It is a new set. Charged for more than 14 hours. But while connected with the telephone line and reconnected with power. the set is not starting!!!!
    President:
  • 4,070 Answers
Hi! Have you tried replacing or swapping the cables? This issue can be caused by a faulty cable. Please try on the cable first. Hope this helps and thank you for using FixYa!
Posted on Aug 20, 2010
Want to be clear about the handset and telephone base set because base set is not responding to handset.
The base needs to be plugged into the wall for power and have a working phone line.
Oct 16, 2014 | Lands Phones
Lost phone manual, uniden d2997
I have a standard trouble-shooting routine for cordless phones. 1) Remove the battery from the handset (from all handsets for a multi-handset version). Then unplug the power cord from the base and wall outlet and also remove the telephone cord. Wait a few minutes and then reconnect the power and phone line cords. Reconnect the battery (ies) for the handsets. Make sure this connection is tight. Then make sure that the battery is fully charged (15 hours before first use) and register the handsets if needed. This is done by putting each handset onto the base in order for the D2997. Wait about 30 seconds for each one until you see the Handset Registered message. Make sure that you are within range of the base.
Next try a different telephone (RJ-11) phone cord between the base and the wall jack. Also check if the power adapter for the base is warm. For the next set of tests, I like to use an old corded telephone. Using a different phone, check if you get dial tone at the jack. If there is a dial tone, then the problem is with the Uniden phone. If the above trouble-shooting didn't help, then contact Uniden. These phones aren't meant to be user serviced.
If you do not have a normal dial tone, try another jack on the same telephone line. If there is dial tone at another jack, then you have a problem with the first jack. Otherwise find where your telephone service comes in. If you have a fairly new service, you'll find an RJ-11 jack. Plug your test phone into the jack and test for dial tone. If you have no dial tone or can't test your line, call your phone company. They will fix any outside problem for free. If it is an inside wiring problem, look at the visible wiring and determine if the wires are damaged. Open the jack (if only one is bad) and check for loose wires. There are two types of jacks. One secures the terminal wires with screws and the other uses a punch-down jack. For the screw type, strip additional insulation from the conductors, if needed, and then reconnect them. For the punch-down type, you will need the punch-down tool. It is available at many hardware stores in the wiring section. Use this diagram to check your jack wiring: http://www.lanshack.com/wire_phone_jack.aspx . If you can't see an obvious problem with the wiring, you may want a professional to deal with the wiring in the wall. Your telephone company will do this for a fee.
Uniden has the manuals for their DECT phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manual for the D2997 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D2997om.pdf .
I hope this helps.
Nov 26, 2011 | Uniden Lands Phones
CANT SEND FAXES THROUGH THE PC
1.The machine is not on-->You cannot send faxes if the power is turned off.Press [on/off] to torn the power on.
After a power failure or disconnecting of the power cord ,press [on/off] to turn the power on.
2.The telephone line is connected to the external device jack .
Reconnect to the Telephone ?Line Jack .
If you still cannot send a fax,there is a problem with the telephone line.
3.Cannot here the dial tone-->check that the telephone line si connected correctly to the proper jack,if so,then there is a problem with your telephone line.Contact your telephone line provider.
Jan 02, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Hi, I am setting up a canon mp730 for a friend. I have run into a problem with the fax phone line. I have connected the lines correctly to the copier and her answering machine but when I try to use the...
Remove the connection and once again try to re connect the lines between the copier and phone line . You might have some connection . Just give a try .
If this doesnot work . I will let you know how to proceed further .
Oct 12, 2008 | Canon Office Equipment & Supplies
I need help still
Beth31046:
you are not dumb!! , I just have to understand your needs.
1st- u received modem, card, phone line filters and no software cd.
one: Every telephone line (hole in wall) that u have a telephone connected to, unplug telephone, connect a " telephone line " filter, then REconnect the telephone, etc to the filter.
2nd-cards?? Did u receive a 'card' that goes inside a "Desktop" computer or whats looks like a credit card that slides inside [usually the side]of a 'Laptop'? If the card is for the Desktop, then u have to open the back of computer,[POWER OFF!!] find an open slot (nothing connected to it) It should have a metal cover with a screw, that prevents things from entering, unscred, take metal tab\cover off, replace with" card" and screw down. The "card" should have what looks like a telephone connector opening (that usually connects a telephone line) excapt the opening for "telephone" line is wider, larger. That opening takes a male\plug that is a little thicker\larger then a regular "telephone" line. 3rd- on the modem, there will be two openings in the back. one for the regular telephone in from the wall [Make sure that there is a filter in the wall with the telephone line]. and a 2nd larger opening for the (thick but not too thick) wire coming out from the computer "card" to the modem
You have to call the people (Embarq, AT&T, etc) that sent you the STUFF, and they should set you up.
if this helps, please tell the FixYa people that I helped you.
Chow,
May 04, 2008 | Westell Wirespeed VersaLink...
Sakar Telephone Problem
This Telephone doesnt have a capability to work with shared connections where u use more than one phone in one connection.......... And this phone cannot be charged it works in either battery or Adapter...... Good Luck......
Dec 10, 2007 | Sakar Talking Caller-ID Speaker Phone
In Use Memory is flashing and there is a clicking sound.
Okay, this is what happens when you put your USB cable into the external device jack next to the telephone line jack (instead of the USB port). Once you plug the stuff in correctly, the problem goes away.
Flauren (original Author on another w eb s ite)
Nov 02, 2007 | Canon PIXMA MP780 All-In-One InkJet...
"searching" message even when handset on the base
Found the following in AT&Ts FAQs for your phone, I'll leave only what might be relevant: # Charge the handset for 12 hours. After the first charge, the battery will quick charge in only 8 hours. Re-cradle the handset nightly for recharging. The battery will not overcharge. # Connect telephone line from base to unit to modular telephone jack. If cord is already plugged in, unplug and reconnect at both ends. Also, you may want to try another cord from a working telephone. See the owner's manual under "Connecting to Phone Line." (you can get the manual here on the product page in case you lost it) # Try a working phone at the jack. If another phone has the same problem in that jack, the phone jack is defective. Good luck, hope you work it out
Jun 03, 2006 | AT&T 2256 Cordless Phone
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
