wall vent) but didn't help. Don't think much (if any)...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Mar 20, 2011 | Whirlpool LER3624JQ Electric Dryer
Dryer is a Fridgidaire Home Gallery...and the dryer tumbles, and heats in beginning of cycle but the heat will not continue to heat...tumbles normally. The vents have recently been cleaned.
if it's gas you have bad gas coils,if not blow out the vent line with a leaf blower if it's long from the back of dryer to the outside vent,also make sure the outside vent isn't blocked,then remove the lint filter and then remove the duct that it slides into and clean that out,let me know what you find,this came in under a frigerator,ha kinda messed me up
Sep 30, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
1 year old Kenmore dryer tumbles but doesn't heat.
If it is 1 year old, call Kenmore , they will probably fix it as a courtesy call.
If not quote that the machine is not fit for purpose as it should not have gone wrong so quick
Sep 24, 2009 | Kenmore Dryers
Not drying clothes - have heat and tumble but probably not air Kenmore 80 series dryer.
Your vent is clogged. Remove hose from back of dryer and wall. vacuum out back of dryer, dryer hose an vent pipe in wall, if it goes out at roof you will need to clean out. Moisture from dryer is getting caught in excess lint trapped in vent causing dryer not to dry.
Sep 20, 2009 | Dryers
Whirlpool AWZ 7303 tumbling but not drying.
blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Sep 11, 2009 | Dryers
Dryer not heating
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
May 02, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Whirlpool Dryer tumbles, but no heat, no timer.
try turning your breaker off then on and advise me
Dec 31, 2007 | Dryers
Kenmore 98702 Stacked Washer/Dryer Logo
152 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
