Question about HP Officejet 6310 All-In-One InkJet Printer
As soon as printer turns on, lights flash and reset power shows. I reset power and the same thing happens repeatedly. Have tried posted solution, but it doesn't fix
  • 666 Answers
You will want to go into the anual and look for a factory reset
Posted on Aug 20, 2010
1720DN
Here's something to try, it's actually the drum reset and if it's the drum that needs replacing then this will get you going again. Just remember that if you reset this that eventually the drum will start having quality issues because you will be using it past its end of life cycle getting more use out of it then normal and it won't hurt the machine either... hope this helps and if so, please mark Fixya
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stop. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
Jun 25, 2010 | Dell 1720dn Laser Printer
Red lights flashing back and forth
Just a small but very important question. Is the CD/DVD tray closed?
This may cause flashing lights.
This picture shows the tray (ref. Epson troubleshooting guide)
Thanks,
Lolita
Apr 17, 2008 | Epson Stylus Photo R220 InkJet Printer
When I turn the PC785 on, EO flashes and the unit turns off.
Hello sir; You don't need the parts, the only thing you need is reset, the procedure as follow; Turn power off, remove front cover, short JP1 to JP2 on DC controller (upper right corner of board), turn power on, the display may show a different code,repeat the reset procedure.
Aug 11, 2009 | Canon Office Equipment & Supplies
Power and attenion keeps flashing says turn power off then on
Perform a partial reset of the HP All-in-One
  1. Turn on the HP All-in-One.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 3 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 30, 2009 | HP Officejet J5780 All-In-One InkJet...
"Change oil soon" light
Turn your key to the on position wait until all of your indicater lamps do their thing . Then pump the gas pedal 3 times in rapid motion in less than 5 seconds. Wait until you see the change oil light start flashing. If this does not happen then turn the key off turn it on again and repeat the procedure.
Jan 30, 2009 | 2005 Buick Century
Printer showing error
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. This is quite straightforward once you know what to do.
If you decide to have a go at replacing the ink pads yourself, post a new comment, and I will provide further help.
Dec 08, 2008 | Epson Stylus C40UX InkJet Printer
Power light and red light keep flashing alternatively
If both lights are flashing alternately, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utilit to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Nov 03, 2008 | Epson Stylus 680 InkJet Color Printer
All available lights on printer are flashing
More or less your printer fuser has gone bad. Replace the fuse. I suggest that when buying a printer you don't with dell 1710N these printers gives a lot a problem. I work with them every day at work.
I suggest that you go with HP.
Oct 09, 2007 | Dell 1710 Laser Printer
All lights flash like crazy on powering up; diagnostic says "turn power off & on"
that is power suply broken. i already got one of those with same sintoms. you must exange it
May 12, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
598 people viewed this question
Seeker5211
Seeker5211
