Question about Brother LS-2125 Mechanical Sewing Machine
I have lost my manuel and need to know hoe to thread the machine and the bobbin.
    Genius:
  • 1,788 Answers
Go to www.brother.com and download a free manual
Posted on Aug 21, 2010
Hoe do I replace the bobbin carriage
Don't know which model you have but most machine bobbins have a metal "flipper" on the front. You need to pull that open with your right thumb and index finger, then insert the bobbincase with the . You might have to wiggle it around (don't let go of the flipper until it is seated and will no longer wiggle). When it has popped into a spot where it will no longer turn, release the flipper.
Bobbin Case Threading and Inserting into Machine
The only part of this video I would contradict is, not stuffing the bobbin thread into the bobbin area. If there is an indentation in the case by the door to put your finger to open the door (like what her machine shows), just hold the thread so it fits through that finger indentation while you close the door. Some machines actually have a little lip by that finger indentation where you lay the thread.
Jul 19, 2015 | Kenmore Sewing Machines
Bought machine at a garage sale. It works but no Manuel of instructions. Need to know how to thread it.
If you can't download the manual, try putting the thread on the spool holder with the thread coming off the spool toward the back of the machine. Be sure your fly wheel is turned toward you until the need is in its highest position. With the end of the thread, work your way across the top of the machine to the left, staying toward the back of the machine, threading through any thread guides as you go. There may only be one. Bring the thread toward the front of the machine and through the thread guide at the top front of the machine, then down on the right side of the tension knob and back up to the needle carrier. Then pull the thread down through any thread guides until you get to the needle. Thread the needle and pull the tail of thread to the back of your machine. Load your bobbin into the bobbin case, insert the case into the machine until you hear a click (you may need to rotate the case slightly to get it into the machine.) turn your fly wheel toward you while holding that top thread toward the back of the machine until the bobbin thread comes up. Pull the bobbin thread up and to the back of the machine an you are ready to go! Good luck!
Jul 22, 2014 | Sewing Machines
I do not have a manuel on a singer 57817c and want to know how I thread the bobbin
Look here http://new.singerco.com/products/detail/88 for a manual for your machine. But first look here for how to wind the bobbin on your machine http://www.singerco.com/resources/bobbin_wind.html and then this page for threading the bobbin http://www.singerco.com/resources/operation_basics.html You'll have to pick which type of bobbin you have to view the correct set of pictures for your machine.
Mar 14, 2011 | Singer 3116 Simple
This machine came with a very limited Manuel. The bobbin thread is knotting up and not catching as it should. I've re threaded several times removed and reinserted the bobbin, but can't seem to find the...
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 22, 2011 | Janome SEW MINI Mechanical Sewing Machine
Need to know how to thread bobbin
manuals can be purchased @ janome. com. your machine should have a bobbin winder. Set empty bobbin on the bobbin winder pin. Thread spool of thread though guide(or tension wheel on the top of the machine;NOT the stitching tension.) wrap thread around bobbin to start, and push bobbin toward the flywheel. slowly press foot pedal and bobbin should begin to turn. apply more pressure to foot pedal to increase speed.When full, bobbin winder should kick back to stop.
May 29, 2010 | Janome 2049LX Mechanical Sewing Machine
My bobbin wont engage with the stich. it just keeps getting jammed up. i lost the manuel i have no idea what to set the tension.
Try these solutions
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Dec 24, 2009 | Sewing Machines
My machine will not pick up the bobbin thread
how long have you had the machine?
I don't see what kind of machine you have?
does the bobbin drop in from the top, side, bottom?
email me at
monis_gifts@bellsouth.net
tell me what kind of machine and model number you have
I'll see if I can help
Sep 02, 2009 | As Seen On TV Sewing Machines
Need to thread machine-no manuel
most common machine have in threading process,I ve holding different brand sewing machine they only differ is in design but the process are commonly same,start bobbins winder to wind threads
  • pull thread from spool on top of machine insert bobbins winder disc then rotate on bobbins winder 4 to 6 times manualy put it on the shaft winder locate at top of machine near handwheel,push the latch against to bobbins winder to fit,then release clutch handwheel by pulling handwheel to disengage motio only winder will rotate when you press foot pedal and start winding thread on clockwise rotation.if this filled insert bobbins winder to bobbins case and pull the end of thread inserting to the slot of bobbins case observe should have tension on this.e5b8d97.jpgas shown and dirction of thread.inset this on the shuttle case.then start looping thread on top of machine as shown22d0eb9.jpgthen start adjusting tension on tension dial you can see in fig.Set dial at # 3 at start of set up ,Stich adjustment at #8 to 12 adjust gradually.
the hook up the lower thread bobbins from lower shuttle by threads on needle then insert cotton fabrics manualy rotate handwheel until needle the fabrics freely don't apply foot pedal let it shown if the neele sew freely w/o looping under bobbins let sew manualy until it appears stiches on fabrics,if ok continue now aply foot pedal
gradually until you familiarize again the sewing.
Mar 14, 2009 | Bernina Sewing Machines
Bobbin Threading
Divot on needle must be installed facing bobbin case.
Apr 24, 2017 | Consew 199R-2A Sewing Machine
Bobbin Thread won't come through
Thread the machine and the bobbin. Turn the handwheel towards you with your right hand and hold the the top thread in your left hand pulling slightly to the back of the machine. When the needle goes into the needle plate keep turning the handwheel untill the needle picks up the bottom thread and by pulling the top thread you shold be able to pull the botoom thread through the needle plate.
Practise makes perfect.
Regards
Dupina
Dec 11, 2007 | Singer Featherweight II 117
Brother LS-2125 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
