Question about Toshiba Televison & Video
Toshiba 40lv665d not coming out of standby mode after being left for more than 10 mins. I have to switch off completely on the button on the left side and then reset to HDMI which is a pain
5 Suggested Answers
  • 4 Answers
SOURCE: Insignia 37" goes into standby mode
I am experimenting with Insignia's and there is a feature whereby if a signal is not detected the TV will switch to standby mode (in about 10 - 15 minutes). It's documented as a tiny "note" in the manual under "Understanding the basics - Turning TV on or off"
I don't know if the TV resumes when the signal is restored or if you need to power on manually.
You are probably experiencing a glitch with the signal or the TV thinking the signal is not there. Are you watching a clear picture when this happens? I would first check to see if the signal is too weak (like using a signal booster). If that is not the case, it's probably the TV acting up.
I hope this helps.
Is this
Posted on Aug 10, 2009
freelance-au
  • 131 Answers
SOURCE: Takes 10 mins to start up then crackles
Hi
A common fault with this model is bad capacitors in the power supply, Remove the back from your tv and look at the power supply for bulged / swollon capacitors on top, they may even leak a brown like substance and should have a value of around 1000uf 10v
Change these where possible with the same uf but higher voltage lets say 1000uf 25/35v
Hope this helps
Please rate my reply++++
Posted on Apr 05, 2010
  • 2246 Answers
SOURCE: standby light takes abouy 10 mins to come on then
change power supply
Posted on Jan 05, 2011
SOURCE: Takes a long time to come on from standby,and I
Hi, this could be a problem with the power supply in the tv, it is common and repair kits are available quite cheaply if you have good soldering skills.
Usually this is caused by capacitors that have dried up and split, you can normally tell as the capacitors are bulging on the pcb, you can get them in a kit as I said eBay sometimes do them or you can buy them indivually from a good electronics components supplier, make sure you get the correct values for each!! marked on the side of the capacitors in xx/v V, xxx/x uF and 105oC.
The picture below shows the type of theing that happens, the brown ones are bulging/split on the top whereas the black one is fine.
High Voltages can exist in these sets, never attempt anything while plugged in and
if in doubt do not attempt it yourself and seek the advice of a qualified TV Technician.
Posted on Feb 09, 2011
Is it normal for an acoustic solution 24" LCD TV to stay for like 10seconds before coming up after switching on from the stand by mode?
10 seconds doesn't seem an excessive amount of time. Standby is supposed to be a power saving mode - the fewer parts of the circuit that are kept in complete readiness for switch on, the less power will be saved.
These days there is much prejudice against using the standby mode and it would be expected designers would respond to this by changing the internal arrangements so standby consumes less power so when the set is switched on it will take time for capacitors to charge and digital computers to fully boot and so forth.
Think of it not so much as a TV but as a computer. A 10 second reboot from the sleep mode wouldn't be so unusual...
If the TV works ok otherwise you probably have no worries...
Sep 06, 2017 | Televison & Video
What is the colour code to stop flashing yellow
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 02, 2014 | Televison & Video
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
I rescanned the channels after our area has gone digital and this went OK but now the TV won't come on and the standby light just keeps fashing as though its trying to come on. I left it all last night...
You did the opposite of what might be useful. Completely cut of it's AC supply, pull the plug out of the socket and leave it like that for 10 minutes.
Plug back in but first making sure the manual power button is off on the set, not in standby mode.
(pushed in)
Then push the manual button to restore standby mode and switch set into full on mode with the remote.
It will either have "rebooted" and work straight away or you'll need to put it into Auto Set Up mode.
Proceed as the first sections relevant from the instructions.
Sep 22, 2011 | Televison & Video
Toshiba satellite may be stuck in Standby or hibernation mode. i TRIED HOLDING THE POWER BUTTON FOR 10 SECONDS AND RESTART, THAT DID NOT WORK. CANNOT GO INTO SAFE MODE. hELP
It sounds more like there was a charging issue and not enough juice left in the battery to start it up. Try removing the battery and then putting it in again. And then try starting it up. The adapter may be shot. Some laptops won't work if the battery is out or is shot even though the adapter is plugged in. Batteries generally need to be replaced every few years.
Also watch the lights on the front to see if they're coming on when you press the power button.
Jul 04, 2011 | Toshiba Satellite A135-S2386 Notebook
My tv says invalid mode for 10 min before I can see the picture. I tried to unplug it for a minute but that didn't work. It just happened for no reason the other day and everytime I turn on the tv I have...
try a factory reset. it may be a fault when turning on. also it can happen more if left in standby mode. every now and then turn the power off completely overnight, this will discharge the capacitors and remove the static build up that can affect the bios of the tv.
Feb 28, 2018 | Norcent Technologies LT-2722 27 in. LCD...
Hi, i have a toshiba 32wlt68 stuck in standby,i have fitted a new power board, still the same! but if i unplug the tv and hold the power button for a short time plug back in i can get out of standby,and...
Okay, this may a silly thought but, was there a switch or a dip switch on this replacement board you recieved. It may be in switched into the Service mode?
Just a thought.
Blessings,
A/V Media Guy
Nov 21, 2009 | Televison & Video
I got my new samsung series 5 tv yesterday and had the ps3 working, then it had a green screen and now the tv wont come out of what appears to be standby mode
unplug the tv for 10 mins to let the tv reset then
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
Toshiba Laptop Stuck in Sleep/standby Mode
maybe u got problem with the flex cable that connect the lcd to keboard/mouse
Aug 27, 2008 | Toshiba Satellite A135-S2386 Notebook
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
Televison & Video Logo
281 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
