SOURCE: Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
SOURCE: I need a diagram for a Kohler carburetor on my
I dont see any Diaphram listed. I would go to your local Yard equipment Dealer that handles Kohler. but my reference books show no diaphram or even a model ca
Sorry
SOURCE: My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
I hope you find this solution helpful. Please rate it thanks for using Fixya!
SOURCE: Oil leak on riding Craftsman LT2000 (Kohler)
Fortunately, the engine oil doesn't go through any rubber hoses, so they are mouse-proof. The oil probably leaked out through an engine seal. Oil on the engine surfaces would smoke when it gets hot. Check your oil level and top it up if necessary, before you run the engine again. The engine can run fine even with a slow oil leak; you just have to watch the oil level from time to time. The leak could be easy to fix - by tightening up a few bolts -- or expensive.
The gas runs through rubber hoses, though. If mice ate through that, I think you would have smelled the gasoline, and the engine wouldn't run for more than a few seconds. But if you see a severed hose, you should replace it. Take it off and bring it to a mower shop or auto supply shop, and buy something the same diameter. Inexpensive.
Hope this helped! If so, please rate my answer, thanks!
Testimonial: "Whew, you've eased my mind. I'll head out tomorrow and try your suggestions. I really appreciate your input and the fact that you are willing to respond! Thank you!"
SOURCE: craftsman riding mower-what year was it made
Hello! The 917= American Yard Products...A major supplier to Sears...The first six digits of the SN#...00/00/00= date of manufacture...In your case...May,1,1997...
Guru.....................Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Testimonial: "Thank you very much!"
