Question about Yamaha YSP-1 System
Won't turn on,power supply good, sounds like it wants to,clicking to power up, but dosen't
    Problem Solver:
  • 9 Answers
C515 ON THE MAIN POWER PCB (HAS 223 K 630HI PRINTED ON IT) HAS FAILED
Replace with a 22nf capacitor - Maplin part number N38CN
the new maplin part has a higher voltage rating and is bigger. it will need to be fitted with the leads extended with wire to get it to fit.
Posted on Oct 01, 2010
I have a spider box yerfdog 3206 wt i believe 150cc howhit engine. Won't start solenoid clicks but no power to starter. even direct power to starter wt solenoid bypassed starter won't kick in ? I have
this sounds like the starter is no good that`s why you get a click noise and why bypassing the solenoid it won`t turn over. the armature must be drawing more amps than what can be supplied.
Sep 21, 2014 | Cars & Trucks
Clicking sound when you turn the tv on but won't work until a few minutes sometimes longer .
The clicking sound is an indication that the power supply is trying to start but is failing
Apr 16, 2013 | Televison & Video
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
Dec 22, 2012 | Samsung PN58A550S Plasma TV
My Phillips 52" LCD TV won't turn on...it is just
it possibly you have shorted power supply board or inverter board that cause of clicking sounds..
try to unplug the inverter board then try again if the indicator lit in blue you have shorted inverter board that need to be replace.
Nov 06, 2012 | Televison & Video
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
Model code HLR4667WX/XAA won't turn on just clicks
Sounds like you have defective capacitors in the power supply board, cheap and easy fix for those with electronics repair skills
Jul 23, 2012 | Samsung LN-S4041D 40 in. LCD HDTV
Air conditioning won't blow air
sounds like your feeling air flow from motion your blower dosen't sound like its coming on try when you are sitting still with car running turnibg on the blower if it dosen't come on it could be anything from a bad fuse to a bad blower motor
Jul 07, 2012 | 2003 Buick Rendezvous
TV won't turn on. I hear a clicking noise near the power supply. I have no picture or sound
This is usually and most likely caused by the power inverter/board. There are capacitors and other components that can burn out and will cause the power not to be transfered correctly
Jun 06, 2012 | Sony BRAVIA KDL-52W3000 52 in. LCD...
My e-machines T3653 pc wont start up all the way. When i hit the power botton it dosen't turn on. But when i disconect the power and plug it back in it does turn on but only for a few seconds>
Sounds like possibly a heat issue. Take your case off (if it's not under warranty) and see if the fan over the processor turns on when you plug it in, also the fan in the power supply, and possibly over a video card as well. If none of those turn on that could be what is causing or what did cause your problem. If the motherboard senses something is overheating it will shutoff the system.
If it's not that, you have more problems and would need to take it somewhere to get it looked at. Could be a number of things, power supply, processor, ram... would need to test them.
Jun 24, 2011 | E-Machines eMachines Desktop PC
TV won't turn on, red light flashes on TV and hear a clicking sound in back of unit is it worth fixing?
Yes,the LED power lite on the front panel stable?Yes,mean the DM power supply board is good.LED power like blinking,mean the DM power supply board is dead.DM power supply is good,still making that clicking sound,when turn on.Mean ur Blast board is dead,that the board that help to light up the projection lamp.
Jun 24, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Yamaha YSP-1 System Logo
313 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
