Question about Garden
We have a outdoor light sensor and need to know how to keep it on sometimes while the children are outside playing at night. Now it comes on only during motion and then goes off in about 3 mintues.We want to keep it on ..how do we adjust??? We have misplaced the manuel.
    Problem Solver:
  • 6 Answers
Without knowing the model i can only suggest what works for the ones i have. one of them if you toggle switch on and off twice in 5 seconds it will be on full time, then toggle it on and off one to return back to motion. the other doesnt have that feature but there is a small switch on the top of the motion sensor to switch between dusk to dawn, motion, manual
Posted on Aug 20, 2010
Testimonial: "Thank you so much for getting right back to us, we will try it tonight and do as you said. We have a EML E 100 model. Again thank you so much for your"
I have the Atomic Clock model W86111. I had to change the batteries on the outside device. The clock outside temp just flashes 63.5 all the time. How do I make it sync to the device outside?
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Oct 14, 2017 | Home
What am I doing wrong? I keep losing my outdoor temperature overnight
I can understand when it is very cold outside, the voltage of the battery drops below the point is can service the transmitter (in the thermometer). But if night temperature is not below zero that can't be the cause.
Be aware, even batteries that come with a new device, can be "old". you never know what the battery had to last, before you put it in the device.
I would advice to buy a new battery for the thermometer. Look in the manual, for what the manufacturer advices. But never use manganese (Zinc-Carbon) batteries. Although the alkaline batteries perform bad in cold, it could be the best choice.
Jan 05, 2015 | Springfield 91455 Wireless Digital Outdoor...
My unit to my house wont turn on outside. This happened last night at about 8:30. I have checked the circuit breaker/fuses and the little red switch on the unit itself-- I pushed that. I turned the...
Turn power off to indoor unit. Remove red, yellow and green wires from tstat and wire nut the three together. Turn power to indoor unit back on. This should bring on indoor fan and outdoor conpressor and fan. Let me know
Jun 22, 2017 | Fedders Q Chassis A6Q10F2A Air Conditioner
On verry cold nights the aux. heat will not come in. The aux. heat can be turned on manualy
There is a malfunction with the outdoor temp sensor on the heatpump.
You will likely have to replace the sensor.
If the strips are coming on in defrost and manually, then you know the relays, heat sequencers and other controls are operating. there apearently is no signal telling the system that the outdoor temp is to low for the HP to operate efficiently.
Feb 01, 2010 | Ruud Heating & Cooling
I just moved into this home and am wondering what EM heat is compared to just Heat and my outside unit is full of frost what do I need to do?
Hi, EM stands for emergency heat. You should only need to use it if the outdoor unit does not operate. You have what we call a heat-pump. If the outdoor coil is iced up, it should go into a defrost cycle to melt away the ice. You will know when it does as you will see steam coming up from the unit as though it is on fire. The outdoor fan will also shut down during this process. These units will defrost using time and temperature to defrost the coil. If the ice continues to build-up, and does not defrost every couple of hours, I would say you have a faulty defrost board or defrost thermostat. There is not alot you can do as these are very complicated systems to work on. You will more then likely have to call out a service tech to check this outdoor unit for you.It also should have heat strips in the outdoor unit for EM heat if the outdoor unit fails. If it is iced up it is on and running. Thats what I would do is keep an eye on it to see if it does defrost, and if not, you will need to get a tech out to check it. It takes special equipment to check these units. Please keep me posted.
Sincerely,
Shastalaker7
Feb 01, 2010 | Honeywell Programmable Thermostat Heater
Programming the Malibu landscape sensor pack. Model # : 8100-9100
it is an adjustable photosensor system. you will need to play with it to fine tune the settings, but you also need to keep in mind that photo sensor react to everything around them, shade can cause it to think the sun is going down, a cloudy day will cause it to stay on, or to come on. if you are looking for away to set it, to only come on when the sun is going to go down, and to turn off when the sun starts to rise, it might actually be easier for you, to get a time programmed timer for you lighting.
Jan 20, 2010 | Solar Industrial Timer Switch Outdoor Sign...
When we turn on our split AC, outside unit is not turning ON
The blinking light is because the unit is waiting for the outdoor unit to come on. If in heating mode, the indoor fan will not run before enough pressure and therefore heat has built up. You should check that the indoor air return sensor is not faulty and therefore preventing the outdoor unit from coming on.
Nov 15, 2009 | Amcor NanoMax A12000E Portable Air...
Outside unit not registering temp and humidity to base unit
Uniden EWCI936
To get the outside temperature working again, open the outdoor sensor box carefully loosening the one screw with a screwdriver, insert 3 brand new AA batteries, check phone for outside temperature. If not showing on the phone display, try changing the 'channel' setting, just above the batteries. Be careful not to break the tiny switch. Gently use a smaller flathead screwdriver, if needed. There are 3 settings. Mine worked fine on the first setting. If it is showing on the phone set screens, then, carefully screw the lid back on to the sensor box, and re-insert into the sensor wall holder. I keep mine in a plastic bag on a shelf outside, away from sun, so I can get a true reading day or night. It is always a bit warmer in the sunlight than the true outdoor air temperature. Enjoy
Apr 24, 2009 | Lands Phones
Heating problems
It sounds like the unit is going into a defrost cycle, which is normal for heat pumps and means all is working ok when it gets around 35 or colder they start to do this more often when the red light goes back off , the outdoor fan should come back on. You may also notice steam (may look like smoke) coming from outdoor unit. Is that what happens??
Jan 15, 2008 | Intertherm P3RA-048K Air Conditioner
Garden Logo
134 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
