I tried to install image mate by dragging into hard drive. Now disk will not allow me to find read me or usb installer
  • 85 Answers
From whare r u trying to install emage. u have internal or external hard didk tell me clearly
Posted on May 03, 2008
On Mac book pro, I have installed Axure software, Not able to open it.
Hi Satish
Did you download the Mac Version? .EXE files are for Win PC and won't run on a Mac (Unless you have used BootCamp to install Windows)
The Mac version downloads as a .DMG file (AxureRP-Pro-Setup.dmg) which is a Disk Image and should mount on the Desktop like a Hard Drive.
Apple now turn this off by default so goto Finder Preferences and turn on "Hard Disks" then "Advanced" / Tick "Show all filename extensions"
When the Disk Image shows on the desktop just open it and drag the actual App to the Applications folder (or Desktop). You could then drag it to the Dock at the bottom of the screen to make a quick shortcut (alias)
Also be aware that Apple try to protect your Privacy etc from unauthorised Apps. So if it opens with a warning, you can fix this by going to your System Preferences / Security & Privacy / General and click "Allow Apps downloaded from" click Anywhere.
Hope this takes care of your problem?
If So...Click HELPFUL
Cheers
Jul 03, 2015 | Apple MACBOOK PRO 15" A1211 T7400 2.33Ghz...
Tip
How to intall windows 7 from pen drive...
How to install Windows 7 from a .iso without burning onto a DVD
proxy?url=http%3a%2f%2f1.bp.blogspot.com%2f_uu-faylkkn4%2fs5sjwgyglri%2faaaaaaaaih0%2fwwn5u85pula%2fs400%2fwindows7_logo.jpg&container=focus&gadget=a&rewritemime=image%2f*&refresh=31536000 Windows 7 doesnot allow you to install off the same Hard Disk. But if you didn't want to burn the .iso image of Windows 7 that you downloaded to a new DVD - you can still install it off the .iso file by using the method below.
You will need a portable hard disk / pen drive though.
Incase, you have a portable hard disk or a pen drive - do the following : 1. Get WinRar (www.rarlabs.com) and install the software on your machine. WinRar is similar to winzip but supports many other formats including .iso. 2. Extract the .iso of Win7 to your pen drive / portable hard disk. Place the extracted files into the root of the drive - your other data can be put into folders. 3. Restart your laptop and hold F9 / F2 to enter into boot-menu which gives you a choice to load from. Here select your pen-drive / portable hard disk - usually a USB device.
Done - that's all it takes. You can now go ahead with the normal install process.
on Mar 08, 2010 | Computers & Internet
Needed is an operation manual "how to" for HGST Touro 4TB external hard drive machine just bought. Want to know how to transfer files from computer to external storage?
FIRST the short ANSWER; Open Windows Explorer and drag and drop files/folders to new drive.
LONG ANSWER; Connect drive,during boot up of PC, and ENTER (CMOS) SETUP. See if drive is listed.
IF LISTED resume boot and see if Windows FINDS new Hardware and installs it. If so go to short answer.
If not seen by windows but seen by CMOS the drive must be PARTITIONED and then FORMATTED. OR
IF disk came with install CD run install to assure all needed USB drivers are present for windows to install disk through USB port.
Once USB drivers are installed reboot PC and see if Windows finds new hardware.
IF windows still does not install new HD but CMOS shows drive is present, the drive needs to be partitioned.
To partition new drive type DISKPART at dos prompt or in START RUN OPEN and press enter.
At the DISKPART> ( prompt ) type LIST DISK then press enter.
Example: DISKPART> LIST DISK press enter
FIND the number assigned to the new drive in the list (#), then type SELECT DISK #
Example: DISKPART> SELECT DISK 2 press enter
the info returned in the dos window should be;
Example: Disk 2 is now the selected disk
Type CREATE PARTITION EXTENDED
Example: DISKPART> CREATE PARTITION EXTENDED press enter
Now shutdown the PC then reboot. Windows should now Find hardware and install new disk.
Click START then COMPUTER the new disk should be listed.
Right click on the Drive and select FORMAT use NTFS format.
now you should be able to drag and drop files/folders to your new disk.
