Question about Amana Washing Machines
My model LW6153WM Amana washing machine doesn't agitate very well any more. Is this a belt issue or do I need to replace the drive bell ?
SOURCE: washing machine agitates, but does not spin
my amana washing machine does not agitate, but it does spin
Posted on May 17, 2008
  • 686 Answers
SOURCE: Amana Washer LWA50AW doesn't spin
pry up the top remove screws on front panel toward top set front panel aside and you should see what you need to do
Posted on Feb 27, 2009
jumptrout51
  • 3361 Answers
SOURCE: amana LWG65AW wash machine spins but does not agitate
Remove the front panel and replace the drive belt around the motor and pump.
Posted on Mar 28, 2009
  • 46 Answers
SOURCE: agitator removal / amana washing maching
Chec This outAutomatic Washer Parts Manual
Posted on Sep 07, 2009
  • 103 Answers
SOURCE: The washing machine belt will move to agitate, but
open rear cover , see if belt slips. then remove belt and rotate empty drum if its jam than drum bearings need to change. if drum is free then belt might be loose and needs replacement.
Posted on Nov 05, 2009
Whcandy washing machine grand go f 662 stops mid cycle and the cold wash light flashes and the softener isnt usedat's your problem?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
TOOLS NEEDED TO SOLVE PROBLEM ARE BELOW.
Bucket and rags,Screwdriver,
New drive belt (if necessary),
New drive motor (if necessary).
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Thanks.
Nov 08, 2011 | Washing Machines
Candy washing machine grand go f 662 stops mid cycle and the cold wash light flashes and the softener isnt used
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your selfer can fix it; here's how.
TOOLS NEEDE TO SOLVE PROBLEM ARE BELOW.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reset the agitator.
Thanks.
Bottom rotor is not working
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-yourselfer can fix it; here's how.
Bucket and rags,Screwdriver,New drive belt (if necessary),New drive motor (if necessary)
Thanks.
Drain line clogged on Whirlpool model ET1CHMXKB09. How do I access the drain line?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with most old washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
Thanks.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't spin, what do I do
Check the lid or door switch this is the usuall issue with a washer that won't spin. The other is a blocked pump or clogged pump filter.
Apr 30, 2011 | Maytag Washing Machines
I have a GE top loading washing machine. The agitator has stopped working and the drum no longer spins at the end of the cycle when the water drains. What can I do to fix it and get the agitator...
When the agitator on your GE washing machine does not work correctly, the most likely cause is a worn drive bell. The drive bell sits on the agitator shaft inside the agitator. The shaft and the inside of the bell lock together using splines. When the splines inside the drive bell wear out, the agitator will not rotate correctly. To repair the agitator on the GE top loading washing machine, you will need to remove the agitator and the drive bell.
1. Unplug the GE washer from the wall outlet. Open the washer lid to access the agitator.
2. Grab the bottom of the agitator with both hands and pull the agitator out of the washing machine. If the agitator will not budge, rent agitator hooks to pry the agitator out. Agitator hooks are available at appliance repair stores. Set the agitator hooks under the agitator and push down on the handle to pull the agitator off the shaft.
3. Pry off the plug on the top of the drive bell on the agitator shaft with a small flathead screwdriver. Use a socket wrench to remove the hex head bolt at the top of the drive bell. Carefully pull the drive bell up off of the agitator shaft. This may take some force depending on how stripped the inside of the drive bell has become.
4. Inspect the inside of the drive bell. There are splines inside the drive bell that line up with the splines on the shaft. Most often the splines inside the drive bell have worn, causing the shaft to spin but not the drive bell. Also inspect the notch on the outside of the drive bell and the notch inside the bottom of the agitator. If either of these are worn, replace the drive bell and the agitator.
5. Take the drive bell to an appliance repair shop to purchase a new part. If you need to replace the agitator, take the old one with you as well. Compare the new parts to the old ones, making sure they are identical.
6. Position the new drive bell over the agitator shaft, lining up the splines on the shaft with the splines on the inside of the drive bell. Set the securing bolt back into the top of the drive bell and tighten the bolt down until it pushes the drive bell down until the bell bottoms out. Push the new plug on the top of the agitator bell with the palm off your hand until the plug locks into place.
7. Place the agitator over the drive bell and slowly rotate the agitator until the notch inside the agitator lines up with the notch on the outside of the drive bell. Tap the top of the agitator down with the palm of your hand until the notch on the agitator locks down over the notch on the drive bell. The agitator will not bottom out flush with the tub.
8. Close the washer lid and plug the washer power cord back into the wall socket.
The defective agitator is the cause of the drum not spinning. So get the agitator fixed and it should solve the spinning problem.
Good luck.
Apr 22, 2011 | Washing Machines
Amana washing machine will not spin. it agitates & the water drains out fine.
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 30, 2010 | Amana ALW780QA
Amana LWG65AW wash machine spins but does not agitate
Mar 28, 2009 | Amana Washing Machines
Will Not Agitate!
try replacing the drive bell, which is underneath the agitator. take the agitator off and unscrew the drive bell. remove and replace. the drive bell is most likely stripped.
Mar 29, 2007 | GE WDSR2080D Top Load Washer
Washing Machines Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
