Question about Kole audio QX1-2400D Car Audio Amplifier
Can i download a schematic for the qx-1 2400d
  • 666 Answers
Yeah u will want to google the model and exploded view and you should no problem
Posted on Aug 20, 2010
My nissan maxima qx 2.0l v6 wont start what can be the problem
Write your answer...i need help! For valve timing the car had engeen down an am fixing it and i dnt knw how to put the timing corrotly name of the car is nissan v6 Qx 2.0l maxima double top
Apr 18, 2015 | Nissan Cars & Trucks
It won't move forward/backward or sideways with the gyro(safe) off
Check this video on YouTube to understand all about the three flight modes and the SAFE technology. Blade Nano QX Basic Overview and set up
Aug 29, 2014 | Red Rocket Hobbies Blade Nano QX BNF
I have a phoenix gold Qx 180.2 amp and im gonna push two 10" comp kicker subwoofers. will it work
Do you no the continus whate rateing of it? End i don,t mean peak or maximiun Watts on it, All so the RMS) watts that the sub will handle,
Nov 12, 2012 | Phoenix Gold QX 180.2 Car Audio Amplifier
Need software for qx5
digial blue has ISO file to download so you can burn a new dvd.
http://www.digiblue.com/pages/Downloads.html
You will need blank dvd disc
Sep 24, 2011 | Prime Entertainment QX-5 Microscope
Universal remote control codes for akai qx-5690UFX
Check with the universal remote control from philips
Jan 07, 2010 | Akai QX-5690 UF Shelf System
Required printer driver
Driver is free from Okidata....just choose which operating system you are using and download here:
http://my.okidata.com/pp-ML320Turbo.nsf/openingdrivermenu?OpenFrameSet
Dec 28, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Pioneer QX-949
From Charles (owning a QX 949, still working but with some investment into repairs by myself) :
QX 949 contains a "power protection cirquit". This cirquit reacts aswell on short-cirquit (either within the output-amplifier cirquit {transistors} or by faulty speakers) as on overload (by playing musik toooo loud).
Your QX 949 might therefore either be affected by short-cirquit within one of the four output amplifiers or there might be a problem within the pre-amplifier or power section, causing an AC or DC signal to appear at the inputs of the output-amplifier section and therefore overloading the output, as if music was played too loud. First basic test: does the discribed "tick sound" (which means that after power-up the protection cirquit releases the relais again) also appear when the volume is turned down completely ? If not, the fault must be a signal produced within the pre-amplifier section before the volume regulation. If yes there still could be a pre-amp problem after the volume regulation but it´s more likely to be found within the output-amp section. One won´t get round to measure this section (oscilloscope) at it's signal inputs to exclude a faulty signal to arrive there. If this is not the case I would recommend to disconnect and reconnect the four output-amps from the power supply one after the other, for finding which one causes a short-cirquit. But before doing this: try out what happens if you change QX 949 into 2-channel mode by turning the socket on the rear panel. Doing this the output amps for the rear channels are deactivated. If your QX 949 was working under these conditions it would limit your further search to the amps for the rear channels.
There is also a small chance that the power-protection cirquit as such is faulty or that the power supply contains problems. The power supply has got 6 fuses that you will find underneath the bottom plate. Are they all still ok ? (If one of them is broken then there can be a positive or negative supply to the output-amps as these are receiving + and - DC-currents from the power supply)
Basically: this amplifier is almost about 30 years old. As the lifetime of electrolytic capacitors ends after about 15-25 years there appears the need to replace them all (on all the prints). I did it with my QX 949... but you definitely must love yours to do that, it's quite an investment of patience and time.
And: servicemanuals.net display on their webpage availability of QX 949´s service manual. If you can't find it I might be able to scan some pages.
Charles (Switzerland)
Mar 13, 2008 | Audio Players & Recorders
Kole audio QX1-2400D Car Audio Amplifier Logo
79 people viewed this question
Top Kole audio Car Audio & Video Experts
David Burbee
David Burbee
Hashim Khan
Hashim Khan
Terry Hair
Are you a Kole audio Car Audio and Video Expert? Answer questions, earn points and help others
