Question about Vizio VR1 Remote Control
My husband spilled red wine on the remote then left it over night. i've dismantled it and cleaned everything, even the computer board. it looked a little burned, like the wine was brown colored when i wiped it off. the red button on the remote is working but it's not controlling the tv at all. do i need to reset the codes or something?
  • 666 Answers
This item is most likely fried and rather than stressing yourself out looking for possible solutions to the problem your husbands clumsiness cause I would say have him give you some money and go purchase a new universal remote
Posted on Aug 20, 2010
My vizio changer hard to chg channels have to push hard and move changer around to change channels. I put new batts.still does it. been like that for awhile
Some liquid may have been spilled onto this remote. As the liquid dries, a film is left on the circuit board inside.
Carefully take the remote apart and clean the circuit board with rubbing alcohol.
Take the rubber membrane that has the remote buttons on it, and clean the back side that touches the circuit board when you press a button.
Allow everything to dry completely and put the remote back together.
May 18, 2011 | Vizio L32 32 in. LCD HDTV
My husband spilled wine onto our remote and after cleaning the inside etc. no power at all. I tried new batteries,but nothing happens at all...am I screwed?
Yes,the wine acid are strong and deadly to electrostatic electronics equipments.The wine spilled probally sip into CPU itself and short it out are already.The remotes equipments,the small surface mount CPU chips in the remotes controls everythings.
Nov 30, 2010 | Logitech Harmony 550 Remote Control
Kenmore wine cooler 13485 spill wine in the top not cooling
if suction line is warm and pressure line hot . sounds like comp is trying to do its job / ck the fans and they may be slow or not going . spilling of the wine did not cause problem . .. but now is the time to correct the problem .. mm / ps if unit is running like you state the you might look at the ref charge . as it may be low . mm . hope this hs helped . feed back pls .. mm
Jul 22, 2010 | Kenmore 13485 Wine Cooler
Hullo, I spilled wine on my sony vaio
spilling the wine could have caused a surge to your battery or charger either one could be damaged but if your battery is reading full and powers off at random then it is probably your battery and needs to be replaced
Apr 08, 2010 | Sony VAIO VGN-N250E/W Notebook
My time warner remote won't stop blinking. The
REPLACE YOUR BATTERIES AND PROBLEM SOLVED. It has nothing to do with contacts or fluid spills.
Feb 24, 2010 | Televison & Video
Wine was spilled into my Harmony 1000 remote
Have you remove battery from the remote immediately after wine spill? If not, your remote is gone and most likely not repairable.
Nov 23, 2009 | Logitech Televison & Video
Spilled wine and shorted it out...no power is this repairable
Wow! Well, at least I hope it was a good Cab. I see your post is from some time ago, so by now you have probably been able to salvage the remote or it has found itself another home (trash). But, for those of you out there who may experience this kind of unfortunate event, sometimes you can recover from this! The first thing to do is immediately remove the battery. The quicker you remove the power source, the better. Then, you should open the remote and dab obviously wet areas with a soft cloth. To open the remote do the following: remove the two screws - one in the battery compartment and one at the top of the remote. The next step is to seperate the two halves of the remote. Don't use a screwdriver for this, you will only mar the surface and possibly break the tabs that hold the body of the remote together. Using your thumbnail (this is really the best, unless you have a thin, rigid piece of plastic. A part of a credit-card may work), force your nail between the two halves of the clamshell casing near the bottom of the remote on the left or right side. Once you get your nail (or plastic) into the remote, angle it down at about 45 degrees and simply slide your hand up one side. This will release all the locking tabs very nicely without marring the surface of the remote. Then do the same on the other side. Now, seperate the top-half (face). This will expose the logic board. Remove the two screws located midway on the left and right side and gently lift up the logic board part-way. Be careful, - the board will still be connected to the bottom part of the remote's body via a small power cable. Look on the underside of the logic board and you will see a small white plug. Gently pull the plug out to detach the logic board completely from the body of the remote. Once you have everything apart, you can dry the wet areas and allow the parts that you can't see to continue to air dry as well. You may need to clean some of the sugars left by the wine if there is a sticky residue left. Use alcohol or contact cleaner to do this. The metallic part of the buttons on the logic board are underneath a protective plastic covering, so with some luck, they may escape damage. Good Luck!
Oct 23, 2009 | Logitech Harmony 880 LCD Remote Control
User spilled wine on the laptop, I cleaned it as good as possible, it came on but now after I switched it does not come on again
Wine can cause the biggest problem in electric devices.Even water much better.There is not much you can do in this case.Acids and vinegar in the wine can melt up everything inside a laptop.
Jul 13, 2009 | IBM Lenovo ThinkPad T61 Notebook
Very short freezes constantly
There was more damage than just the keyboard, your fault appears intermitten and possibly some connectors and sockets are not making good electrical contact. You need to dismantle the laptop completely to inspect and clean what ever you can with distilled water and let it dry throughly. It still may not work because there may be some electrical damage to some chips and components, especially if the laptop was running at the time of the wine spill.
There is not much help I can offer you except to advise you to buy another laptop, and if the hard drive in the old laptop is OK then buy a USB hard drive case and insert the laptop hard drive in this case and use it as an external USB hard drive. You need to delete all the old system files etc. to maxmise the hard disk space.
Dec 04, 2008 | HP Pavilion dv9000z Notebook
Wine spilled on camera - repair or buy new one
It would be quite difficult to bring this camera back. I would suggest buying a new camera and keeping it away from the wine. Even if you did get a quote you liked and decided to get the camera repaired it is unlikely that the technician would be able to restore it to pre-wine functionality. David Millier Advance Camera Repair
Feb 10, 2007 | Panasonic Lumix DMC-FZ20 Digital Camera
Vizio VR1 Remote Control Logo
409 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
