Hi it depends on what the inputs are on the device if you have the 3 color sockets then this will work in the uk with our equipment, if the bose system picks up its own signal such as tv channels then it wont work but if its just a device for putting inputs in from devices such as tv's, game consoles and stereo etc then you will have no problem using it in the uk, you may need to get an adaptot though as our voltage is 240volts so you will need to see if your device works at this higher voltage usually they are universal but it may be worth just asking in your local tv repair shop it it is compatable it should be but it wont cost you a penny to ask your local tv repair shop
it should tell you on the back if it take more than one volt input so have a look and see what it says, the inputs should be the same as uk but double check the voltage.
let me know if you need further assistance ok