Oct 16, 2013 | Computers & Internet
Can I upgrade OS x 10.5.8 to 10.6.8 from the hard drive (without CD)
OS 10.6 came as a option of DVD or USB stick.
On another computer you could create a disk image of the OS disk, transfer it to your computer via USB disk and mount it. This will allow you to install the update.
Oct 28, 2012 | Apple Mac OS X
How to upload pictures on a vivitar 3750
Generally the auto timer is under the setting's when your already in picture mode with the camera on. Sometimes it can be found on the camera in the form of a hotkey on the back or side
Apr 14, 2010 | Vivitar ViviCam 3750 Digital Camera
Bytecc BT-300 USB 2.0 drive mate problem : I am a PC user with WinXP O/S. My BT-300 worked fine when used along with 2.5 in laptop hard disk (power cable connected to drive mate). On the other hand, I am...
First is the "Drive" formatted? It will not work, if it is a new drive, until it is formatted. And/Or "Initialized"? If it has data on it already then it may be faulty? the only way to check that is to try it on another machine... also are you 100% sure you have it connected right way around, I have made exactly that mistake, before, I learnt whats what. Also try another USB port, this sometimes works. Try the setup on another PC to check it is actually OK.
Feb 22, 2010 | BYTECC USB2.0 to IDE Adapter Kit...
How to save data from hard drive off my apple power book g4
You can drag and drop your files on to an external hard drive or USB flash drive, burn the files to CD/DVD using an application called toast - you will need a CD/DVD writer to do that. If you can find one, you can save your files to a zip disk.
Dec 04, 2009 | Apple PowerBook G4 Mac Notebook
Can't download my video files from xacti e2 to my computer
TRANSFERRING RECORDED IMAGES AND VIDEOS FROM YOUR VPCT700 DIGITAL CAMERA TO YOUR COMPUTER
Connecting the Camera to Your Computer
1. Connect one end of the USB cable to the PC/AV terminal of the camera.
2. Connect the other end of the USB cable to an available USB port on your computer.
3. Turn on your camera.
-The [USB] screen appears.
4. Select [PC] with the Up and Down Arrow buttons, and press the SET button.
5. From the Windows desktop, double click on “My Computer”.
6. Look for a new “Removable disk” icon. This “Removable disk” is actually the memory card in your camera. Typically, the camera will be assigned drive letter “E” or higher.
7. Double click on the removable disk and locate the DCIM folder.
8. Double click on the DCIM folder to open it to find more folders.
-Your recorded images and video clips will be inside these folders.
-Copy & Paste or Drag-N-Drop image and video files to a folder on your computer.
Mac users: Double-click the “untitled” or “unlabeled” disk drive icon on our desktop. iPhoto may automatically launch.
Downloading images and Video Files
When the camera is turned on and connected to your computer, it is considered to be a disk drive, just like a floppy disk or CD. You can download (transfer) images by copying them from the “Removable disk” (“untitled” or “unlabeled” disk on a Macintosh) to your computer hard drive.
Windows
Open the “removable disk” and subsequent folders by double clicking on them. Your images are inside these folder(s). Select the images that you want, and then choose “Copy” from the “Edit” menu. Open the destination location (folder) and choose “Paste” from the “Edit” menu. You may also drag and drop image files from the camera to a desired location.
Macintosh
Open the “untitled” disk icon, and the destination location on your hard disk. Drag and drop from the camera to the desired destination.
NOTE
- Memory card users may prefer to use a memory card reader (highly Recommended).
- Video playback application is not included with the package. Make sure that video playback application has been installed in your computer.
Feb 13, 2009 | Sanyo E1 Flash Media Camcorder
External hard disk installation
plz check your usb port if other device read ...........then your external hard disk so error. or if ex hard ok...you install windows vista .
Jan 19, 2008 | Computers & Internet
External hard drive
Try these steps: - Right-click on "My Computer" - Click "Manage" - Click on the "Disk Management" icon in the left column (Under the "Storage" category" - If your disk appears on the right-hand side, then try to right-click on it and create a partition. The issue may just be that, since the disk is not partitioned/formatted, a drive letter has not been assigned, which would cause it to not show up in the "My Computer" list Good luck!
Oct 06, 2007 | Western Digital My Book Essential Edition...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
