Question about Logitech Dual Action for Pc (963292-0403:) Game Pad
Physics files given a game from bigpond.comau called pirates of the burning sea. Down load game that seems to work. To be told i need to download physics novodex files bigpond give a company called ageai you download this sorry try to but every time you try it crashes saying fatal error is there any where else to to get program or other solution or do you think just bin game
    President:
  • 2,712 Answers
Bin it..not worth getting your PC screwed up over this.
Posted on May 03, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    Thank you for using FIXYA!
    IrishDruid
How can I download and burn ps3 games from torrent site?
In order to play burnt games on an xbox 360/ps3, you need to put a mod chip on your system. the only problem with doing that is that it usually means you can't go online any longer.
Aug 23, 2014 | Sony Playstation 3 (PS3) Console
Password for rar of Pirates.of.the.Burning.Sea - SKIDROW
You could try this, http://extratorrent.cc/torrent/2529755/RAR+Password+Unlocker+4.2.0.0+Software+%2B+Crack.html
May 26, 2014 | Sony Pirates of the Burning Sea for...
How to download games using the internet
Assuming these are not pirated games.
Download an ISO program such as imgburn and burn the iso files to cd or dvd as appropriate..
Jun 05, 2013 | Computers & Internet
I ve got sony ps2 in india and i always have to get a new gaming cd. is there any option to unlock my ps2 so that i even use pirated cds on it.
If your PS2 is made pre-2009 (has a manufacturer number less than 9xxxxxxxx) then you can use a bootloader to unlock the USB and hardrive to play "backed up" games and AVI movies.
You will need on of these things:
1) an original copy of 007 Agent Under Fire or an original PS1 game, to use as a "trigger" disk.
2) a original copy of Gameshark, SwapMagic, or CodeBreaker for PS2 (DL'ed copies wont work)
and you will need:
1) a memory card plugged into your PS2 slot 1
2) a USB drive
Now do this:
Load the boatloader ELF file from a burner "backup copy" of your 007 disk (using the "disk swap trick" on your "sensor-modded" PS2. I used ESR Disk Patcher and Apache V1.1 to alter the TOC values of the ELF file and "patch" the ISO file before burning, and I used the disk swap trick after playing level one of the game, saving, and then loading the "driving level" (level 2).
OR use SwapMagic or similar tool to load the bootloader. You can find Youtube videos detailing this process.
Install Free McBoot onto your memcard using the bootloader. You can use the "noobie package", use google to find this and put the files onto yor USB card. Voila! Now you can play AVI files or "backed up" games from USB or hard-drive, among other fun things.
Apr 24, 2011 | Sony PlayStation 2 (PS2) Console
I have engine.exe error when i try to run Pirates of the Caribbean for PC What can i try to do?
Hello Etto!
Recently i had the same problem with this game. However, in my case i finally managed to solve it! I guess, the main problem was, that the game couldn't communicate with my Intel on board graphic card, what is more, it didn't see my AMD Radeon video card. Finally i found 2 soultion:
First: swich off Intel on board graphic card. This way the game used my AMD Radeon video vard without any problems.
Second: Use a software, called SwiftShader2.0, which can make the game use the Intel on board graphic card without any problems.
You can download SwiftShader2.0 from here: http://www.moddb.com/mods/new-horizons/downloads/swiftshader-v20-demo
Having downloaded, sipmply install it to the root folder of the game (in my case it is C:\Program files\Bethesda Softworks\Pirates of the Caribbean)
Note that, there is a "Config" file in this root folder, and using that you can make the graphical settings of the game (resolution, set it to full screen mode, etc.). For some reasons this didn't want to work in my case, but there is an other way of doing these settings: in this root folder you can also find an "engine.ini" file, which can be opened as a .txt file. If opened as .txt, than you can rewrite the data in it, in order to make the desired changes (for examlpe you should rewrite "full_screen = 0" to "full_screen = 1", to activate full screen mode. You cn also chage the graphical resolution of the game this way.)
If necessary you can easily reinstall SwiftShader2.0, using its reinstall icon, that can be found in the same folder, in which it was installed.
The link i have given to download SwiftShader2.0 is originally a created for "New Horison", which is a promising mode for Pirates of the Caribbean. You can also download the full mode, and install it containing SwiftShader2.0. This may also solve your problems, because as far as i know the developpers of this mode made it work on modern systems. What is more, this mode contains much more adventure -for example you can choose from about 7 very different charachters to play with! But personally i decided to play without whis mode, because in my system it wasn't performing well, and anyway, i wanted to play with the original game.
I hope, this will solve your problems. /Sorry for spelling mistakes/
Mar 07, 2011 | Bethesda Softworks Pirates of the...
I keep getting an error in sea.dll in pirates of the carribean pc game
Hello rvartak132
I don't know why, but PotC hates the Intel chipset!
You need to download and install an application called Swiftshader. You will suffer a loss in performance, but you should still be able to run the game on lower settings.
You can download it directly from here: http://www.moddb.com/mods/new-horizons/downloads/swiftshader-v20-demo
If you need any further assistance, feel free to ask. Good luck!
ajblaj
Sep 15, 2010 | Bethesda Softworks Pirates of the...
Pirates of the Caribbean engine.exe error
Pirates of the Caribbean problems with ENGINE.exe: In my case a simple software, called SwiftShader2.0 solved it!!!
Recently I also had a problem with this game. Every time i tryed to start a new game, an error occured, stating, that the engine.exe stopped, and the program exited. After spening all night researching on this topic, i found the solution: you should install SwiftShader 2.0. It is a simple and great program (as far as i know it changes the graphical performance, in order to get the game work).
You can download it from here: http://www.moddb.com/mods/new-horizons/downloads/swiftshader-v20-demo
Note that, there is a "Config" file in this root folder, and using that you can make the graphical settings of the game (resolution, set it to full screen mode, etc.). For some reasons this didn't want to work in my case, but there is an other way of doing these settings: in this root folder you can also find an "engine.ini" file, which can be opened as a .txt file. If opened as .txt, than you can rewrite the data in it in order to make the desired changes (for examlpe you should rewrite "full_screen = 0" to "full_screen = 1", to activate full screen mode. You cn also chage the graphical resolution of the game this way.)
The link i have given to download SwiftShader2.0 is reliable, it is originally a created for "New Horison", which is a promising mode for Pirates of the Caribbean. You can also download this full mode, and install it containing SwiftShader2.0. This mode contains much more adventure -for example you can choose from about 7 very different charachters to play with! But personally i decided to play without whis mode, because in my system it wasn't performing well.
I hope, this will solve your problems too. /Soory for spelling mistakes/
Aug 26, 2010 | Bethesda Softworks Pirates of the...
Can't launch a new game in Pirates Of The Carribean
your computer probably cant run the game, check your graphics card, RAM, and processor speed, make sure it meets the requirements for the game or exceeds them, if one is below, the game will most likely not work
Dec 01, 2008 | Bethesda Softworks Pirates of the...
Have downloaded game. its an image file need to burn to dvd to play
yes you should be able to save the game to hard disk, and play the game as well. you don't need to burn it to cd to play it.you may need to unzip it. do you have unzip?
Nov 26, 2007 | Microsoft Windows XP Home Edition
Logitech Dual Action for Pc (963292-0403:) Game Pad Logo
42 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
