Question about Garden
Murray rider deck adjustment - Garden
  • 3 Answers
Place on flat level ground, remove floating wheels, open the flap on the deck height adjuster place handle all the way down, on the deck you will find a big plastic wing nut on each side loosen both of them, wiggle the deck and retighten them pull deck up replace floater wheels, close flap and use
Posted on Oct 07, 2010
3 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: how to adjust the mower deck on my murray rider,
Park the tractor on a firm, level surface. . .
At the lower end of the lift/lower travel slot, there should be a plastic cover which you pop up so that your blade lift handle goes all the way down (it should say something about blade level on there somewhere. . . . .
After you have the handle in this position, look at the front lift arms of the mower deck and find the 2 large wing nuts, one on each side. . . . .
Loosen these while the deck is down and then retighten them Your deck is now level and will lift to its highest recommended position when you raise the lever
Posted on Oct 11, 2009
mowerman1857
  • 389 Answers
SOURCE: need parts for old murray rider mower 36 in
If you send me your email address I will send you a PDF file of the parts for your mower
m o w e r m a n 1 at h o t m a i l dot c o m
Use correct format and without the spaces
Posted on Sep 17, 2009
Need a wiring diagram for a murray rider
go on the internet at www.webcrawler.com and they have every type of diagram u want.
Apr 01, 2012 | Murray Garden
I purchashed a used 26 54 husqvarna 2007 model rider and it will not cut low enough.My murray will scalp ground if i lower deck to ground.It looks like the blades are designed to be set higher off...
Low under the steering wheel there may be an adjusting knob. If it is there are you turn it, it should adjust the height of the deck. If you lower the deck and try to turn the knob it will be difficult to turn and you will know that is what it is for, the deck lower stop. Then pull up the deck and adjust a bit and lower the deck and see where it is, repeat until satisfied with the deck height when lowered.
Sep 20, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I need a diagram on how to fit a cutter deck belt for a murray sentinel 15.5/ 106. Belt number 037 x 88 Keith
The routing is usually pictured on the belt cover such as in your picture. If you send me the model no. to the rider, I will verify proper routing.
Feb 11, 2011 | Murray 38 Lawn Mower Blade Belt '90'96...
I need to adjust the clutch on an older Murray rider. I found how to adjust the clutch rod, and now I can't get it back on.
Estoboy, navigate to http://www.mytractorforum.com/forumdisplay.php?f=202
And post a picture of your machine. We'll be able to help you better on there. (Tons of Murray guys)
Jul 12, 2010 | Garden
The belt is too loose on my 42" 17.5 Murray rider mower. Where can I find the adjustment?
Hi how old is your belt, if it is an original one or even a replacement with use go to your local repair shop and get a new belt --- take your old one so they match it up as well as your make--model---serial number of the mower. this will get you the right belt. you have a pulley that should take up the slack so I would look at the belt for streching and wear.
Oct 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to adjust the mower deck on my murray rider,
Oct 11, 2009 | Garden
Need parts for old murray rider mower 36 in deck,nobody can identify model #7-36508 help please mr Rider?
Sep 17, 2009 | Garden
Murray rider quit abruptly.
were you mowing at the time? if you didn't disengage the blades, the engine will not start, everything will seem "dead". if that's not it, check for a blown fuse
Aug 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
254 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
