Question about Frigidaire Washing Machines
Mod. gltf2940es3..Washer will not perform final spin nor extra spin...
  • 2 more comments
  • old gringo Aug 20, 2010
    This machine is a fairly new front loader/are you familar with this model?
    Front loader washer frigidaire (Electrolux)model gltf2940es3. Will not go into final spin.
    Thanks Mac... I did not receive any manuals with this washer. How do I gain access to replace the doorlock/switch assembly?
    Thanks again Mac ....I ordered the part online. Should receive it by middle of next week. Following your instructions I should be able to replace the part ok. I may have to get back to you.
  • Frigidaire Master
  • 2,605 Answers
Hi, welcome to FixYa. Based on what you've described, "Washer will not perform final spin nor extra spin"... you need a door lock/switch assembly. It is likely the single most common fault (which prevent's any spin, and consiquently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed. I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately. You should be able to purchase one at most local brick & mortar stores or on-line part's depot's such as "searspartsdirect.com" "repairclininc.com" to name a couple. They usually sell for about $50 or so, part #131763202 and are relatively easy to replace. Let me know if I can assist you further. Thank you for visiting "fixya" today. Good luck. macmarkus :)
Posted on Aug 20, 2010
  • 2 more comments
  • Mark MacDonald
    Mark MacDonald Aug 20, 2010
    Hi again,
    No problem !
    There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
    1) **unplug the washer from the wall...safety first of course.**
    2) Reomve the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
    3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the new one and you`re in business.
    4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
    Let me know if you need further assistance going forward or if my instructions are not clear.
    Good luck.
    macmarkus :)
  • Mark MacDonald
    Hey absolutely, let me know how it goes for sure.
    Good luck though.
    macmarkus :)
  • old gringo Aug 25, 2010
    Hey Mac.....Your diagnosis was right on. I received the part today and installed it using your directions...machine is back in service.. Thanks for your help. .Take care
    Old Gringo
  • Mark MacDonald
    Mark MacDonald Aug 25, 2010
    Awesome !
    Glad I could help Old Gringo. Give yourself some props, you just saved approximately $200...or more !
    Thank's again for choosing FixYa. Come again...I know, hopefully no need to for a while.
    Regards.
    Macmarkus :)
    Brigadier General:
  • 3,513 Answers
Hi
If the lid switch is defective, your washer can't spin and may not function at all.And this can be the cause that your washer is not performing the final spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Let us know if you have somethin more to ask else accept the suggestion.
Thank You for contacting Fixya
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
Washer...Amana Mod:NAV3335AWW. Washer tub does not agitate correctly and when final spin is finished, clothes are still soaked. What can cause this?
If the cloths are coming out wet then it sounds like yours trans. I would not advise you to fix this it will cost more than a new washer
Nov 09, 2010 | Amana NAV3330E Top Load Washer
Just a Idea, belt is slipping this is why when it is empty it works on high speed when full its to heavy and belt slips
May 06, 2010 | Frigidaire HE 3.1 cu. ft. Extra Large...
Washer cuts off at 7 minutes and will not do the
It be the carbon brushes are worn down on the motor, when it goes into the final spin.
Mar 09, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES3
I believe E47 is a door lock code.
You probably just need to replace the door latch.
Common problem with those units.
Sep 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
The final spin cycle on my maytag neptune washer will not perform
If you have changed the door lock assbly,the next thing it could be is the need for a motor conversion kit. this is something you need to place a service call on. The approx cost for part #12002039 is 240.00US
Feb 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
190 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
