Question about Watches
I recently bought a marc jacobs watch and want to see if i can remove the links on my own
4 Suggested Answers
escapement
  • 2334 Answers
SOURCE: i need to remove watch links
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 09, 2009
  • 492 Answers
SOURCE: Remove links on this watch
Most bands have removable links on the end of the band. You can tell because they have small holes on the side to remove the pins that hold them together. The links that don't have holes are not removable. This is standard on most metal bands.
Posted on May 09, 2009
  • 299 Answers
SOURCE: I recently received a Tag Heuer Link Calbre 5
Here is how its done. First remove one end of the clasp (this is much easier on the adjustment side - just depress the pin and remove). Now you can separate the two halves of the first link (actually this is a half-link). Simply grab each half and pull. You may have to do some twisting - do it carefully so that you don't bend the pin. You may have to do some prying - if so, you can use a thin piece of plastic so you don't scratch the link and only pry along the pin so that you don't bend it. Once removed, you can now remove the first full link. Remove it in the same way. Now replace the end half-link and re-attach the clasp. Removing a link from the other side is a little more difficult. The clasp lock is held on with a long pin (slot on one end and screw on the other. One must be held in place while you turn the other. You may need another pair of hands to help you.
If you feel uncomfortable about any of the above, take it to a jeweler - a Tag AD is not necessary but probably best although any jeweler can remove a link if they understand how they are put together. Tell them the link is composed of a right and left half that snap together and they should then see and understand what they need to do.
Posted on Apr 28, 2010
Marc Jacobs battery replacement
Robert, take it into a jeweler, they do not charge much more then the cost of battery.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jun 30, 2016 | Marc Jacobs Watches
What battery fits a Marc Ecko E22569G1 watch?
http://www.bigapplewatch.com/battery.asp?prod=battery&watchnumber=MARC%20ECKO%20E22569G1
Dec 05, 2014 | Marc Ecko Watches
How to get extra links for my watch?
The only place you can get watch links are from the manufacturer, unless you want to buy a second identical watch.
Aug 12, 2014 | Marc Ecko Marc Echo Watch Large Heavy Ss...
I have a marc jacobs 10 jewels unadjusted and has stopped working. what shall i do
Take it to a jeweller, a Marc Jacobs dealer, or a watchmaker for cleaning or battery replacement.
7.June.2014
Jun 07, 2014 | Watches
Removing a link in watch
this video will help you
Mar 17, 2014 | Marc Jacobs MBM3178
The back wont go back on watch after changing battery
The jeweler should be able to put the back on again. He/She has the tools.
Nov 07, 2013 | Swiss Marc By Marc Jacob Leather Wrist...
Jacob jensen 842 battery
Mine is a 750, but essentially, when you search long enough (pref with a magnifying glass) you can find a tiny little slit. If you carefully wedge a pen knife or similar underneath, you can get it open. Quite a tight fit though!
Jan 19, 2013 | Jacob Jensen Watches Jacob Jensen - Watch...
I just got the Marc Ecko Watch, Women's Stainless Steel Bracelet E15035L2 and I dont know how to set the time on it. How do i set the time on it.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all MARC ECKO watch manuals. Rate me, plz.
Feb 17, 2010 | Watches
Watches Logo
3,525 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
