Question about Sylvania 6427TE 27" TV
How to program a GE universal remote to a sylvania tv
SOURCE: Sylvania 6419TA
try the codes for the sylvania vcr
Posted on May 30, 2008
SOURCE: rca remote, codes don't work for sylvania tv
Trata con esto.
Presiona el boton Code search y mantanlo asi hasta que el led se quede encendido suelta y presiona el boton TV despues vas a presionar y soltar el boton Power hasta que el televisor se apague despues presionas el boton enter y el codigo queda almacenado.
El Tv tiene que encenderse primero manualmente.
Posted on Jun 03, 2008
SOURCE: philips universal remote - tv codes for Sylvania
Only one code worked (out of the 13 codes provided for Sylvania TVs with my Philips Universal Remote) so I could program my Philips Universal Remote to operate my Sylvania 6413TC 13" TV: 0520
After manually turning on the TV:
1. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
2. Press and release the desired Mode button (in your case - TV). The red indicator blinks (very quickly), then stays lit.
3. Enter the 4-digit code (0520), and if it's valid, the red indicator should turn off. (Supposedly, for an invalid code, the red indicator flashes. However, when I tried all 13 codes, the red indicator turned off, yet only one code actually worked. Go figure.)
4. Press CHANNEL UP. If your TV responds, no further programming is required. Although, some buttons on your Universal Remote may not operate your TV. (They all worked for me, yeah!)
If 0520 does not work for you, here are all the codes provided by Philips: 0807, 0002, 0502, 0115, 0520, 0919, 0324, 0247, 0402, 0408, 0109, 0715, 0717.
Posted on Sep 08, 2008
Several people in the on-line forums suggested inputting the brand search codes for Philips and Magnavox sets -- but it didn't work for me. Someone else suggested that Funai Corp (China) now makes some Sylvania sets, and their rep said that universal remotes don't work for their products. My Philips Universal Remote says to enter "0" for the brand search code, and that will instruct it search for all the codes installed in it. But there are approximately 300, so be very patient. And it didn't work for me anyway. . . but maybe it will for you.
If you do find an answer/solution, pl post it, OK? Thanks.
Donna
Posted on Mar 29, 2009
Just4help
  • 145 Answers
SOURCE: cant program my universal remote
Search the model # of the REMOTE on www.google.com and a good portion of the manufactures have the Codes on thier sites for you.
Posted on May 25, 2009
How do you program a ge CL3 24922 universal remote to a sylvania tv/dvd combo; when none of the codes I have tried works?
You may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Jul 28, 2017 | GE Televison & Video
I have a sylvania tv an a ge universal remote what are the codes to program remote
Get the manual for the universal remote from the manufacturer website.
Jul 27, 2015 | GE Televison & Video
Need to program my phillips universal remote CL035A to my Sylvania TV
Look in the manual of your
Phillips universal remote CL035A for ther listing of TV codes, take notes of codes for Sylvania and input codes accordig to instructions of your manual.
If you can locate Sylamia, follow instrucions for unspecified device.
You don't have a manual?
How to Program Philips Remote Control Without the Codes eHow
Jun 19, 2015 | Sylvania Televison & Video
I'm using a ge universal remote and cnnot get the sylania model 6513 DF to work
Hello
You haven't described anything about the model number of GE remote. Eventhough it is universal remote, it will have a model number. Model number is necessary for us to give you correct codes. I hereby give you code for Sylvania combo. Check it with.
0456
The code for Sylvania TV/DVD combo with GE RM 24912 universal remote is:
456
Check this code [456] with your present GE remote. Sometimes it may match. OK.
Jun 04, 2011 | Sylvania 6513DF 13" TV/DVD
SKU24914 what are the codes for sylvania t.v
The RM24914 uses a four digit code. Try the following codes: SYLVANIA 0062 0004 0009 0135 0189 0183 1141 0227 0456 0008 0068 0075 0141 0161if the TV isn't a combo unit.There is also a manual programming option. Turn on the TV manually. Then press and hold Setup until the light comes on. Release the button and press TV. Press On/Off until the TV turns off. Press Enter to lock in the code. Then test if the remote controls all the features of the TV. If not, repeat the process from holding Setup.
The manuals for most of the GE universal remotes are here: http://www.jascoproducts.com/support/manual-downloads/index.asp?searchcat=GE+Universal+Remotes&offset=0 . The code lists are here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
However, the codes in a universal remote are usually limited to those for devices released 6 months before the remote was programmed. If your remote is older than your TV, you may need a new remote.
I hope this helps.
Mar 22, 2011 | GE JASRM24912 Remote Control
I need to re-program my GE universal remote to my Sylvania TV
see if you can find your GE universal remote at a store where you got it from or any store, best buy, target,, walmart, etc...open up the package and write down the instructions or code numbers :-) hope that helps and good luck
Apr 07, 2009 | Sylvania Televison & Video
I need codes for philips universal remote control
lost manual tring to hook up dvd/vcr emerson up need code
Apr 24, 2008 | Philips Universal PH301S Remote Control
Sylvania 6427TE 27" TV Logo
200 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
